Question about Garmin GPSMAP 172C GPS Receiver
My 172c will not pick up satellites the time and date is wrong
2 Suggested Answers
SOURCE: My Garmin e-trex will not
It righted itself when I switched it on again outside and 'calibrated' it by moving around with it in my hand. Obviously it is better not to leave the batteries out for so long, overnight, while recharging them.
Once before I had to get back to the factory settings and start again by pressing buttons consecutively quickly but I couldn't do that again. I had forgotten what I did and hadn't written it down. Any ideas?!
Cheers
Posted on Jul 21, 2008
How do you set time/date?
Hi, do you have the MiniTuner module in the radio? You need that in, and the antenna connected facing the SW horizon. Turn on to SATellite. Adjust antenna so that you can hear Channel 1 clearly. After you hear channel 1, the satellite will send a time signal. Then go to MENU, select Adjust time and pick your time zone and if you are on Daylight Savings time. Then, menu to exit out. Your satellite signal will keep the time updated when in Satellite mode.
I don't know if that will also set the regular clock too, or just only the time while in satellite mode. Let me know how you do with it.
Aug 19, 2014 | Timex TMX1 Satellite Radio Receiver
Garmin 76cs will not aquire satellites after powering up
plug it into a computer and update the firmware. my TomTom has done that a couple of times.
Aug 29, 2012 | Garmin GPSMAP 76CS GPS Receiver
My date and time is wrong on my gpsmap 60csx. how can i adjust it? I just did an update
The 60CS does not have a way to set the date and time manually- it finds both from the satellites as soon as it receives them.
The time zone can be set in:
- Main menu
- Marine setup
- Time Setup then TimeZone
Jul 10, 2011 | Garmin GPSMAP 60CSx GPS Receiver
Garmin GPSMAP 172C - cannot find satellites (WAAS)?
WAAS is a seperate service from GPS. It provides GPS corrections so if you can not get WAAS there is no big problems. you unit just wont be as accurate as normal. WAAS only is for North America and EGNOS for Europe. You may want to turn WAAS off for now. I suggest trying a update for the unit. You will need a memory card and Garmin USB programmer. Then just go to garmins site to get the latest update. If you need a USB programmer feel free to Contact GPSCity.ca or GPSCity.com. They are the leading experts in Garmin GPS.
Jul 12, 2010 | Garmin GPSMAP 172C GPS Receiver
The date that my Nuvi operates on is incorrect
Nuvi 200 - trying to reset the date using the method suggested by Kevin A (and in a cellar) and after two hours the Nuvi was still "locating satellites". Am I doing something wrong?!
My main problem, however, is that having loaded a copy of the latest European maps onto the card used in the device, when going through the "where to" routine I am asked to enter State/Province. Living in the UK this is a little difficult as there is no answer I can give that the unit will recognise! Any ideas?
May 01, 2010 | Garmin nuvi 750 GPS Receiver
I am looking for a driver for a SHARP "LL-172C-B"
There really isn't any "Drivers" as such for the monitor, Windows should pick it up, as the Monitor "Talks" to the PC and "Tells" it what it "Is". You simply need to connect it up, reboot and use it.
Mar 11, 2010 | Sharp LL 172A-B 17" LCD Monitor
305 Not Picking up satellite signal
Visit the link below to update the software,
Here
Serial to usb connector needed like this Here
Should be good after that.
Regards.
Apr 16, 2009 | Garmin Forerunner 305 GPS Receiver
Garmin GPSMAP 60CS displays wrong date
mou exoun dvsei ena gps to opoio mesa einai ola sbismena.
prospathw na tou perasw ena ellhniko xarth alla den mporw...
xreiazomai help.......
Feb 03, 2009 | Garmin GPSMAP 60CS GPS Receiver
No satelite acquisition for garmin 172c
you need to go outside in an open area with no trees around and turn the garmin on untill it receives a sat connection it can take several minutes for it to find it
Dec 04, 2008 | Garmin GPSMAP 172C GPS Receiver
Wrong date and time
Your GPS receive its date and time from satellites. Take the unit outside and acquire a satellite fix in order to update your time and date. You can set the time zone and time display (12hr, 24hr, UTC) under the unit setting.
Jan 12, 2008 | Garmin nuvi 350 GPS Receiver
Garmin GPSMAP 172C GPS Receiver Logo
140 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
