Question about LG 42PX5D 42 in. Plasma HDTV
I lost my picture except for coloured bands that run vertically across the screen sound still works and I can change channels
    Top Expert:
  • LG Master
  • 74,377 Answers
Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. You can also click the [Home] tab to see the latest updates. It will make search easy. There are more than 1350 posts to different brand TVs now. Pull up older posts there or do a search by type in the Brand Name of your device in the Search Box, at the top right of the display window.
Posted on Dec 09, 2012
  • 146 Answers
SOURCE: multi coloured vertical stripes on plasma screen
With half of the screen working, and with a Plasma tv. I will look at the driver board as being bad. Take the back cover off, the driver pcb will be at the top or bottom of the set. They are only about 2 inches tall and will cover most of the lenth of the set (2 boards that run end to end). The board that is on the side of the tv that is bad is the bad board. Replace that board or have a tech replace it.
Posted on Nov 17, 2008
  • 718 Answers
SOURCE: On my LCD TV. a series of vertical colored lines
First you can try adjusting the cable to the LCD Controller (LCD CONTROLLER 6870C-0080D from LG 42LC2D) Sometimes the contacts get out of alignment and disconnecting/reconnecting it will clear it up. Do not touch the contact points.
If this does not work, you may have to replace it.
Posted on Mar 14, 2009
SOURCE: I have a videocon 42
What you need is known as a "Z buffer" or "address buffer".
It is a board located UNDER the display.
Can't tell you the board number because you do not mention the TV model, but if you are up to replacing it yourself you better get to there anyway and see the model printed on the board itself.
There are usually two boards underneat in the 42'' models, sometimes three, but usually two.
You need to find the one located where the vertical line shows and replace it.
Replacement is not hard, but requires a bit more unscrewing because those boards are usually covered by metal shielding / heatsink, which usually has quite a few metal screws.
Other than that, though, it is not hard.
Posted on Mar 23, 2010
toyladi3
  • 597 Answers
SOURCE: my tv still has sound but the picture has went.
Yes the problem can be fixed.
The problem is from the t-com board of your television. Have it replaced and your television will be in good condition once again.
Take care
Posted on Sep 09, 2010
Testimonial: "Sounds good to me :)"
  • 18 Answers
SOURCE: SCREEN IS BLACK IN ALL MODES - TV AV DVD
your problem is on the main digital board
Posted on Oct 17, 2010
Picture went black except for partial green and blue lines &2 thin red lines
Vertical scan section circuit fault. Check and replace damaged component/s at its vertical scan output section circuit. If you wish to get some details, check the site linked here. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/
Jan 17, 2014 | RCA MM36100 36" TV
Panasonic TH-42PX70B plasma tv vertical very this coloured lines in band about thrd of way across screen from right hand edge what is thesolutionto fix this problem
Sounds like COF (Chip On Film) strip fault. Check this link for more details. There is illustrations [screenshots] and reasons to plasma displays. Check it out, and compare them with your TVs fault. Pull up older posts there.
Mar 07, 2013 | Televison & Video
Magnavox 32MF337B/27 power supply works and like another writer when power is turned on the audio works the channels change and you can tell that all remote and on set keys work, but no picture except an...
hi i have a 50" magnavox that has a problem, i was looking at several websites and i find out the dirfferent posibilities.
in your case i have 2 posibble answers.
1) negative image
tv turns on and shots down in 2sec
flashing pixels on screen
dark image
has sound but no video
screen goes black and then return to normal picture
vertical color lines on screen no video
vertical color lines with video
vertical bars on screen
horizontal lines on the image
picture goes red after while
IT COLUD BE (X or Y or Z SUSTAIN BOARDS )
2) just left part of screen working
just right part of the screen is working
vertical and horizontal lines on screen
part of screen not working
some functions not working
no video but has sound
functions not working at all
IT COULD BE (LOGIC CONTROL BOARD)
TErry HerreRA
Oct 04, 2009 | Philips Magnavox 42MF521D/37 Television
No picture at all
vertical circuit not working- probably vertical output IC
May 03, 2008 | Televison & Video
Showing black screen with a blue line
Is the blue line running straight across the middle of your screen? If so its a vertical deflection problem. Possible bad Vertical output IC
Feb 20, 2008 | Panasonic PT-47WX53 47" Rear Projection...
JVC TV
civilman, the first set has either no high voltage or is collapsed vertically, until someone checks for high voltage there is no concrete answer, the AV27730 is vertical collapse from your description, either the voltage to the vertical IC is missing or the vertical IC has failed, not a big deal cost-wise, hope this answers your questions, if not e-mail me back, good luck, BMW Rider
Dec 20, 2007 | JVC AV-27730 27" TV
Banding on LCD TV
you need a new motherboard
Dec 09, 2007 | Televison & Video
HAS SOUND,NO PICTURE?
YOU'VE LOST VERTCAL DEFLECTION---THIS COULD BE SOME PARTS IN THE VERTICAL SECTION BAD,,LOST A VOLTAGE GOING TO THE CIRCUIT OR WORST CASE ----FLUID FROM THE PICTURE TUBES HAVE LEAKED ON THE CIR BOARDS CAUSING THIS PROBLEM---NEED TECH FOR THIS ONE!!!!!!!!!!!
Sep 15, 2007 | GE 46GW945 46" Rear Projection Television
LG 42PX5D 42 in. Plasma HDTV Logo
Computer Repairing
Computer Repairing
