Question about Toshiba Satellite Pro L300 Notebook
How to remove hdmi cover on a toshiba satellite c850d laptop
SOURCE: no picture connecting laptop to LCD TV both Toshiba
Try the fn key and the monitor key (f4?)at the same time to activate external monitor
Posted on Feb 17, 2009
  • 7 Answers
SOURCE: my satellite toshiba laptop shows a screen of fine colorful lines
did you ever try to go on gateway site to find a fix or microsoft.com to see if there is a update display driver for you computer
Posted on Feb 10, 2010
  • 152 Answers
SOURCE: need help with toshiba dynabook satellite 1801
Toshiba bios password removal process is meant for use on Toshiba laptops that you own or have had permission from the rightful owner to remove the password. If any of these processes are done incorrectly it may result in complete system failure or permanent system damage (you've been warned!).
Some Toshiba bios passwords can be reset using the Key Disk.exe utility, to do this you need a 1.44Mb floppy disk. Format the disk using Windows and then with a hex editor, change the first five bytes of the second sector to 4B 45 59 00 00.
Then put the floppy into your machine and boot it up, you'll be asked for a password, just press Enter. Then when you're asked to set the password, type Y then Enter, this will get you into the bios configuration where you can then type in a new password.
Aside from the KeyDisk, you can build a parallel Loopback plug, this is a simple device that plugs into the parallel port of the machine and removes the password when you boot it up.
To make it you will need a 25 pin DB25 plug, take the plug apart and join these pins using some old cable;
Pins: 1-5-10, 2-11, 3-17, 4-12, 6-16, 7-13, 8-14, 9-15, and 18-25
Plug it into your parallel port and boot up your machine, the password should be removed as soon as it boots.
Note: This will work on majority of older Toshiba's (1995 – 2002) and obviously only ones that have a parallel port.
Posted on Apr 28, 2010
donovanm
  • 177 Answers
SOURCE: how can i hook up my toshiba satellite m305d-s4831
You can opt for a VGA-HDMI adapter-one side for the laptop and the HDMI for the TV
Posted on May 09, 2010
  • 11800 Answers
SOURCE: How do i open the
You plug in the cable from the tv (and only from it) and you enable it from Control Panel > Display, second monitor.
Posted on Mar 01, 2011
How do i fix toshiba satellite C850D laptop some keys not working
1) open the buttons and clean underneath them by a toothbrush.
or
2) remove the keyboard (you can see how to remove it online or get back to me if you can't find it) and clean the wire belt gently, maybe something is stuck in there.
or
3) if the above didn't work and you don't want to spend money on a new keyboard, try using a keyboard app.
or
4) the best desperate solution (which i used to solve my problem) is to use SHARP KEY app, which enables you to switch a key to an alternative, less used button.
Mar 06, 2015 | Toshiba Satellite Computers & Internet
Why doesn't my windows button work on Toshiba Satellite C850D
Check your keyboard driver is setup correctly in the control panel.
Jul 07, 2014 | Toshiba Satellite E205-S1904 Laptop
Cannot find a way to turn on webcam on satellite C850D
You need to install a secondary software to use the camera. For example, if you install Skype it will use your camera for video calling. If you just want to view the camera and record the video to your computer Amcap is a simple utility for the job, it can be downloaded here:
http://amcap.en.softonic.com/
Jan 31, 2014 | Toshiba Computers & Internet
Toshiba How To get inbuilt microphone working
Open the Control Panel, select Speech Recognition to very the Mic is in working order. Set Up Microphone. Open Sounds to select Mic. If you are trying to setup in a software program, say Skype, open Skype Setting and configure/select Internal Mic and webcam.
May 12, 2013 | Toshiba Satellite C850D-BT2N11...
I own a Toshiba Satellite C855D and my HDMI port has a plate cover. How do i get it off?
Are you sure you actually have a HDMI port ad not just the area that makes HDMI optional when ordering or for after the fact installation of a new video card?
Jan 12, 2013 | Toshiba Satellite C855D-S5354 15.6" Laptop...
Is there a cover over the hdmi port on the toshiba C855D-S5359
According to Toshiba Website - there is no HDMI port on this model laptop.
http://us.toshiba.com/computers/laptops/satellite/C850/C855D-S5359/
Dec 30, 2012 | Toshiba Computers & Internet
Does toshiba satellite m505-s4940 come with hdmi port
Quoted from CNET review:
"A full-size ExpressCard slot and a memory-card slot are all welcome features, but HDMI has been dropped in the S4940--a plugged-up port is all that remains. "
Sorry...
Nov 21, 2012 | Toshiba Computers & Internet
Toshiba satellite C850D-104 when playing videos on battery power the sound distorts very often but when plugged into the power it plays perfectly,what is the problem?
It seems you have unstable power in your Battery. It is not a good sign for your laptop too. it usually seems on who use their laptop for heavy works like video editing and playing games. You are suggested to Change Your Battery.
Thanx
Nov 10, 2012 | Toshiba Satellite C850D-ST2N02 : Laptop...
Toshiba Satellite Pro L300 Notebook Logo
122 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
