Question about Tunturi T30 Treadmill
J 440 treadmill belt moved all the way to left
I noticed the belt was to the left, so I used the wrench and turned counterclockwise on the left and clockwise on the right. This has always worked in the past. The belt moved all the way to the left and started to groove the plastic cover!!!! HELP. I turned it off immediately.
    Problem Solver:
  • 9 Answers
Clockwise on the left tightens, tighter forces away. Counterclockwise on the left would allow it to come to the left.
Posted on Oct 22, 2009
Belt off of pro form 700 cardio cross trainer
Dear Sir: Hello , I hope everything is fine.
Please do the following: o 1 Remove the key from the machine and unplug the unit for safety purposes. o 2 Adjust the rear roller adjustment bolts using an allen wrench. The right bolt should be turned one-fourth turn clockwise and the left bolt should be turned one-fourth turn counterclockwise. o 3 Place the key back into the unit and plug it back into its power source. o 4 Run the Proform treadmill for five minutes to make sure that the walking belt has fully recentered itself. o 5 Repeat these steps if necessary.
If the Belt Slip when in use: o 1 Unplug the unit and remove the key card. o 2 Tighten the walking belt by turning both rear adjustment bolts clockwise using an Allen wrench. o 3 Replug the unit and reinsert the key card.
Thank you in advance, sincerely. Blessing.
E.CUADRA Managua, Nicaragua. c.a.
Sep 25, 2011 | Exercise & Fitness
How do I adjust the belt on my Sportcraft Mode TX50RC treadmill
Step 1Confirm that the treadmill is plugged into a grounded, 120-volt electrical outlet. Examine the status of the power switch, located next to the treadmill's power cord. Set the switch to the "ON" position. Step 2Insert the red key into the slot set into the front of the console. Press and hold the button labeled "+" until the displayed speed reaches 5.0 mph. ad_order_1 = (typeof ad_order_1 === "undefined") ? "1" : ad_order_1; ad_client = "ca-livestrong_html"; num_ads = "1"; type = "text"; channels = "art_sub_top_Treadmill_Machines,article_top_fitness"; class_name = "adsense_afc"; print_google_ad(ad_order_1, num_ads, type, channels, ad_client , class_name ); Step 3Kneel down next to the rear panel of the treadmill's base. Locate the two bolts set into the rear panel. Examine the treadmill belt as it moves and determine which direction you wish to shift it. Step 4Select the appropriate bolt for your desired adjustments To shift the belt to the left, use the right bolt; to shift the belt to the right, use the left bolt. Step 5Insert one end of the Allen wrench into the top of your selected bolt. Turn the bolt a quarter turn clockwise. Examine the treadmill belt and determine if it is in the proper position. If necessary, make up to two additional quarter turn adjustments; if the belt is still out of alignment, move to the other bolt and give it a quarter turn counterclockwise up to a maximum of three times. Alternate between bolts as necessary. For make it easy to you have added video. Just watch it.
Jun 13, 2011 | Exercise & Fitness
Belt on treadmill is moving towards the right and bunching up
you need to adjust the travel of belt. to do this you need a allen wrench that came with it. if you have it run treadmill at slow speed,go to the rear right at the right end cap there is a hole, use the allen wrench and unscrew slowly while watching the belt until returns to the middle. if it slips when walking go back to rear and adjust by screwing in one turn on each side until belt wont slip.
Feb 09, 2011 | Proform 380 Treadmill Walking Belt
My belt is over to one side to much is there and easy way to get it back in the middle
If the walking belt has shifted to the left, first remove the key and UNPLUG THE POWER CORD. Using the allen wrench, turn the left rear roller adjustment bolt clockwise, and the right bolt counterclockwise, 1/4 of a turn each. Be careful not to overtighten the walking belt. Plug in the power cord, insert the key and run the treadmill for a few minutes. Repeat until the walking belt is centered. If the walking belt has shifted to the right, first remove the key and UNPLUG THE POWER CORD. Using the allen wrench, turn the left rear roller adjustment bolt counterclockwise, and the right bolt clockwise, 1/4 of a turn each. Be careful not to overtighten the walking belt. Plug in the power cord, insert the key and run the treadmill for a few minutes. Repeat until the walking belt is centered.
Jul 16, 2010 | Proform Quick Burn Pro Treadmill with 12...
Belt slipping and moving
Here is a basic procedure that will work for the majority of treadmills out in the market:
If the walking belt has shifted to the left, first remove the key and UNPLUG THE POWER CORD. Using the allen wrench, turn the left rear roller adjustment bolt clockwise, and the right bolt counterclockwise, 1/4 of a turn each. Be careful not to overtighten the walking belt. Plug in the power cord, insert the key and run the treadmill for a few minutes. Repeat until the walking belt is centred. b. If the walking belt has shifted to the right, first remove the key and UNPLUG THE POWER CORD. Using the allen wrench, turn the left rear roller adjustment bolt counterclockwise, and the right bolt clockwise, 1/4 of a turn each. Be careful not to overtighten the walking belt. Plug in the power cord, insert the key and run the treadmill
Jul 15, 2010 | Treadmill Doctor Weslo Cadence Dx10...
Life fitness 95ti belt moving to one side any way of correcting
If the walking belt has shifted to the left, use the Allen wrench to turn the left rear roller bolt clockwise 1/2 of a turn; if the walking belt has shifted to the right, turn the left rear roller bolt counterclockwise 1/2 of a turn. Be careful not to overtighten the walking belt. Plug in the power cord, insert the key, and run the treadmill for a few minutes. Repeat until the walking belt is centred.
Jun 09, 2010 | Life Fitness 95Ti Treadmill 95 Ti
Belt is off alignment
If the walking belt is off-center, first remove the key and UNPLUG THE POWER CORD. If the walking belt has shifted to the left, use the allen wrench to turn the left rear roller bolt clockwise 1/2 of a turn; if the walking belt has shifted to the right, turn the bolt counterclockwise 1/2 of a turn. Be careful not to over tighten the walking belt. Then, plug in the power cord, insert the key, and run the treadmill for a few minutes. Repeat until the walking belt is centered.
May 31, 2010 | Proform 730 Folding Treadmill Model...
I have a Proform 380 Treadmill. When the treadmill is on the belt rubs on the left side.How do I center the belt?
If the walking belt is off-center, first remove the key and UNPLUG THE POWER CORD. If the walking belt has shifted to the left, use the allen wrench to turn the left rear roller bolt clockwise 1/2 of a turn; if the walking belt has shifted to the right, turn the bolt counterclockwise 1/2 of a turn. Be careful not to overtighten the walking belt. Plug in the power cord, insert the key and run the treadmill for a few minutes. Repeat until the walking belt is centered.
May 24, 2010 | Proform 380 CS Treadmill !
My treadmill walking belt has moved to the right and slips.
PROBLEM: The walking belt is off-center or slips when walked on SOLUTION: a. If the walking belt has shifted to the left, Start unit @ 1.0 mph using the hex key, turn the left idler roller bolt clockwise 1/2 of a turn to move belt to the right. Be careful not to overtighten the walking belt. If the walking belt has shifted to the right, turn the left idler roller bolt counterclockwise or clock wise 1/2 of a turn depends on the tension that will be on the belt take your time and walk on it to feel the belt underneath you2_bing.gif Repeat until the walking belt is centered.
Feb 28, 2010 | Nordic Track NordicTrack Treadmill, A2550
Walking belt on image 10.0 tread mill slips, purchased it used, can see where it has rubbed to the left. How to adjust it?
There are adjustment screws on the very back of the deck… one on each side.
1. You will need a hex wrench that came with your unit (look on the side of the deck) sometimes it is attached to a bracket or look in your plastic bag with your instruction manual. If you cannot find it, do not worry, it is a common “hex” size. Purchase a "multi size” hex wrench at the hardware store"
2. Locate the screws on the back of the treadmill on the deck "where you walk" You will see one on each side.
3. With your wrench in hand, start your treadmill on a low speed and take note of which side the belt is "creeping" to the left or right.
4. If the belt is not centered and over to the left side take your tool and adjust the screw on the left side slowly a few turns until you notice the belt creeping back to the center....usually it does not take much adjustment.
5. Once you start getting the hang of what adjusting each particular screw does to the belt....You will be a pro in no time.
6. Once the belt centered, turn off the treadmill and unplug it. Take your hand and slide it under the belt about midway. The belt should feel "snug" against the deck. If it feels too loose...use your new found adjusting skills to tighten the belt adjusting each side a few turns…unplug…checking for tightness until you feel good about it.
7. Last suggestion: Some treadmills decks need lube to help it run smooth. Without it your deck will get worn and the belt will "stick" to the deck....not good. Buy the lube a sporting goods store or at a place that sells treadmills. If you cannot find any buy some spray on graphite.
Feb 25, 2010 | Exercise & Fitness
Tunturi T30 Treadmill Logo
169 people viewed this question
Top Tunturi Exercise & Fitness Experts
Shehu Pro
Shehu Pro
gbob59
Are you a Tunturi Exercise and Fitnes Expert? Answer questions, earn points and help others
