Question about HP Hewlett-Packard - Photosmart 5520 e-All-In-One Inkjet Printer, 11 PPM Black / 8 PPM Color Speed, Up to 1200 x 600 dpi Print Quality, Up to 80 Sheets
Hp 5520 printer jammed paper fix
Paper jammed
5 Suggested Answers
  • 25 Answers
SOURCE: Paper jam in HP 4255 office jet all in one printer
Clearing paper jams
Paper jams can be real or false. The unit may report a paper jam even when there is no jammed paper. The solution to a real paper jam or a false paper jam is the same.
CAUTION:
Jammed paper must be removed using the rear access door with the power cord disconnected to avoid mechanical damage. Do not remove jammed paper from the front of the unit.
  1. Turn off the HP product and turn it around so the back of the unit faces you.
  2. Disconnect the power cord from the back of the all-in-one. The power cord must be disconnected to allow the paper feed rollers to turn freely.
  3. Locate and open the rear access door by pressing in on the left side tab and then pulling the door toward you.
Figure 2: Removing the rear access door
  1. Inspect the pressure rollers on the rear access door and verify that they are clean and turn freely. Clean the rollers if needed with a soft towel lightly moistened with water. If the rollers do not turn freely, replace the rear access door. Click How to Buy on this page to order replacement parts.
  2. From the rear access door opening, remove the jammed paper.
  3. Remove the remaining paper from the paper supply tray. Discard any paper that is damaged or crumpled and then re-stack and reload the paper into the paper supply tray.
  4. Reinstall the rear access door.
  5. Reconnect the power cord to the unit and turn the unit on.
Preventing paper jams
The following information will help prevent paper jams from occurring:
  • Never use paper that is torn or wrinkled.
  • If you are having problems using paper that has already been printed on once (recycling), replace it with new paper.
  • Remove and then reinstall the rear access door. Verify that the access door is fully locked in place. The paper can skew if the rear access door is not locked.
  • Every six months to one year, clean the paper feed rollers with a rag lightly moistened with water. Over time the paper feed rollers accumulate dust and do not function as well as they once did.
  • When printing envelopes, tuck the flap into the envelope and crease the folds before printing.
Posted on Jul 08, 2008
  • 34 Answers
SOURCE: HP 4200 printer paper jam. No paper is jammed
check this out....when the printer reports the jam, open the paper tray very carefully and slowly.
Has the paper moved at all forward? Has it moved like 1/4 inch to 1/2 inch out of the tray?
If so, you probabaly need a torque limiter, no tools, $10 or so and a very very easy fix.
POBCM is very correct when he points out that the block/stop in the back of the tray moves when the tray is closed with too much force and this is the #1 cause most of the time.
You may see a "41.3" code displayed if the block is not up to the back of the paper and the paper is not all the way forward in the trays, and under the two metal clips at the front of the tray.
Posted on Mar 14, 2009
sgoswami
  • 114 Answers
SOURCE: Paper jam on HP officejet 6500
Try This :
Connect the printer directly to the wall outlet ; not through any Power strip
Then Unplug the Power cable from the back of the printer
Keep on tapping the power cable for next 30 seconds
Plug in back the power cable;
Open the rear access door and you will get to see some rollers
Clean the rollers with a Lint free cloth Moistened with some distilled water
Try to do a copy if still it doesn works
With one hand press and hold down the (#) and the (6) button and with the other hand plug in back the power cable ; it will do a Semifull reset on the printer; This will take some time ; Follow the instruction on the screen;
If still it doesn't work then you need to contact HP ;
The toll free no. for HP would be : 1-800-474-6836
They will replace the printer for you free of cost (No Charge if the printer is in warranty i.e within 1 yr of purchase)
Still you may check the link below for further issues:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01312792&lc=en&dlc=en&cc=us&lang=en&product=3795406
Regards Soumajit
Posted on Sep 21, 2009
celibytes
  • 70 Answers
SOURCE: HP PSC 1350 printer won't feed paper
Check the gear on the left side of your printer where the disk encoder strip is attach,the gear is not holding the metal shaft your need to replace that gear. The problem is in the inner hole where the shafting is attached.
Posted on Nov 03, 2009
Hp 5660 photo paper jam from placing in wrong tray.
HP Printers - 'Paper Jam' Error ' HP® Customer Support
https://support.hp.com/ca-en/document/c04348351
This document troubleshoots how to clear different types of paper jams from error ... 5542, 5544, 5545, 5546, 5547, 5548, 5640, 5643, 5644, 5646, 5660, 5664, ...
Solved: HP Envy 5660 - Paper jam message - HP Support Forum ...
https://h30434.www3.hp.com/t5/Inkjet-Printing/HP...5660-Paper-jam.../td.../4673198 Nov 4, 2014 - 4 posts
Solved: Our HP Envy 5660 printer is 2 weeks old. It was purchased at an ... An error message popped up reporting a paper jam issue. Followed ...
help HP printer Envy 5660 Error "load photo paper in tray" - HP ...
https://h30434.www3.hp.com/t5/LaserJet...HP...5660...photo-paper-in/td.../5285421 Oct 5, 2015 - 2 posts
A new Envy 5660, can't get it to print 8x11" size, keeps error message, "load photo paper in tray", need to know how to set printer to print on regular size paper. ... I see you are trying to print to your HP Envy 5660 but you keep getting an 'Load photo paper in tray' error message.
HP ENVY 5640, DeskJet 5640 Printers - A 'Paper Jam' Message ...
https://support.hp.com/ca-en/document/c04759464 There are three different areas where paper might become jammed. Clear any jammed paper from one area, and then try to print again. If the error persists, ...
Paper Jam Or Tray Problem - Hp Envy 5660 Instruction Manual [Page ...
https://www.manualslib.com > ... > Instruction manual HP Envy 5660 Manual Online: Paper Jam Or Tray Problem. Paper has become jammed in the printer. Before you try to clear the jam, check the following: Make ...
Fixing a Paper Jam on the HP ENVY 5540 Printer - YouTube
? 14:06
https://www.youtube.com/watch?v=mrjGs1ahOjw
May 17, 2016 - Uploaded by HP Printer Support
Learn how to clear a paper jam hp 5660 photo paper jam Google Search
Jun 20, 2017 | HP Office Equipment & Supplies
Tip
HP Inkjet Printers - Fixing Paper Path Issues: Paper Jam, Carriage Jam, and...
For a printer to work, the paper has to move through the printer. The route that paper follows through the printer is called the paper path. If the paper doesn't pick up (no pick) or something interferes with the paper path, nothing prints. If the paper is stuck in the path, you have a paper jam. Sometimes jammed paper in the printer can lead to the device that carries your ink cartridges back and forth in your printer to get stuck (carriage jam) as well. Sometimes the carriage can stop moving for other reasons.
The videos in the following playlists were created to help resolve these paper path issues. These videos are not short or entertaining but they are complete. They repeat steps (test print) so even novice users can follow these without having to refer back to instructions earlier in the video. The solutions in these videos are what works to solve paper path issues most of the time. Follow the steps completely. Sometimes people shortcut some of the solutions. Avoid shortcuts for accurate troubleshooting.
The steps for resolving paper path issues are specific to your printer. These playlists have videos for about many different models. We will continue adding to the collection or updating the videos when we find new ways to resolve these issues. The title and description of the videos explain what models the videos apply to.
Some of the videos end with a step that explains that the printer needs to be serviced. If your printer is still in warranty and you get to that step, contact HP for help. If your printer is out of warranty, open a new post in this forum and see if others have a non-conventional solution that will help. Also, Google is your friend offering non-HP out of warranty solutions for servicing/fixing a broken printer.
Fixing Paper Jams on HP YouTube
Fixing Carriage Jam YouTube
Fixing Paper Pick Up Issues YouTube
on Dec 04, 2014 | HP Office Equipment & Supplies
My hp printer 5525 shows carriage jam how can i fix this?
If you lift the lid to get access to the cartridges, there should be a diagram showing you how to unjam the carriage. I have a 564, & it has that feature.
Aug 05, 2016 | HP Photosmart 5520 Multifunction Inkjet...
I put paper on my hp printer and keeps jaming up wht can i do to fix tht problem thank you get to asap thanks again
60 Second printer paper jam fix by hp technician solves feed ...
? 4:56
www.youtube.com/watch?v=BdFvyDZmiFI
Oct 25, 2011 - Uploaded by BrokenPrinter1
60 Second paper jam fix by hp technician how to solve feed ...I've been trying to figure out why my printer has been jammingfor days! Days I ...
Fixing a Paper Jam - HP Deskjet 3050 All-in-One Printer ...
? 12:07
www.youtube.com/watch?v=suiQgoH-8cM
Jul 5, 2011 - Uploaded by HP Printer Support
My hp printer was working great until yesterday when I seemed to be taking ... I was able to fix the paper jam error on my friend'shp desktjet ink ..
Oct 20, 2015 | HP Office Equipment & Supplies
How do I fix paper jams for HP CP1215
It depends on the printer, but I found that when one of my HP printers was over 4 years old I had to upgrade to a higher quality paper to avoid paper jams. **Hammerill and Navigator are two brands. They may cost a little more to use, but it extended the life of the printer and restored the printer to normal. Those papers are noted for a more slippery paper surface in their processing, that essentially eliminates all paper jams.
Jan 21, 2015 | HP Office Equipment & Supplies
My 5520 all in one printer does not print black
did you try cleaning the head? or a new cartridge?
Tony
Jul 14, 2014 | HP Photosmart 5520 e-All-in-One -...
Fix inner paper jam hp cm1312
I Suggest You To Watch HP Video Gallery Fixing Paper Jam HP Deskjet 1510 All in One Printer To Fix Your Brother Printer Issue.In Case You Still Having Problem Then Follow Us For On : HP Printer Support Team.
Nov 19, 2013 | HEWLETT-PACKARD HP Color LJ CM1312 MFP...
HP Hewlett-Packard - Photosmart 5520 e-All-In-One Inkjet Printer, 11 PPM Black / 8 PPM Color Speed, Up to 1200 x 600 dpi Print Quality, Up to 80 Sheets Logo
1,038 people viewed this question
Seeker5211
Seeker5211
