Question about DeLonghi Magnifica Coffee Makers & Espresso Machines
Delonghi magnifica brewing unit stuck on bottom
Brewing unit stuck
EsWorld
  • 1618 Answers
SOURCE: jammed brewing unit
Remove the brew unit and check the screen under the red o-ring, find the 2 screws above the top piston and make sure the chamber that leads out to the tube is clear.
Posted on Mar 29, 2010
EwingElect
  • 276 Answers
SOURCE: Delonghi Magnifica After heating up, Unit kicks
Husband suggests that could be coming broken off the brewing unit as it should be activating, He suggests you should get in contact with your local De'Longhi Service Centre (should be info on how to contact in your User Manual, or google De'Longhi for your country).
Posted on May 19, 2010
SOURCE: where do I buy spare parts I need a brewing kit
http://www.appliancefactoryparts.com has all the parts, including the O-rings, valves, etc.
Posted on Jan 23, 2011
SOURCE: Defuser unit stuck at bottom
Recycling the power resets the position of the defuser. When you turn it off, make sure you do it via the button on the front before swutching it off at the power point.
Posted on Aug 22, 2011
SOURCE: My Delonghi Magnifica 3400 has a problme with the
My Delonghi Magnifica door was popping open too when the machine would cycle on or off. I found that the shoot on the inside of the door was stuck. This chute is spring loaded. The chute guides the coffee from the diffuser to the dispenser ports. I think it must have been coffee build up on the back side of the chute making it stick. So when the diffuser passed by during cycling the chute would not move out of the way. This makes the door pop open. I cleaned the chute so that it moves freely and no more trouble.
Posted on Sep 18, 2011
Miele cva 4075 stuck brewing unit
http://mielerepaircenter.com/miele-coffee-maker-repair
Sep 07, 2014 | Miele CVA4070 Coffee Maker
Brewing unit stuck
make sure you are trying to remove the infuser when the machine is turned off. you can damage the unit if trying to remove the infuser while the machine is on (and you won't be able to get it out).
Jan 10, 2013 | DeLonghi EAM3500 Espresso Machine/Coffee...
Siemens coffee maker model tk540001 brewing unit is stuck!
Hi, I am a user with the same problem but on a Siemens TK580001. Is the solution applicable 1:1 as the two models have different panels?
Jun 11, 2012 | Coffee Makers & Espresso Machines
I have a Miele Coffee Machine (built-in) CVA 620-1. I got a message saying the brewing unit is blocked. I removed the waste unit, a procedure that has to be done before you can remove the brewing unit. ...
The brew unit has lose parts on left-hand-side, wiggle them up and down. Put the waste unit back, switch off the machine and then turn it on (pull the cord). It worked for me!!!
Sep 14, 2010 | Miele CVA615 Espresso Machine
Jammed brewing unit
Mar 28, 2010 | Solis Master 5000 Espresso Machine
Delonghi Magnifica "insert brewing unit"
I just figured this out on my machine, I should have taken pictures but i didnt :( this problem seams to pop up whent the elevator that moves the brewing unit up and down gets its starting position mis aligned, since the machine does not have sensors to re adjust the alignment the motor will pull the elevater down even if it cant go further and that seams to cause the nasty noise we were hearing.
1. unplug machine
2. remove the side and back covers
3. remove tray and brewing unit from inside (2 red buttens you press together)
4. remove the bracket that holds the brewing unit (2 hex screws)
5. below the brewing unit bracket is one more screw, it holds the motor unit and elevator on the back of machine, remove this screw.
6. on the back pull out the motor unit with elevator.
7. realign elevator starting position by turning the bottom wheel that is connected to motor via belt, it might feel a bit stuck first as motor has ower tightened the elevator.
The back of the elevator looks like a step ladder with screw going up the middle, for me it worked best to align the bottom of the traveling bracket with the bottom step on the ladder i recomend trying that position and then adjusting if nessesary.
8. reasemble the machine and continue to enjoy exelent coffie
Aug 08, 2009 | DeLonghi EAM3500 Espresso Machine/Coffee...
Brew cup stuck unable to get out
If you open the door and take a flashlight, light in the front/middle of the brewing unit. You will see a little screw, take a screwdriver and loosen it, bend little on the little plastic above where the screw was and pull out the brewing unit.
When you have the brewing unit out then you need to reset the machine and brewing unit.
To reset the machine you have to turn off your machine, open the door.
Look in the down left corner, you will see a hole, look in the middle of the machin you see another hole and in the upper right corner.
put a screwdriver or similarly in the left corner and in the middle of the machine, turn on the machine and put another screwdriver in the upper right corner. hold it in place to the machine not get any noise more.
To reset the brewing unit, first put the plastic back again (that one you loosen with the screw first).
If you look back on the backsida of the brewing unit, in the middle you will see a plastic that looks lika a handle, force it down and you will see all the other parts will move around little. Turn it to you can see the little mark on the front goes to the N mark.
Best regards
/Mirran
Jan 29, 2009 | Saeco Vienna De Luxe Espresso Machine
Gears out of sync
Next time get in this trouble.
Look inside the brewing unit (on the left side if it´s in your machine) you will see a little screw that holds the little plastic that goes into the machine. If you get stuck you only have to loosen this screw and then you can pull out the brewing unit:-)
Jun 24, 2008 | Saeco Incanto Classic Espresso Machine
Stopped up
http://www.cafecorporate.com.au/FAQS/ProblemsandMalfunctions/tabid/75/Default.aspx#_Coffee_in_grounds
In most cases it is a result of the brewing unit getting jammed.
Some of the most common problems are :
Split ‘O’ Ring on Brewing Unit
Faulty Coffee Brewing Unit
Twisted ‘O’ Ring on Brewing Unit
Beans In Decaff Chute
Split White Cog In Brewing Unit
Water Leak On Transformer
Faulty Encoder
Plug on logic board from encoder faulty
Faulty transformer
Workshop repairs required.
Aug 22, 2007 | Jura Capresso Impressa X90 Espresso...
Coffee Makers & Espresso Machines Logo
55 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
