Question about Bose MediaMate Computer Speakers
Bose mediamate speaker high pitch noise
The accessory speaker makes high pitched noise when plugged into the powered speaker. Can you suggest a solution?
  • 135 Answers
SOURCE: loud whining noise
yes,,this is due to electromagnetic interference...
try to keep the accessory speaker as far as possible fro the powerspeaker..this would serve better
Posted on Jul 06, 2008
SOURCE: Bose Companion II Computer Speaker: The AC power adapter burnt
My puppy chewed through the cord for my a/c adapter, I just took the speakers into Circuit City, and they found me a workable replacement (the replacement isn't BOSE, but it works just fine).  Hope that helps!
Posted on May 07, 2009
  • 8404 Answers
SOURCE: There is a humming noise when I plug my computer
Is there a separate power supply for your speakers? If yes, turn the plug over in the outlet.
Does it buzzz all the time or only when you are plugging it in? Is there a flourescent desk light close by? Flourescent lights can interfere with your speaker system.
Are you able to independently determine if the electric outlet your devices are plugged into are properly wired?
Do not remove the outlet from the wall. If you have a volt ohm meter, you can do this test.
Inside the box in the wall, there are three wires, a black (hot), a white (neutral) and a green (ground). Ultimately, the green and the white are attached to a common ground back at your power box by virtue that the service entrance is bonded ... don't try to reconcile this.
You can look at the outlet and see there are two slots and a round hole (times 2). Notice that there is a big slot and a small slot. The hot wire is attached to the small slot and the neutral wire is attached to the big slot. The green wire is attached to the round hole or ground.
With a volt/ohm meter (available at your hardware store for about $10.00) with the setting for 250 volts AC, insert one probe into the small slot and the other probe into the large slot. You should get a reading of 125 volts more or less.
Remove the probe from the large slot (on the left side if the ground is at the bottom) and insert it into the ground. If you have a reading similar to your first reading, your plug is properly wired. If you get no reading between Hot and Ground it is not properly wired, you probably have a condition knows as reverse polarity. Check the other side, i.e. measure between the large slot and ground, if you have voltage, you definitely have reverse polarity. If you are handy, you can fix this yourself, if you are unsure, get it fixed by a pro.
If you do it yourself, remember the dark wire goes to the dark screw (brass). The light wire goes to the light colored screw (zinc) and the green wirre goes to the green screw.
There is the possibility that your ground is not actually connected. If your ground is not connected, you will not get a reading between black and ground. You can check this by setting your meter to Ohms. As I said, ultimately, green and white are common back at your power panel. Cross the probes together and watch your meter, it should show SHORT. Insert one probe into the ground part of your plug and the other probe in the big slot. You should read SHORT.
I tell you all this because buzzing can be traced to bad electric. Please test yours and be careful.
Please let me know what happens and if you have more question or comment - please post a comment to this question.
I hope this helps you .
Thanks for using FixYa.com
Please vote
thanks
a
Posted on Dec 05, 2009
SOURCE: I have the Bose companions 3 series 2 speakers feedback problem
Another possibility: make sure both speakers are at least ten inches away from any router.
Posted on Feb 17, 2011
bronk50
  • 27725 Answers
SOURCE: need a power adapter forr
you could get this on Ebay if you dont have an account you will need to create one
Add Email adress
Add Bank Acc
Add Credit Card
also add your postal adress
also add a paypal account
when you get to the paypal login page at the bottom you will see new to paypal sign up tab
paypal to create an account
paypal registration password ,bank card /credit card,phone numbers home/mobile ,email adress and a postal adress
be very specific when you search type in the coorect details i can supply a link to an adapter but not sure if its the one you need
http://cgi.ebay.com.au/New-12V-AC-AC-Power-Adapter-Supply-BOSE-PS71-DCS91-/270684179832?pt=LH_DefaultDomain_0&hash=item3f0608cd78
AU $12.60 +AU $27.16
in the USA
hope this helps
Posted on Apr 01, 2011
Funai tv. When plugged in, makes ear piercing high pitched buzz that goes away when unplugged. Will not respond to buttons. No picture or power. Already replaced power board. What now??
TV not turning on; making high-pitched sounds - Tom's ...
www.tomshardware.com > Forum > Graphics Cards
Tom's Hardware Guide
Nov 30, 2013 - 7 posts - ‎2 authors
Both of them are refusing to turn on, and make high-pitched sounds when plugged in and unplugged. More about : turning making high pitched ...Missing: ear ‎piercing
Top 136 Complaints and Reviews about Funai TV ' Page 2
www.consumeraffairs.com > Electronics > Televisions
Rating: 1.1 - ‎65 votes
We unplugged the unit and waited 15 - 20 seconds and plugged the unit back in, and it wouldn't ... He heard a loud high-pitched whining which led him to TV in my daughter's room. ... It only makes a humming sound now, no pictures at all.Missing: ear ‎piercing
HELP! what is that high pitched noise when tv is on? - TV - Audio ...
www.tomsguide.com/forum/60895-6-help-high-pitched-noise
Jan 25, 2013 - 3 posts - ‎2 authors
Hello, I hear this constant high pitched noise, almost like ringing, but even ... pitch
Jan 21, 2016 | Funai Televison & Video
Bose QC15 makes a high pitch noise
Go to support on the Bose website. Enter your model number and click on trouble-shooting. They should have your solution there.
murf427
Aug 02, 2012 | Bose Radio Communications
High pitch noise when on or off
Some ferrite cores of power supply regulator might poise this problem. Check for it.
Jul 07, 2012 | Samsung P2370HD 23 in. TV
My Dell inspiron 13r laptop is emitting a very high pitched noise when it is on. I have tried reinstalling my audio drives but nothing seems to be working... Please help
If it is a relatively quiet, high pitched noise, it may not even be from your speakers. I've experienced a high pitched noise whenever i plug in my AC adapter to my PSP, so there is a chance it might be power related.
Mar 25, 2011 | Hi-Capacity Equivalent of DELL INSPIRON...
Sep 16, 2009 | Bose Companion 3 Computer Speakers
Wont turn on and high pitch noise
Looks like the printers internal electrical components have gone. if there is a tranformer in your printer then that is making that noise. or else even the motors might also be gone.
my strong suggestion take it to any authorized service personnel
Apr 20, 2009 | Computers & Internet
Loud whining noise
Jul 04, 2008 | Bose MediaMate Computer Speakers
Bose MediaMate Computer Speakers Logo
23 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
