Question about Philips MMS 321 Computer Speakers
Computer speakers are buzzing - Philips MMS 321 Computer Speakers
  • 2 more comments
  • Anonymous Feb 03, 2009
    I have the same problem. I've had them for about a month and just noticed it a few days ago.
  • Anonymous Apr 27, 2009
    even when the knob is turned all the way off, they still make buzzing noises
  • DonsComputer May 06, 2009
    when i plug my mic in my speaking well start making dang buzzing noise i installed sound blaster Audigy SE. everytime i plug it in it starts up
  • Arlon Rosell May 11, 2010
    Just a clarification:
    Is it buzzing when you play audio?
    Novelist:
  • 152 Answers
Common humming sounds from computer sound systems stem from the follwing:
1) Interferance with other electrical componants / devices
Solution: EMF / Radiostatic shielding may provide the solution
2) Defective componants
solution: try the hardware in another PC, if it still hums, your board / plug-in compants may be defective.
3) Jack(s) - Headphones / speakers have loose connection
Make sure everything is plugged in securely, and your jacks have not been damaged, also make sure you are plugged into the correct ports.
4) Microphone boost / auxiliary settings
check your sound settings, disable any ports you aren't using. Line-in, Aux, CD-rom, Digital Input.. if they aren't being used, they may be creating "whte" static in the lines. Muting them, or disableing them in the sound settings for your device may provide the solution..
5) It has been known to happen that certain CPU / Case / Power supply fans emmit a sonic frequency through the speakers due to EMF expulsions from the electro-magnetic motor. This is rare, but is possible, Disable the case fan to determin if it's the culprit, swap power supply, or CPU fan to determin if they are the issue.
WARNING: Never run your PC without the CPU fan in full operation, Never run the PC without your Power Supplies fan in full operation: This can lead to DAMAGE to your PC.
On a personal note: My card has several different ports, make sure you are plugged into the correct port, and muting the Aux cleared the humming in my computer's sound system.
Posted on May 29, 2009
  • 835 Answers
This can be caused by several diffrent things. Most of the time it has to do with electrical interference. **** as being placed directly near your monitor, the computer itself, a tv, a radio, or any other appliance that uses a lot of power.
the 2nd thing that can cause this issue is that the speaker is not hooked up properly into your computer. Double check that it is all the way pushed in.
The last and final solution. Sorry friend but you either blew your speakers, or they came to you already defected.
Posted on May 09, 2009
  • 44 Answers
Try moving them away from the screen, or if possible using another power supply. (check voltage . polarity!)
Posted on Apr 30, 2009
My logitech x-210 speakers make a buzzing sound
Sounds like the speakers are not plugged in to the computer, or are plugged in to the wrong socket.
The speaker socket on a PC is usually green, a 3.5mm stereo socket.
Apr 23, 2010 | Logitech X-540 Computer Speakers
Annoying buzz coming out
i have a similar problem, and i've seen loads of stories about the same problem from these speakers, it's a shame because otherwise these speakers are pretty good :(
The speakers seem to pick up interference, especially when the volume is low, they also sometimes give out periodic buzzes, but this could be individual faults with equipment.
Jun 11, 2009 | Logitech X-240 Computer Speakers
My speakers are not plugged into any soundcard but are buzzing
May be a short somewhere, speakers always have a little white noise and buzzing, usually nothing you'll notice.
May 28, 2009 | AOpen MA-691 Computer Speakers
Subwoofer Emits a Buzzing Tone
The 2200 uF capacitor in the power supply has gone bad and the humming is a 60 Hz from the rectification of AC to 18 vDC.  Either get a new power supply or take apart the power supply and replace the bad cap.
Mar 16, 2009 | Altec Lansing AVS 500 Computer Speakers
Buzzing noise from speakers
The buzzing noise is being heard probably because there is another electronic device around that's using radio waves to function. (Such as a cell phone, a cordless phone adapter or a wireless router. Even microwaves and ceiling fans can give off these sounds.)
My advice would be to try and move around or turn off some appliances in your room that may give off radio waves.
Sep 18, 2008 | Logitech Z-2300 Computer Speakers
Computer speakers
Try updating your drivers for your sound card.
Mar 13, 2008 | Logitech X-230 Computer Speakers
Speakers Buzzing Whilst Playing Music
sounds like interferance try moving the speakers around maybe away from the monitor and try turning off any thing elec around your pc to find out maybe what is causing this
Dec 01, 2007 | Philips MMS 460 Computer Speakers
Speakers make a buzzing noise but wont play anything else
make sure that your system volume is turned up and that the speakers are turned all the way to the right.
Aug 22, 2007 | Dell A215 Computer Speakers
Philips MMS 321 Computer Speakers Logo
567 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
