Question about Broan-NuTone Allure II QS230SS Kitchen Hood
1998 grand voyager van
Ac/heating control knobs not functioning
  • 15,935 Answers
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 05, 2010
1998 voyager van hot air always coming out the vents, now there is now heat or air or relays left in the unit WHY?
Obvious question, but are you sure the battery is being charged by the alternator ?
Jul 03, 2012 | 1998 Dodge Caravan
I need a PCM for my 1998 Plymouth Grand Voyager 3.3L. I can't find the part however, I have a PCM from a 1999 Plymouth Grand Voyager 3.3L. Will it fit on my 1998?
maybe / maybe not, really depends on numbers and design level of builds between vans.
Parts Information OEM Part # Price Engine Control Module ECM 4 Speed Federal 4727153AJ $599.00 Order By Description. California 4727154AJ $819.00 Order By Description.
Jun 04, 2011 | 1998 Plymouth Grand Voyager
I have a 98 ply grand voyager, and have heat from the drivers side vents, but cold air from the passenger side vents? please help
Does your van have seperate controls for driver and passenger temperature settings? If so the most likely cause is a broken actuator or broken passenger blend door. Unfortunately, the only way to repair a broken blend door is to remove the dash and the HVAC assembly.
Feb 05, 2011 | 1998 Plymouth Grand Voyager
My 1998 plymouth grand voyager horn and cruise control do not work.whats the problem..
There was a recall due to the clockspring being wound incorrectly. If the repair was not made, this could cause the horn and cruise control to quit functioning and the air bag light to stay on.
Aug 19, 2010 | 1998 Plymouth Grand Voyager
How do I reset the AC on my 1998 Chrysler Grand Voyager?
You can try disconnecting the battery, some times that work's, also have the a/c system check for freon pressure could be low being they did body work and maybe had to remove an a/c hose.
Feb 05, 2010 | Chrysler Voyager Cars & Trucks
Does the 2002 Dodge caravan have AC in the rear of the van? Or does it have just AC vents in the front of the Van.
If your van has rear AC/Heat there is a roof mounted control for the rear. There is also a control knob on the front panel, that says rear control auto, rear control & rear control off.
Jan 19, 2010 | 2002 Dodge Caravan
Ac gives out then van overheats
Both of these need the serpentine belt to run. Maybe its too loose. may need replacement or tensioner
Aug 08, 2009 | 2000 Chrysler Grand Voyager
98 PLYMOUTH GRAND VOYAGER WONT START - BLOWS ENG FUSE - HELP
You have a shorted engine harness, this is not common but it does happen, heat and engine movement cause damage to the harness, this is most common on hi miler cars and vans, the only way to fix it is to start by looking anywhere the harness rubs, that is where the damage occurs.
Oct 15, 2008 | 1998 Plymouth Grand Voyager
Broan-NuTone Allure II QS230SS Kitchen Hood Logo
67 people viewed this question
Top Broan-NuTone Kitchen Ranges Experts
Dan Phillips
Level 1 Expert
Phil Lovisek
Phil Lovisek
Are you a Broan-NuTone Kitchen Range Expert? Answer questions, earn points and help others
