White rodgers 50e47-843 ignition
Everything seems ok as far as the green steady light,but there are no power at the igniter leads
  • 47 Answers
SOURCE: gas heater won't ignite
I agree. Either the pilot flame is dirty and is not making good contact to heat up the bi metal strip on the pilot assembly, or the pilot assembly is defective. 90% of the time if you clean the pilot orfice and the pilot burner it will take care of the problem
Posted on Nov 24, 2009
  • 17 Answers
SOURCE: heater is on firing up- everything seems ok but
the igniter has to have proper omhos to open gas valve.
recommend replacing igniter. be careful not to touch new igniter with bare hands. oils in the skin of your hands will cause the igniter to get too hot and burn out quick
Posted on Dec 10, 2009
liteswink
  • 99 Answers
SOURCE: Ignition Module Troubleshooting White Rodgers
This is OEM special part you need to contact Goodman Manufacturing. Website Phone 866.304.0137
Posted on Jul 07, 2010
  • 185 Answers
SOURCE: Gas heater, everything seems ok, fan starts,
It could be a number of problems........ I will give you the most common ones. Did the gas get shut off..are you getting gas to the Gas Valve..... Is the gas valve getting 24 volts right at the end of the cycle of the igniter? If not then the ignition control board could be bad.. If the gas valve is getting gas and 24 volts then the gas valve could be bad. The manifold gas pressure may be to low... The gas burner itself may be dirty and not letting the gas to hit the Hot surface ignitor. Or the position of the ignitor may be to far or to close to the burner..... So you see if could be any one of these or a combination of them... Hope this help on your problem.
As always, if you are in doubt about what to do, the best advice anyone should give you is to call a licensed electrician Or HVAC tech to advise what work is needed.
Before you do any work yourself,
on electrical circuits, equipment or appliances,
always use a test meter to ensure the circuit is, in fact, de-energized.
IF YOU ARE NOT ALREADY SURE YOU CAN DO THIS JOB
SAFELY AND COMPETENTLY
REFER THIS WORK TO QUALIFIED PROFESSIONALS.
Posted on Feb 16, 2011
kel1guy2002
  • 3740 Answers
SOURCE: I have a precision temp
Hi and welcome to FixYa, I am Kelly.
Here is the Service Manual:
http://www.precisiontemp.com/Manuals/RV500_Service_Manual.pdf
Before you troubleshoot inside the unit do the steps in para 3.3 page 7 of the manual to make sure you have good power.
There is a testing procedure on page 39 that should cover everything stated below.
Do the flow-meter check para 4.2 page 12.
Do the thermistor tests para 4.5 page 12. (See figure 5 page 18 for resitance readings)
Page 19 will show you test points on the control board.
DO NOT do the auto-calibration procedure para 4-15 page 38 until you know you have corrected the problem.
This should help you resolve the problem.
From here I think this is related to the flow-meter as you have no other failures. If there is debris in the flow-meter assembly and it stops turning / measuring flow rate due to debris; you will have the symptom you describe.
Thanks for choosing FixYa,
Kelly
Posted on Jul 11, 2011
Need the output wiring diagram for a AUDIOVOX 93-im-ETX radio
Wiring diagram for Audiovox 93-IM-ETX
Figured it out by taking radio lid off and following the leads:
Black/white--ground (-)
Green/white--battery (+, that is, always on)
Orange/white--ignition/ACC switched power
White--left front +
Red--Left rear +
Blue--right front +
Yellow--right rear +
Light Green--negative for front speakers
Purple-negative for rear speakers
Sep 28, 2010 | Audiovox Car Audio & Video
What are the stereo color codes for a 2002 jaguar x type 2.5.. hooking up amp with the factory deck and dont wanna buy the iso harness thaNKS
| ITEM | WIRE COLOR |POL| WIRE LOCATION |
| 12V|red/grn & red/org |+ |ignition harness |
| STARTER|gry/blk or lt. blue |+ |ignition harness |
| IGNITION|green/black |+ |ignition harness |
| SECOND IGNITION|pink/white |+ |ignition harness |
| THIRD IGNITION|red/wht (key sense)|+ |ignition harness |
| ACCESSORY|yellow |+ |ignition harness |
| SECOND ACCESSORY|pink/yellow |+ |ignition harness |
| POWER LOCK|black/blue |- |DDM *1 |
| POWER UNLOCK|black/white *2 |- |DDM *1 |
| LOCK MOTOR|yellow/black | |DDM *1 |
| UNLOCK MOTOR|white/purple | |DDM *1 |
| DISARM DEFEAT|white/green | |pass. kick, harness to rear |
| PARKING LIGHTS +|use neg. wire only | | |
| PARKING LIGHTS -|white/green *3 | |headlight switch |
| HEADLIGHTS|white/green *3 |*3 |headlight switch |
| DOOR TRIGGER|black/white *4 |- |underdash light |
| DOME SUPERVISION|comes on w/unlock | | |
| TRUNK/HATCH PIN|white/black |- |REM *5 |
|TRNK/HTCH RELEASE|black/blue |- |release switch or REM *5 |
| FCTRY ALARM ARM|arms w/ lock | | |
|FCTRY ALRM DISARM|disarms w/ unlock | | |
| TACHOMETER|brown or brn/stripe | |main harness pass. firewall |
| SPEED SENSE| | | |
| BRAKE WIRE|org/yel or org/blu |+ |brake pedal switch |
| HORN TRIGGER|gray/orange |- |FEM *5 |
| WIPERS|red/blk(L),red/grn(H|+ |wiper motor |
| LF WINDOW UP/DN|white - yellow |A |DDM *1 |
| RF WINDOW UP/DN|wht/pur - yel/pur |A |FEM *5 |
| LR WINDOW UP/DN|blu/red - pur/blu |A |REM *5 |
| RR WINDOW UP/DN|blu/orn - pur/wht |A |REM *5 |
| RADIO 12V|orange/black |+ |radio |
| RADIO GROUND|black |- |radio |
| RADIO SWITCH|yellow/green |+ |radio |
Notes:
NOTE: This vehicle is equipped with a passive immobilizer that needs to be bypassed for remote start operation only. Use DEI part number 555U to bypass. *1 The DDM (drivers door module) is located in the center of the drivers door. *2 Requires a double pulse to unlock. *3 Parking lights require a negative trigger with a 1800 ohm resistor in-line to the white/green wire. Using a negative trigger with a 780 ohm resistor in-line to the same white/green wire will turn on the headlights as well as the parking lights. *4 This wire may cause the aftermarket alarm to false when the vehicles electrical system shuts down. Use a relay to isolate it. *5 The FEM (Front Electronic Module) is located in the drivers kick panel. The REM (Rear Electronic Module) is located in the trunk, just above the battery. hope that helps
Sep 27, 2009 | Car Audio & Video
I hav a 95 berrta and im tying to put a head unit
Hello chrisuftring,
Here's a link to the wiring color code for the '95 Chevy Beretta.
You'll need to match the function of each wire from your head unit and the color code for that would be in your manual. Most aftermarket units are somewhat standard as far as power, accessory, ground, and speaker connections are concerned. But the wiring colors may be different for such leads as remote, power antenna, illumination, dimmer, and muting.
An Alpine head unit has the following wiring colors:
Blue - Power Antenna
Blue/White - Remote
Pink/Black - Audio Interrupt (muting)
Orange - Illumination
Red- Switched 12V+
Yellow - Constant 12V+
Black - Ground
Gray - RF Speaker (+)
Gray/Black - RF Speaker (-)
White - LF Speaker (+)
White/Black LF Speaker (-)
Violet - RR Speaker (+)
Violet/Black RR Speaker (-)
Green - LR Speaker (+)
Green/Black - LR Speaker (-)
With this head unit, you would wire Yellow to Orange, Red to Yellow, Black to Black, Orange to Gray, Blue to Pink, Gray to Light Green, Gray/Black to Dark Green, White to Tan, White/Black to Gray, Violet to Dark Blue, Violet/Black to Light Blue, Green to Brown, and Green/Black to Yellow.
Note that there are 2 "yellow" wires in your vehicle color code. You'll have to test them to determine which one is the accessory wire and which one goes to the left rear speaker. Using a 12V "test light" is the simplest. Connect one side of the light to ground. With the ignition ON probe the yellow wires. One of them should light the tester, the other one won't. Verify that the light goes out when the ignition is OFF and your have separated the redundant "yellows". The one that lit the tester is your 12V+ switched wire and the other one goes to the left rear speaker.
Hope this helps.
Sep 11, 2009 | Dual Car Audio & Video
What is the color code for the stereo wires in an 08 land rover l
Battery BROWN/LIGHT GREEN(+)IGNITION SWITCH HARNESS
Ignition 1 WHITE (-) IGNITION SWITCH HARNESS
Accessory 1 WHITE/PINK (-) IGNITION SWITCH HARNESS
Starter 1 WHITE/RED (-) IGNITION SWITCH HARNESS
Tachometer WHITE (-) AT IGNITION COIL
Speed Sense YELLOW/GREEN (AC) AT MODULE UNDER PASSENGER SEAT
Parking Lights ORANGE/RED (-) AT MODULE UNDER PASSENGER SEAT
Brake Lights GREEN/BLUE (+) AT SWITCH ABOVE BRAKE PEDAL
Power Unlock BLACK (-) AT MOTOR IN DRIVERS DOOR
PowerLock BLUE (-) AT MOTOR IN DRIVERS DOOR
All Door Trigger VIOLET/GRAY (-) IN HARNESS TO RIGHT OF STEERING COLUMN
Trunk Trigger VIOLET/YELLOW (-) AT MODULE UNDER PASSENGER SEAT
Hood Trigger VIOLET/WHITE (-) AT MODULE UNDER PASSENGER SEAT
Headlights-Lo BLUE (-) AT MODULE UNDER PASSENGER SEAT
Wipers-Lo PINK/LIGHT GREEN(-) AT MODULE UNDER PASSENGER SEAT
Trnk Release WHITE (-) AT TRUNK RELEASE SWITCH
Battery RED/WHITE (+) RADIO HARNESS
Accesory YELLOW/RED (+) RADIO HARNESS
Ground TAN (-) RADIO HARNESS
Illumination GRAY/BLUE (+) RADIO HARNESS
LF Speaker (+) BLUE/WHITE
LF Speaker (-) TAN/WHITE
RF Speaker (+) RED
RF Speaker (-) TAN/RED
LR Speaker (+) RED/GREEN
LR Speaker (-) TAN/GREEN
RR Speaker (+) BLUE
RR Speaker (-) TAN/BLUE
Radio Security YES
(thats for 07 but shoe to what u need)
Aug 24, 2009 | Alpine Car Audio & Video
I need to know what color the ignition wire is so i can install a kill switch on my 06 F250 Powerstroke
hi, hope this will help.....if it does, could you leave a positive feedback for me please...many thanx..........
PART COLOR LOCATION
12 VOLT CONSTANT BLUE/RED (+) IGNITION SWITCH HARNESS
STARTER BLUE/WHITE (+) IGNITION SWITCH HARNESS
STARTER 2 N/A N/A
IGNITION 1 WHITE/ORANGE (+) IGNITION SWITCH HARNESS
IGNITION 2 N/A N/A
IGNITION 3 N/A N/A
ACCESSORY/HEATER BLOWER 1 BROWN/YELLOW (+) IGN SWITCH HARNESS
ACCESSORY/HEATER BLOWER 2 PURPLE/GREEN (+) IGN SWITCH HARNESS
KEYSENSE BLUE/GRAY (+) IGNITION SWITCH HARNESS
PARKING LIGHTS ( - ) GRAY (-) AT HEADLIGHT SWITCH
PARKING LIGHTS ( + ) PURPLE/WHITE (+) SMART JUNCTION BOX IN PASSENGER KICK PANEL
POWER LOCK BLUE/LIGHT GREEN (-) TYPE (B) IN DRIVERS KICK PANEL
POWER UNLOCK YELLOW/PURPLE (-) TYPE (B) IN DRIVERS KICK PANEL
DOOR TRIGGER VIOLET(+) UNDER DRIVERS SILL IN HARNESS COMING FROM PASS SIDE
DOMELIGHT SUPERVISION GREEN/BLUE (-) HEADLIGHT SWITCH
HORN YELLOW/RED (-) AT STEERING COLUMN HARNESS
TACH BLUE(AC) AT HARNESS NEXT TO BRAKE PEDAL
WAIT TO START LIGHT N/A N/A
BRAKE PURPLE/WHITE (+) AT SWITCH ABOVE BRAKE PEDAL
ANTI-THEFT TRANSPONDER ANTI-THEFT TRANSPONDER @ IGNITION SWITCH TUMBLER
Aug 05, 2009 | Ford Super Duty Cars & Trucks
Wiring diagram to hook-up remote starter on 1996 dodge caravan
Constant 12V+ Red or Pink/Black - Ignition Switch Harness
Starter Yellow - Ignition Switch Harness
Ignition Dark Blue - Ignition Switch Harness
Ignition 2 Black/White - Ignition Switch Harness
Ignition 3 Dark Green/Red - Ignition Switch Harness
Accessory Black/Orange - Ignition Switch Harness
Tach Gray Or Blue/Tan PCM Coil 2.4 Liter - Engine
Neutral Safety Wire Black/White - Power Control Module
Brake Switch White/Tan - Brake Switch
Trunk Pin Tan/Black - 40 Pin Connector at Fuse Panel
Parking Lights Light Green/White (-) - Head Light Switch Harness left of Column
Head Lamp Green/Orange - Light Switch
Factory Disarm White/Dark Green - (665 Ohm) left Connector bottom of Fuse Panel
Door Trigger Brown/White (-) - Lower right Gray Connector at Fuse Panel
Door Lock White/Dark Green - BCM at Fuse Panel
Door Unlock White/Dark Green - White Connector B58 Connector
Horn Wire Black/Red - Steering Column
Windows Up LF=Light Green, RF=Brown/White, LR=Blue, RR=Gray
Windows Down LF=White, RF=Purple/White, LR=Red/White, RR=Dark Green
Your R/S instructions should tell you what goes where.
Thanks for using FixYa - a FixYa rating is appreciated!!
Jan 31, 2009 | Vehicle Parts & Accessories
Need diagram for 2007 escape audiophile
if it is the wiring diagram for the Escape you need, here it is:
12 VOLT CONSTANT Connect to BATTERY ONLY STARTER TAN/LIGHT BLUE (+) IGNITION SWITCH HARNESS STARTER 2 N/A IGNITION 1 LIGHT GREEN/PURPLE (+) IGNITION SWITCH HARNESS IGNITION 2 N/A IGNITION 3 N/A ACCESSORY/HEATER BLOWER 1 BLACK/LIGHT GREEN (+) IGNITION SWITCH HARNESS ACCESSORY/HEATER BLOWER 2 N/A KEYSENSE N/A PARKING LIGHTS ( - ) WHITE/BLACK (-) @ SJB, Connector E, Pin 4, See NOTE *1 PARKING LIGHTS ( + ) BROWN (+) @ SJB, Connector C, Pin 19, See NOTE *1 POWER LOCK PINK/WHITE (1-Wire System) See NOTE *2 @ SJB, Connector D, Pin 22, See NOTE *1 POWER UNLOCK Same wire, See NOTE *2 See DIAGRAMS DOOR TRIGGER PINK (-) @ SJB, Connector C, Pin 28, See NOTE *1 DOMELIGHT SUPERVISION USE DOOR TRIGGER TRUNK RELEASE N/A SLIDING POWER DOOR N/A HORN YELLOW/LIGHT GREEN (-) @ SJB, Connector A, Pin 14, See NOTE *1 TACH NOT RED or WHITE/RED @ IGNITION COIL or FUEL INJECTOR WAIT TO START LIGHT N/A BRAKE LIGHT GREEN (+) @ SWITCH ABOVE BRAKE PEDAL FACTORY ALARM DISARM DARK BLUE/LIGHT GREEN (-) @ SJB, Connector D, Pin 3, See NOTE *1 ANTI-THEFT FORD'S SECURILOCK ANTI-THEFT TRANSPONDER SYSTEM TRANSPONDER @ IGNITION SWITCH TUMBLER EXTRA INFORMATION NOTE *1 The SJB (Smart Junction Block) is the FUSE/RELAY BOX on the PASSENGER SIDE of the CENTER CONSOLE. NOTE *2 This vehicle uses a 1-Wire Door Locking System, LOCK requires a (-)Negative thru a 1000 Ohm Resistor and UNLOCK requires a straight (-)Negative
Jan 06, 2009 | 2005 Ford Escape
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
