HP Pavilion dv1000 Notebook Logo
Posted on Jan 13, 2009
Xp home edition no audio for multimedia
Recently computer crashed, reinstalled xp home edition,,,no have no audio files,,comes up with error code 28, stating that reinstalling deletes audio/multimedia files.
how can fix without having to pay?, what driver tool is required and how to access it please,and thanks,,,,,mike.
  • DEKR
    DEKR May 11, 2010
    are you trying to update the drivers or to reinstall the program
Anonymous
Level 1:
Problem Solver:
  • Contributor 23 Answers
  • Posted on Jan 13, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
23
Questions
Helped
5372
Points
50
Download a tool called driver max its free just type it in Google it will find your driver for you ...but you do have to put in emailaddy and things to use it ..Hope this Helps
No audio output after reinstalling windows xp sp2
Without knowing ur brand of computer i would have to assume that u did a clean install. Go to the manufacturer's website and download the drivers for ur brand of computer. Once u install all of the basic drivers, everything should be as good as new.
2helpful
Code 28, and go into device manager and multimedia audio controller has yellow ! mark and its under other devices, i am running windows xp, any suggestions?
Hi Friend,
Please follow the below steps,
Step 1: Go to Deice Manager
Step 2: Rightclick on the which prompts Code 28 Error and click on UPDATE
Step 3: It will run the Update Wizard and it will install the Latest Driver for the device and it will stop the error code 28
Regards,
Aysaam
My computer says code 28 I do not have any driver installed for multimedia audio controller i have no sound and my cd rom does not get reconized
For Code errors refer to microsoft site: http://support.microsoft.com/kb/125174
The drivers for this device are not installed (Code 28).
To reinstall the drivers for this device, click Reinstall Driver
Procedure
Step 1
Click on "Start."
Step 2
On the "Start" menu, click on "Control Panel."
Step 3
In the "Control Panel" folder, click on "Performance and Maintenance."
Step 4
Click on the "System" folder in the "Performance and Maintenance" folder.
Step 5
Click on the tab titled "Hardware."
Step 6
Click on the box that says "Device Manager."
Step 7
Click on "Sound, Video, and Game Controllers."
Step 8
Right-click on the device that prompts Windows XP to display Code 28 (it should be Windows Sound System Compatible Driver, also called the WDM driver). A drop-down menu will appear.
Step 9
Click on "Update" and an Update Wizard will guide you through the installation of a new device driver, which should stop Code 28 from appearing on Windows XP.
Hope this help
Running Windows XP Home Edition Error code
The diags code was a failed response from the floppy drive. Most system didn't ship with one.
Boot to the XP CD, go to recovery console, run bootcfg /rebuild
http://support.microsoft.com/kb/330184
Lost strings32.dll can't reload programme
Try to download the file from here and use it in your computer :
http://www.dlldll.com/downdll/6250.html
Hope that solve the problem
have a nice day
Please rate my answer
Multimedia controller problem
Error code 28 indicates that the driver for multimedia controller is not installed or corrupted. Use the driver cd provided by your computer manufacturer and install the audio driver.
Revert back for any clarifications
XP Home Edition crashes while in standby - blue screen error
Sounds like a bad file . I would consider reinstalling windows. When it starts up, for a new install, it will find your existing OS and ask it you want it repaired, say yes then it wil repair it and leave al you data as is.
Windows xp home edition reinstall
If you use his disk, that will be better, because if it is original HP disk, it should install all original drivers at all, however this may delete all files on the computer depending on the type of installation you do.
Installing an older version of XP home does not make a big difference , as windows will update the system using automatic updates. What must be done, is ensuring that all proper drivers are installed.
Check device manager, in control panel/system, and see if all devices are installed with proper drivers.
AMD SEMPRON COMPUTER WITH WINDOWS XP HOME EDITION USED TO PLAY SOUNDS BUT NOW KEEP GETTING AN ERROR 39 IN ALL AUDIO SETTINGS
Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39)Recommended resolution
Reasons for this error include a driver that is not present; a binary file that is corrupted; a file I/O problem, or a driver that references an entry point in another binary file that could not be loaded.
Uninstall the driver, and then click Scan for hardware changes to reinstall or upgrade the driver.
On the General Properties tab of the device, click Troubleshoot to start the Troubleshooting Wizard.
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
