Question about Futaba Toys
How to hook up the futuba r114f receiver with my futuba 6esa transmitter
The rudder and elevator servos work simultaniously
4 Suggested Answers
  • 133 Answers
SOURCE: Throttle is operating servo on
It sounds like you just got it. Be sure your battery is fully charged. Its probably a "Lipo / ?". They put out very high current but drain quickly. On the larger copters, some functions will work partially or stop completely before other functions when they are low on charge. If its RTF out of the box and you just got, give the battery at least a 3 hour charge and try it again. If that doesn't work then, I would take it back for a replacement. If its not new and we need to trouble shoot, I have a lot of writing to look forward to. I fly an AH-64 attack chopper and a dual tower sky crane. I just finished repairing my crashed sky crane this morning. No more plastic for me. Let me know when you are ready. Today or whenever. We will get it done. Also. you will need a volt meter, small diameter Philips screw driver and a logic probe would be easiest to use if we need to check any PC boards. Good luck with the battery! I'm here if not. Roger
Posted on Apr 20, 2011
  • 30 Answers
SOURCE: Have a Spectrum transmitter and
its been a while since my rc days but did all the servos operate properly before you installed them in the plane and are they compatible with the receiver also check that you have compatible channels on tx and rx hope this is helpful and i,m not trying to teach you how to **** eggs lol
bob
Posted on Aug 08, 2011
  • 11800 Answers
SOURCE: I have a Phoenix 60
Your remote control system works by comparing a digital signal received from the remote with the one generated by the sensors on the control motors, Since the motors still move somewhat it means that the remote still sends the signal and the problem is in the receiver: either the voltage is too low to allow the processsor of the receiver to function properly (measure the voltage on the battery with the receiver working) or the receiver itself has failed - measure the output on the motors to confirm that with a command present (move the stick while measuring).
Posted on Sep 12, 2011
Have trex 450 v2 , with hobby wing ESC , two rudder servo burn up under two different transmit
have you got a digital or analogue servo in the tail. You have to select what type you are using on the gyro. If you use an analogue one and switch the gyro to digital, that will fry the servo for sure, iv'e burnt a hole in a servo case before. ( slap own face )
Jan 03, 2014 | RC Remote Control Rc Helicopter
Have a Spectrum transmitter and AR6000 receiver. Cannot bind in a plane. Motor will run; but neither rudder nor elevater will work. Tried 2 receivers.
bob
Aug 08, 2011 | Spektrum Toys
Esc won't respond to remote on my e-max
Hi
the ESC does not respond to the transmitter. The receiver responds to the transmitter. If the receiver channels are working (swap the steering servo between the two slots). If OK then the ESC is bad if not OK then the receiver is bad.
Jun 05, 2010 | Traxxas E-maxx Evx-2 Monster Truck
When i start my tmaxx it tries to take off by itself wide open i cant stop it just keeps going
Hi
Assuming the transmitter is still set correctly then the problem is either your receiver is defective or your throttle servo is defective and/or both. Don't start the engine but switch the servo wires. If the switched servo now doesn't work then your receiver is bad, if it does work then the other servo is bad. Good luck
May 03, 2010 | Traxxas T Maxx 3.3 Monster Truck
It appears the steering locked up. What do I do?
Make sure that no debris (stones, sticks, etc.) have gotten jammed in tie rods or steering servo. Check to see if servo is trying to move, you should be able to hear it when you turn the wheel on the transmitter. If the servo is not working at all, it could be faulty, came disconnected at the receiver, or receiver pack has too low of voltage. If the servo is trying to turn, check the servo saver to make sure it has not loosened or has been damaged.
Jan 05, 2010 | Traxxas Rc Revo Nitro Monster Truck
Remote control plane not responding to transmitter.
I do not have a solution for this problem, but I have exactly the same problem! Is it a common problem for these airplanes?
Jan 01, 2010 | Sport & Outdoor - Others
How do you change the throttle servo on a revo 3.3
Disconnect the servo at the receiver, remove the servo horn and linkage from the servo. Remove the four screws that hold the servo to the chassis. Replace with new servo, plug new servo into receiver and turn on transmitter and receiver. With transmitter and receiver on reattach servo horn and linkage. This will make sure that the servo is centered at neutral throttle.
Sep 25, 2009 | Traxxas Rc Revo Nitro Monster Truck
Can't get new transmitter working on remote control car?
your receiver is old 89-92 and will not work properly with your newer transmitter. you need a R122JE receiver.
Sep 09, 2009 | Futaba Two Servo Trays For Standard Rc...
Crashed blade 400 repaired it unsure of servo settings helicopter tilts forward and tends to spin around
Try setting gain on Gyro (use small plastic screwdriver) to a straight up and down position.
Set Gyro setting in Transmitter to 75%. NOTE: before turning on helicopter, be sure to center all adjustments on transmitter
Side switch on GYRO to DS and make sure the servo is moving in correct direction. If not. reverse direction with switch on side of Gyro. You may need to reverse the controller of Rudder in settings on transmitter.
This worked for me on my Blade and using the same Gyro on a self build 450 heli.
Helimangler
Apr 20, 2009 | E-Flite Blade 400 3D RTF Electric Mini...
Toys Logo
29 people viewed this question
Top Futaba Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Futaba Toy Expert? Answer questions, earn points and help others
