Question about Amana PTH123B25AJ Heat Pump Air Conditioner
Newer circut baord
I cant find my manual for the new circut baord and I have a remoate thermastat, there are a few buttons your supposed to push to transfer to the remote, but in my bumbling I managed to have the fan run all the time and now no heat. Thanks
  • mpbart Feb 12, 2009
    Thanks for helping, as it turned out a couple oa days later I found my manual, all is good with the world now. Again thanks for you help Mel.
  • 142 Answers
Okay, press and continue to hold the up and down arrow keys and quickly pess the OFF key twice within a two second time frame. the display will alternate between displaying the feature code and the option code.
In this mode, for the remote thermostat, press the HEAT key till you are on C1, using the up/down arrow keys, select rE.
For the fan prob., follow the same procedure until you are on C2, using the up/down arrow keys, select On.
And for the heater follow the same procedure until you are on CJ, using the up/down arrow keys, select 4.
Posted on Feb 10, 2009
  • Tommy Walker Feb 10, 2009
    You can access the manual also through amana-ptac.com .
Which hose goes where on my 2000 pontiac sunfire heater core...
are you installing the correct thermostat the right in the head or block
3 thermostats indicate incorrect fitment method
heater hoses run either way as the water is pushed through the heater core by the pump
Apr 21, 2017 | Cars & Trucks
Sony bravia clicking on and off
There is short circuted component/s in the circuit baord. The set need a through checkup.
Apr 17, 2012 | Sony BRAVIA KDL-40S2010 40 in. LCD...
I've purched the Olympus digital recorder VN-100 VN-2000 a few years ago. I've never really used it. But i recently need to..and for some reason it cant record. Everytime I push the REC button ,the red...
take out the batteries , push the reset button, then put batteries back and try again.
If still not working properly , then it probably should go back to Olympus, if you bought it a few years ago , its probably out of warranty.
You can buy a newer model like the vn-6200-pc , which has way more memory and more features for much much less then it will cost to repair the vn-100 or vn-2000 , f
Dec 25, 2010 | Olympus VN-1000 Digital Voice Recorder
Cant find the thermastat in the radiator
U really can't find it there! It suppose to be in the engine! Follow the UPPER radiator HOSE from the radiator to the engine, there would be a CAP w/ 2 or bolts holding the cap, open it and u could see the missing"THERMASTAT VALAVE"!
Nice to help somebody!
Nov 20, 2010 | 1994 Mazda MX-6
I have a mhu45ng mr heater. When i turn it on nothing happens. It has 120v power and 24v power. The light on the circut board does not come on at all. The gas is on the thermastat is on and the power is...
check the fuse, I believe it is a 3 Amp , there is also a safety switch, when you remove the panel it is on the top you can push it in and the light should light after a few seconds. Hope this helped Tim
Oct 16, 2010 | Mr. Heater MHU45LP
I hooked up a Jacuzzi bathtub and pump won't stay on
I bought a new house and I have a jacuzzi bathtube . and all the sudden stopped working .. where or how I can locate the pumpe ? the only thing I see is the button to turn it on or off and now it does'nt go on ?!! I checked the circute praker and everything seems okay to me.... help please.
Mar 08, 2009 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
No dial tone when the talk button is pushed
the circut inside is acting up and will need repair, this can happen whenthe batterys are low in the phones and the base does not detect them , also the detect circut coud be bad , and or the automatic pick up circut for the answering machine
Oct 15, 2008 | Uniden 5.8GHz Expandable Cordless Phone...
Cruise control on 99 taurus
check your on and off button at the steering wheel.
use a multi-meter set in the ohm postion and see if there is conectivity as you push each button. you will have to take the button off the steering wheel but it will take
just a few minites. while your at it you can check the right side also.
the set-resume-coast.
Jun 15, 2008 | 1999 Ford Taurus
Amana PTH123B25AJ Heat Pump Air Conditioner Logo
147 people viewed this question
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
