Question about Riccar 8850 Vacuum
Belt on Riccar 8850 is slipping off motor shaft.
Have installed new belt, was told that "motor is out of alignment" and will need a kit installed, new bushings and such $75+. Does this sound
legit?
  • 76 Answers
NO! there is usually a fan attached to the motor. i have found that junk gets in there and will cause it to viberate. otherwise check the brushroll. there will be connectors on each side with a bearing. if the plastic looks melted, replace the brushroll
Posted on Jul 30, 2009
Belt continually slips off Riccar upright vacuum
Your 8850 is an old vacuum. If a new belt does not solve the problem it may need a new rubber motor mount or metal pivot. Both parts are inexpensive and available from your Riccar dealer. If it's been a while since it's been serviced it would be wise to have it serviced by your dealer. A Riccar vacuum will last for many years but should be serviced once a year like all vacuums.
Apr 07, 2014 | Riccar 8850 Vacuum
I have a Riccar upright vacuum and the belt continually slips off! AARGH! It seems to especially do it anytime you try to vacuum an area rug of any type.
sounds like you need a new belt as the one you have is either been stretched or was the wrong one supplied you can find replacements at most electrical stores ebay or amazon hope this helps
I need to replace the belt on my Riccar supralite vacuum and need instructions
Lay the vacuum upside down, remove the bottom plate, remove the brush roll and belt, install new belt around motor shaft and brush roll, pull on brush roll to stretch belt far enough to drop brush roll back into place.
Aug 14, 2013 | Riccar 8955 Upright Vacuum
Riccar 8850 keeps throwing belt
Your vacuum is at least 10 years old. There are some inexpensive parts that can wear or may need adjustment. You have a very durable vacuum that may have many more years of life but Just like a car, needs to be serviced by a trained qualified technician who knows what to look for. It will save you money I the long run.
Nov 26, 2011 | Riccar 8850 Vacuum
Replacing a belt on the Riccar 8850...I see how the brush assembly will work with the new belt. But I don't see how a new belt will turn on the small rod extending from the motor. Is there a pully missing?
There is not a pulley missing, when the belt is tight the shaft will turn the belt but when the belt loses elasticity it will slip on the shaft when being used on the carpet. Replace the n
belt at least once or twice per year.
Apr 04, 2011 | Riccar 8850 Vacuum
I NEED A BELT FOR A RICCOR 8900..............................PART NUMBER A20-R2 CAN YOU TELL ME WHICH ONE I NEED.....................THANK'S CRISTA HARDIN
You seem to have two model numbers. I plugged the following into Google and got plenty of locations for Riccar belts.
Riccar 8850 Vacuum belts
You can do this and find a supplier you might want to deal with.
Sep 15, 2010 | Riccar 8850 Vacuum
Replacing belt but brush does not turn
Are you sure that you have the right size of belt? This is the correct belt:
Riccar 8850 Belt
Dec 16, 2009 | Riccar 8850 Vacuum
Riccar 8800 belt replaced but now floor brush won't spin
Are you sure that you get the right sized belt? This is the correct one you need:
Riccar 8800 Belt
Dec 15, 2009 | Riccar 8850 Vacuum
No suction
Replace your belt. Remove the baseplate, remove the brushroll, place a new belt around the motor pulley, then around the pulley on the brushroll, and pull the brushroll back into place in the nozzle. Spin it by hand to make sure it spins, (otherwise you'll break the belt again,) and then replace the baseplate. Party.
-R
Feb 25, 2009 | Riccar 8850 Vacuum
Vacuums Logo
311 people viewed this question
Top Riccar Vacuums Experts
Chris Nomland
Chris Nomland
quennie732
Are you a Riccar Vacuum Expert? Answer questions, earn points and help others
