Question about Jensen Vm9214 Car Video Player
Why is my My Jensen VM9214 stuck on camera mode an cant change it an wont play cds or dvds
Not sure if it was wired wrong! Didnt know where the white/green wire hooked up to. an the orange wire as well
SOURCE: Jensen VM9132 07' model
At audiovox.com has some upgrade files for the jensen vm9312 that is supposed to fix this problem. First you have to find the vm9312 and then click on software updates. Audiovox makes Jensen products i believe.
Posted on Jun 26, 2007
Shuttle83
  • 1139 Answers
SOURCE: Brake wire for Jensen VM9311ts
You first have to figure out which one of these wires goes to ground potential when the brake is engaged. Get a digital multimeter set it to read resistance (turn the dial to the omega symbol)and then connect one end to ground of the car try the outer ring of the 12 cigarette lighter and the other using the tip to pierce the insulation of one of the wires, then press the parking brake. The meter with the brake not pressed should have ---- when the break is pressed the meter should read 0000 or some value less then 1.000 ohm. The wire that goes to ground when the brake is pressed is the parking break wire and attach your DVD player brake wire to that. My money is on the solid green wire.
Posted on Sep 21, 2007
  • 4102 Answers
SOURCE: wire diagram i think
pink wire if its to go to ground then any metal is ground or negative not live in other words they say the handbrake so you cant use it whilst driving so any metal should do for this ok.
Are you wiring it to amp or not?
Also the mute only wires into say phone cradle or something that would mute the stereo say if you had phone in craddle this would mute the sound so you could here the call. so not needed unless you have phone craddle.
If the two lives are wired in and the ground black when you earth the pink then it should switch on let me know if this happens.
Auto ant is for the arial on car if this goes up and down on motor if not then its not needed
Ill check on dimmer/illumination ok but bare with me for couple of hours just popping out but will get back to you then ok
Posted on Apr 21, 2008
j_del
  • 1586 Answers
SOURCE: JENSEN VM9311TS DO I HAVE TO HOOK THE BRAKE WIRE UP AT ALL?
There isn't any code that I know of. Most DVD head units have one extra wire in their wiring harnesses, compared to a standard CD head unit. On mine, it's a peach-colored wire, and is the activation wire for the DVD feature. During the installation, the instructions call for this wire to be tapped into the emergency brake indicator light wire. The reason is this:
The e-brake indicator light is what is called a "ground complete" circuit. That means that the bulb always has power applied, but when you pull the brake, that puts a ground to the wire and completes the circuit, allowing it to illuminate. The head unit sees this ground, and activates the DVD player.
In my Jensen unit, I simply ran this wire to a ground (I used a screw near the fuse box), and I put a switch on the wire, so I could break the ground contact at will. Jensen calls for a procedure to activate DVD playback. In their instructions, they tell you to select DVD from the option menu, and when the "lawyer screen" comes up (the one warning you to park before you watch a movie), you release the e-brake for 3-5 seconds, and then reapply it. To simulate that with the switch I used, I leave the switch closed (activated), and select DVD. Then I flip the switch "off" for 3-5 seconds, and flip it back "on". This tricks the head unit into thinking I put the e-brake off for a few seconds and then put it back on, and the movie will start. Then I can drive away.
Basically, ground the wire that is used for DVD activation, and put a switch inline on it. Then you can break and reapply the ground in whatever manner is required by the manufacturer of your head unit. If there is no off/on sequence with yours, as there is with mine, simply ground the wire to a screw inside the dashboard and you're done.
Posted on Aug 01, 2008
LVT7857
  • 116 Answers
SOURCE: jensen uv8 and amp hook up
Remote wire from Jensen is blue or blue/white. Use Blu/white if there is one. . RCA's, for subs, use the rear if no subwoofer pre-outs are available. If unit has sub pre-uts, use them as the head ubit (stereo) would have a level that can be raised or lowered thus giving you more control over the input to the sub amp.
Posted on Jan 28, 2009
Wiring problems with Kia stereo
The simple solution would be to go to the source where she bough the system
Dec 11, 2014 | 2001 Kia Spectra
Check your wires, theres a wire for the reverse if your going to use a back up camera, if not do not connect it, you may have had it connected through a speaker wire, if so then thats your issue and once you wire it up right it wont do that any more, had the same issue and thats what fixed it hope this helps
Dec 09, 2012 | Jensen Vm9214 Car Video Player
Jensen vm9214 when i hook my indash to battery only the src button is red it wont turn on t
Did you connect the power, ground and accessory? When doing a bench test for operation, these wires need to be connected.
Sep 30, 2012 | Jensen Vm9214 Car Video Player
Problems playing cds n dvds
hi there
the problem you are probably inquiring is a dirty cd dvd lens this is a simple fix go to local electronics or walmart store and ask for a cd lens cleaning cd this will usually fix the problem and is fairly inexpensive that should take care of your issue
thank you any other questions feel free to post
Aug 20, 2011 | Jensen Vm9214 Car Video Player
Why wont my jensen 9510ts in dash player play dvds but not cds?
Quite often in Jensen units, there is a separate laser for each. Odds are that the CD laser has died. Jensen does not sell replacement parts.
Jul 01, 2011 | Jensen Car Audio & Video
I have a jvc kdavx1 trying to hook up to a 2000 buick reagal need to know how the wires hook up
Please let me know if you have questions, and thanks for using FixYa.
2000 Buick Regal Car Stereo Install Diagram jvc kdavx1
Radio Constant 12V+ Wire: Orange yellow
Radio Ignition Switched 12V+ Wire: Yellow red
Radio Ground Wire: Black/White black
Radio Illumination Wire: Gray/Black orange/white
Left Front Speaker Wire (+): Tan white
Left Front Speaker Wire (-): Gray white/black
Right Front Speaker Wire (+): Light Green gray
Right Front Speaker Wire (-): Dark Green gray/black
Left Rear Speaker Wire (+): Brown green
Left Rear Speaker Wire (-): Yellow green/black
Right Rear Speaker Wire (+): Dark Blue purple
Right Rear Speaker Wire (-): Light Blue purple/black
parking brake: blue light green
For this last wire, access the back of the parking brake to find a switch with a blue wire. Peel some insulation from the wire and wrap the stripped end of a 3 foot piece of 16 or 18 gauge wire around the stripped section. Solder and wrap the connection with electrical tape, route the wire to the jvc, then strip and solder the other end to the pigtail of the head unit.
If you are also installing a camera seeing behind you when backing, you will need to run a wire to the back-up light on the driver side reverse light (light green) wire along with your video cable.
May 30, 2011 | JVC Car Audio & Video
I need to know how to hook up an alpine CDA-9833 stereo into a 1993 dodge dakota without a wiring harness i just want to hook the wires together and i dont know which wire goes to the other all the colors...
Please let me know if you have any questions, and thanks for using FixYa.
1993 Dodge Dakota CDA-9833
Car Radio Battery Constant 12v+ Wire: Red yellow
Car Radio Accessory Switched 12v+ Wire: Red/White red
Car Radio Ground Wire: Black black
Car Stereo Dimmer Wire: Orange (tape this wire off) none
Left Front Speaker Positive Wire (+): Blue/White white
Left Front Speaker Negative Wire (-): Black white/black
Right Front Speaker Positive Wire (+): Purple gray
Right Front Speaker Negative Wire (-): Green gray/black
Left Rear Speaker Positive Wire (+): Black/Yellow green
Left Rear Speaker Negative Wire (-): Gray green/black
Right Rear Speaker Positive Wire (+): Blue/White purple
Right Rear Speaker Negative Wire (-): Blue/Orange purple/black
May 09, 2011 | Alpine Car Audio & Video
Cant take my car stereo off mp3 mode it wont play regular cds
cd decks that can play mp3 format cds should be able to play regular cds. there is not mp3 mode per se.
Oct 28, 2010 | Jensen Car Audio & Video
Have a wiring harness for a CQ-C8100U panasonic CD Player/Head Unit, need a wiring diagram to hook it up to a 2002 Ford Explorer Sport 2 Door
Hello! Since I do not know if your vehicle is equipped with the Standard or Premium System I'll give both sets of wiring...You can identify which system you have by looking at the color of the ground wire...
Red=Standard and Black/Green =Premium
Standard...Constant +12=Green/Yellow...
Switched=Yellow/Black...Ground=Red...
Illumination=Blue/Red...
Standard Speaker
FR + White
FR - Green/Orange
FL + Orange/Green
FL - Light Blue/White
RR + Orange/Red
RR - Black/White
RL + Pink/Green
RL - Pink/Blue
Premium...Only power difference is Ground=Black/Green
Premium Speaker
FR+ White/Red
FR- Brown
FL+ Green
FL- White/Orange
RR+ Purple/White
RR- Blue
RL+ Blue/Black
RL- Yellow
Guru.....saailer
Feb 18, 2010 | Panasonic CQ-C8100U CD Player
Jensen Vm9214 Car Video Player Logo
21 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
