Question about Bosch Washing Machines
Bosch WFMC3200UC/01 PRTS DIAGRAM - Bosch Washing Machines
5 Suggested Answers
SOURCE: BOSCH WASHER REPLACEMENT PART
I have the same problem. Bosch no longer stocks the replacement for my particular washer which has the same model no but could be a different fd #. I now have the wrong part as directed by bosch which doesnt have the hose connection. I am not sure what to do with the hose leading to nowhere. Bosch is living off of an undeserved good reputation.
In the present, the reputation is not deserved. Bosch products should only be recommended to enemies. The company and the especially the customer service is beyond deplorable. I hate these appliances. I feel ripped off! The part by the way, which is wrong, is 100.00 with tax.
Posted on Jun 05, 2008
  • 3 Answers
SOURCE: BOSCH WFMC3200UC WASHER
Go to http://www.repairclinic.com/SmartSearch/smartsearch.aspx and type WFMC3200UC under search at top. Then select gasket/seal/o-ring from part type drop down menu.
Posted on Sep 15, 2008
Macmarkus
  • 2605 Answers
SOURCE: I had to replace the
Welcome to FixYa.
The first thought which comes to mind reading your post and replies, specifically this...
" I am connecting the fascia panel back to the control panel and I have something attached incorrectly as the display read out when I turn the dial is 180 degrees off "
...are you sure you don't have the program dial 180 degrees off it's proper position ?
That is a common and honest occurrence when replacing these controls because they can fit on both ways...in fact I've done it on occasion if I'm not paying close attention, and I've done plenty.
Be sure this dial shown is at the 12 o'clock position when fastening the control to the panel...
Let me know if you think this is a real possibility and I can try and help you move forward from here.
I'll watch for your reply.
Regards,
Macmarkus :)
Posted on Feb 14, 2011
BADBOYJAY
  • 264 Answers
SOURCE: how do I remove door seal from wfmc3200uc/01
right this is easy you need to take the soap draw out and there is one star screw on the right hand side it needs to come right out then one screw down on the right side there is a flap you need to flip it down and you will see a screw undo it and the bottom plinth sould push it to the left and it should come off then two other screw one left one right then you and pull down the front then you can see the rubber there is a spring holding it in place make sure you put back the spring when you put the new one on then when you have done putting it on put the front on starting at the bottom then push up and screw back together OK any problems get back to me OK hope i have helped
Posted on Oct 17, 2012
My bosch nexxt washer model wfmc3200uc/01 vibrates excessivelyrics and moves across the floor on spin. I have balanced and tried everything. Any advice on parts that can be replaced or where to start
This probably aint it, but my front loader did that, and it turned out to be a bracket that they install for transport. It connects to the tub and keeps it from bouncing while in transport. If it is connected, remove it and try it then.
Sep 06, 2015 | Bosch Washing Machines
Can't get retaining rings back on boot gasket on Bosch 3200uc
You can google for them or look on this site Fixya for spares.
Mar 19, 2013 | Bosch WFMC 3200 Front Load Washer
Need instructions for moving -- have four bolts!
Hi.
Here the full set of instructions for the model Bosch WFMC 3200 posted in title:
WFMC3200UC/01 Manual 1
WFMC3200UC/01 Manual 2
Here repair manual available for $9.95.
Regards.
Ginko
Jun 07, 2011 | Bosch WFMC 3200 Front Load Washer
Front Door Seal
Call the Customer Service number located in your manual. Discribe to them what you have said here and they will send one to you for FREE! This is a problem that should NOT happen.
Moving forward, once you get it spray it down with Lysol Mold and Mildew Prevention and let it dry a couple of days before you install it.
May 13, 2008 | Washing Machines
RepairClinic.com (which is good)
espares.co.uk
AppliancePartsPros.com
Apr 28, 2008 | Bosch WFMC 3200 Front Load Washer
Bosch wfmc3200uc/01
would need machine in workshop sorry can t help on that one
Nov 10, 2007 | Bosch WFMC 3200 Front Load Washer
Washing Machines Logo
5,536 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
