Question about Frigidaire FRS26R4A Side by Side Refrigerator
Is there a filter on my Frigidaire side by side?
I have a Frigidaire model FRS20WRH, I am needing to know if there is a filter that I need to change. The ice maker has stopped working.
  • 1314 Answers
SOURCE: Frigidaire - FSC23F7DS - water dispenser not working but ice maker is
take out the crisper drawers and see if the water tank is frozen is the light on the dispencer lighting up when you depress the paddle and look up in the dispencer to see if the acuating paddis broken we will go from there
Posted on Feb 18, 2008
Krazytech
  • 725 Answers
SOURCE: Frigidaire plhs267za side/side water dispenser leaks while ice maker cycles
You have a bad diode on the water valve connection frigidaire has a kit for this fix..
5303918287, 5304418384 DIODE KIT frigidaire
Posted on Sep 07, 2008
  • 103 Answers
SOURCE: Not making ice
Hi: Change or just remove the water filter first. As your water dispensing slowed that is a clue. If the water filter is that clogged it will cause a problem with the ice maker. Plus the water you drink is not filtered anymore. City water is being run through 2 years of crud. If you don't replace it just remove it. I hope this helps, Jeff
Posted on Jun 03, 2009
the icemaker is not making ice,In the bottom of refridegerator you can see some coils and they are iced over bad.
Posted on Jun 04, 2009
SOURCE: Frigidaire plhs267zab5 ice maker won't switch crush to cube
Pull out the whole ice machine part. At the back of the fridge you will see a small rectangle hole with a white plastic part inside the whole. Loosen the pastic part by applying a little pressure with your fingers it should move, it's probably just sticking.
Posted on Jun 19, 2009
Frigidaire frs20wrh i can not find the water filter
usually the water filter in on the back on the water line coming into the refrigerator, pull the refrigerator and look
Dec 15, 2015 | Frigidaire Refrigerators
Elextrolox side by side water leaking out filter in top of refrigerator model extre23cs78epso
have you recently changed the filter? try turning it in tighter. you may need a new filter base or a new filter if the seals are missing or something on a new one.
Aug 05, 2013 | Frigidaire FRS3R5EMB Side by Side...
I have a Frigidaire Model FRS26ZSH need water filter instruction
Filter Status Press and Hold five seconds to reset light. (This light will tell you when to replace the water filter.)
press the button to the right of water filter to release filter...
Sep 17, 2009 | Refrigerators
How can I change the water filter on a frigidaire fridge
Hi, The filter is in the upper right hand corner of the fresh food section. Turn the filter cup counter clockwise to remove it. There will be a filter cartridge in the cup that you replace.
Please let me know if this has been helpfull or if I can assist you further
Thanks
Vic
Jul 17, 2009 | Frigidaire FRS6R5EMB Side by Side...
Won't make ice
Have you changed your water filter lately. On many side by sides there are built in water filters that will slowly stop making ice and giving water because the filter is in need of changing...if this is not the problem write back and I will walk you through the other possibilities...
May 18, 2009 | Electrolux Refrigerators
Have a frigidaire gallery frig model plrs267zab8....can't get water, ice maker to work after inserting new filter...
generally the filters I have changed need to be flushed with water before acutally using them because carbon can come out of the filter when first used. I don't know you specific item. Check the direction of the filter it may be installed backwards. Can you remove the filter and verify that you get water flow when the valve behind the filter is on? Just suggestions.
Dec 13, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Wheres the model number?
ok the model number is on a silver plate inside the door or on one side of the machine. the outlet filter in on the pump you have to take the front bottom cover off and you will see the pump it is hooked to the drain hose screw off the filter that is on the pump it is a slot turn counter clock wise and then pull out and clean
Dec 18, 2007 | Frigidaire ATF6000ES Front Load Washer
Bypassing a filter
They do make a bypass for this which you can get at http://www3.sears.com/.  Will need to know the entire model # from the sticker on the inside of the fridge.  If you have trouble let me know.  I would the the model # also to help further.  Also, it may say something about it in the owners manual.  Let me what you find.
Oct 17, 2007 | Frigidaire FSC23F7D Side by Side...
Frigidaire FRS26R4A Side by Side Refrigerator Logo
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
