Question about Frigidaire GLEQ642A Electric Dryer
Dryer works and tumbles but does not heat
My dryer suddenly stopped heating to dry. I checked the gas tank and it is full. My model # 26 52212 front loading tumble dryer. I read the troubleshooting guide and it mentions that it could be a fuse that has blown out but I dont know where the fuse is located. Please help.
    Master:
  • 623 Answers
First, you must remove the front panel. Open the door and remove 2 screws on each side of the opening; 2 in the door hinges and 2 directly opposite from them. Then close and latch the door and pull on the top corners of the panel and it pivots down, then lift off the bottom brackets. Then start the dryer (making sure it's not set for air fluff or no heat) and watch the ignitor to the left side of the burner tube. Report back if it glows or not. Also you might include the first two numbers of the serial number so I can make sure we're talking about the same series machine.
Posted on Jan 13, 2009
DRYER HEAT TURNS OFF AFTER ABOUT 30 MINUTES
  • Get on with replacing the gas valve coils shown to you in the previous link, it will take care of your problem.
  • There are two house circuits/fuses in an electric dryer's circuit.
    If one of them is tripped/blown, the drum may turn, but the heater will not operate. Reset the circuit breaker or replace the house fuse.
  • Outlet wired incorrectly.
    Have a qualified electrician verify that the supply voltage is correct.
  • Gas supply valve to a gas dryer is not open.
    Open the gas supply valve. See Installation Instructions for details.
  • LP gas supply tank is empty or there has been a utility interruption of natural gas.
    Refill or replace the LP tank. Call your natural gas utility company.
  • Dryer does not have enough air supply to support the gas burner.
    The dryer needs space around it for proper ventilation. Do not stack or place laundry or throw rugs against the front or back of the dryer. See Installation Instructions for details about installing a dryer in a closet or alcove.
  • Incorrect cycle or temperature has been selected.
    If the Air Fluff cycle or temperature is selected, the dryer will tumble without heat. Each cycle ends with a Cool Down period during which the load tumbles without heat. Check the location of the indicator on the Cycle Selector knob.
Jun 07, 2008 | Whirlpool LGB6300 Gas Dryer
The dryer is tumbling but not heating, so clothes are not drying model LGN2000JQN
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jul 26, 2011 | Whirlpool Dryers
Kenmore elite model 11070092990 dryer tumbling but not heating unplugged and started again-still not drying
heatman101
Jun 13, 2011 | Kenmore Dryers
I have had a stackable hi efficent 7.3 cap. kenmore dryer for 2 months. Suddenly it doesn't heat. No sign of vent problems or electrical but on all cycles both the dry & cooling light up at the top...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Nov 22, 2010 | Kenmore Dryers
Kenmore dryer thats not drying
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jun 01, 2010 | Dryers
Maytag MDG5500 - heat goes off after several minutes
Q - My gas dryer will not heat, what could stop my dryer from heating?
A - Things that could stop a gas dryer from heating:
- glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats,motor heat switch, timer, selector switch, sensor.
A page for checking gas dryers is here.
Mar 07, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Dryer not heating
Jan 08, 2009 | Frigidaire Dryers
No heat in kenmore 97273100 72731 front load gas cloths dryer
check the ignitor under the door panel on the left side of the burner if it gets red when you turn the dryer on.if yes than see if gas shoots out and yes than how long it stays on if in few minutes it turns off than need thermal fuse checked so let me know up to this point if it works or not .
Nov 02, 2008 | Kenmore 73952 Gas Dryer
Frigidaire GLEQ642A Electric Dryer Logo
105 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
