Question about Pride Mobility Products Pride Mobility Maxima 4 Wheel Hd Scooter with 55AH Battery & Charger + Flat Free Tires 22x18 Hi Back Deluxe Fabric Seat
New battaeries willnot hold charge
Just put in new batteries two days ago. They will not charge. Outlet is live.
  • 40 Answers
Sounds like you have a bad charger. If you have access to a volt meter you can set it to volts DC put the meter to the batteries then plug in the charger. If the volts go up on the meter after you plug in the charger is working ok.
Posted on Apr 01, 2009
Why won't the Battery in my Ute hold it's charge?
You have a open circuit somewhere that is draining your battery.
Oct 23, 2014 | Cars & Trucks
Iwent out two days ago car wouldnt start cheched by pulling spark plug wires and there was no spark. I killed the battery try to start it so I took the battery out charged it put it back and the car...
Suspect your battery won't hold a charge as it did when new. As they age, from repeated discharge & charge from normal start and stop, over time they don't charge as deeply. I think this is your problem. You can verify by charging it up, and taking car to local Autozone, Advance or any good auto parts store and have them load test your battery, that'll confirm or not. While there have them test your charging system - they do both FREE
Jan 05, 2011 | 1997 Lincoln Continental
I boost the battery, and it does hold a charge but only for a day or a day and a half at most. I'm not sure what could be causing this problem. The battery was purchased Last year brand new, but sat all...
if the battery holds the charge for a day or 2 wile you drive the car normally then you should check your alternator live the car 2 or 3 days after the battery was charged and check if it starts and run if it does run it another 2 or 3 days and see if the battery dies if it dies most likely your alternator is bad, your mechanic can test it with in 3 minutes to see if it is the alternator or the battery
Aug 05, 2010 | 1991 Plymouth Sundance
Willnot hold battery charge
Hello
Thank you for using FixYa for your problem
Always check the batteries first but if is it still giving the same fault, your camera is faulty.
It should be taken to an authorized repair centre for a repair estimate. Very few digital cameras have any user-serviceable parts.
If you have only had it for 4 days, is it not under guarantee?
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Dec 01, 2009 | Jazz Cameras
Sony erricson w705, wont charge the battery, it comes up with a message saying it cant charge the battery please put a sony erricson battery in, but it is a sony erricson battery and when the battery was...
my phone is the same model and did this but when i charged it, after about an hour it would come up with 'charging error stop ' and when i unplugged it, it hadn't even charged at all. and then the other day it just wouldnt charge, i plugged it in, it said it was charging but it wasnt. in the end, it worked by keeping the phone switched off and charging it while i was turned off. so try that, if not then i really dont know sorry
Oct 08, 2009 | Sony Ericsson Walkman W705 Cell Phone
Battery will not hold charge ,where can i buy new battery
HI,
if your battery charge fully and only long with 2 or 3 hours it is normal don't worry no need to change.
but if you charge it and a minimum of 30 mins and it will drain need to chnage the battery unit.
thanks.
Mar 29, 2009 | SanDisk Sansa c250 (2 GB) MP3 Player...
DELL XPS 1210 i purchased a replacement battery not recognised
If the battery is not detected in the BIOS (F2 at boot) and doesn't show as charging, then return the battery and get a replacement.
If neither the original battery or the new replacement battery are not detected in the bios a problem with the motherboard may exist. If still under warranty, contact Dell Support for a repair, if not, then you may be investing in a new motherboard
Jan 29, 2009 | Dell Inspiron 1501 Notebook
Battery not holding charge
That sounds like typical battery life for that phone.  When I owned one that's what I got on the weekends when my call volume was lower.
Dec 15, 2008 | Motorola Mobility RAZR V3
Battery won't charge.
hello,
normally many cell phones requires 6-10hrs for its batter to fully charge up. also i have seen it where battery can be brand new but doesn't have enough juice to hold the charge.
now as far as red light on charger, remember even if you have 99% charged batter and you plug in the charger it will show you red light on phone/cradle.
FYI- all brand new phones are covered with 30 days of warranty replacement with new phone. after 30 days it covers upto 1 year from the date of purchase with refurbished phones.
In your case i think it is just the battery, try having your provider replacing new battery if no luck again then my suggestion will be to replace your phone with new battery with in 30 days.
TY
Dec 22, 2007 | Motorola Mobility MOTOKRZR K1 Cellular...
Pride Mobility Products Pride Mobility Maxima 4 Wheel Hd Scooter with 55AH Battery & Charger + Flat Free Tires 22x18 Hi Back Deluxe Fabric Seat Logo
201 people viewed this question
Top Pride Mobility Products Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
Robin Hill
Robin Hill
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
