Question about Razor E100 Electric Scooter
Ur gay nflikghasdfpoiughsoiudfhgoiusdjfgsd fixing up an old el;ectra scoot n go electric scooter and there are a couple broken wires in the harness i need to know where they go to,
SOURCE: ksc-wa100
Posted on Jul 06, 2008
  • 33 Answers
SOURCE: need wiring diagram for 2008 ford crown victoria
You can purchase the wiring diagram for $5.99 from the following site: You can also purchase a wiring diagram book from the following link:
Hope this helps,
Posted on Mar 23, 2009
  • 216 Answers
SOURCE: Need Yamaha XT 500 Wiring diagram for pipe cart I,am building.
This is the best i can do, its the manual in photo form. You can enlarge using any photo editor.Good luck. Rate me if i've helped you. thanks.
Posted on Mar 26, 2009
SOURCE: MZ CHARLY Scooter w/defective controller; can not find part
I have a manual for a 2001 mz charly electric scooter. The scooter folds down and you can carry it. Just checking to see if we are talking about same scooter. The book if have has the circuit diagrams.
Posted on Jun 21, 2009
Sym joyride 200i starts after 10 min cranking in the morning rest of the day starts perfect EFI light flashing continiously
Hi, Kevin it should be noted that the reasons EFI lights constant or flashing, will or will not start, turns over or not conditions varies from the year, make, and model and you should always refer to your owners/service manual for proper diagnostic procedures. It should also be noted that any type of prior work or event IE: adding accessories, electrical curiosity/adventures, laying bike down/crashes, rainstorms/bike washings just before EFI light issues started can be significant hints/aids into tracking down the gremlin, also carry the appropriate jumper wire to access fault codes to reduce the risk of being stranded or towed, that being said the usual suspects are:
1. Faulty Fuel Pump, fuse or system relay switch.
2. Battery starting to fail due to old age/damage, perform a load test.
3. Discharged battery, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Faulty switches/sensors: run/off, ignition, clutch lever, neutral, side stand, tip over, fuel, and or their connections.
5. Broken wire or worn insulation exposing wire to a ground situation especially inside wire harness at tight bends around fairing brackets, under dash panels, under fuel tanks over cylinder heads etc. Many harnesses are open on the ends that will allow water to enter and accumulate at v-bends.
Dielectric grease and contact cleaner are your best friends for wire/cable/harness connectors, look for corroded, broken, or loose pins/sockets. For more information about your issue and valuable free downloads that you will need please visit the websites below. Good luck and have a nice day.
Scooter Troubleshooting Scooter won start All about Scooters
Cold start
my SYM HD 200 won start
Feb 28, 2016 | Motorcycles
Battery Not Holding a Charge
Mobility scooter batteries can encounter problems, as over time, these batteries age and lose some of their effectiveness, until eventually they stop working completely. In this case, battery replacement represents the only thing that owners can do to fix the problem. Before doing so, however, they should perform some other troubleshooting measures to make sure. For collapsible scooters, seat the battery properly when unfolding the scooter for use. Owners should also make sure to properly connect the battery, while also looking for any error messages or flashing lights displayed on the scooter's dashboard.
5 Troubleshooting Tips for Mobility Scooters
Dec 01, 2015 | Travel Scoot Travel Mobility Scooter -...
Have a 150 scooters checked sparkplug oil air filter as well new fuel still want start
got to see if it's a fuel problem or electrical/ignition problem. Spray a little starting fluid into the carb or air cleaner as close to the carb opening as possible. If the scoot tries to start even a little bit then you have a fuel problem. If nothing happens with the starting fluid start checking for electrical things. Shut off switch, key switch, broken or frayed wires, bad battery connections and on and on. Good luck
Feb 05, 2012 | Motorcycles
Need a wiring diagram for a Scoot-N-Go Elecric scooter?
After getting a new set of batteries, now when I turn on the key the scooter's motor engages and takes off. I have the wiring diagram and everything looks right, what could be the problem?
Feb 04, 2012 | Health & Beauty
My 3 wheeled mobility scooter cuts out almost every time I turn the handle to the left. I think it may have a kinked wire.
This typically happens when the front to rear wiring harness has a damaged internal wire or wires. The front to rear harness runs from the front control console, down through the tiller (T part) through the front wheel frame and angle adjustment collar, and through the bottom frame to the controller. There is a wear area of the wiring at the front bearing of the steering tiller. There are 8 or more wires in a covered jacket that run through this area. Over time they rub and get pinched or kinked and broken. The test for bad wiring is exactly what you describe. Usually the broken internal wiring cannot be seen.
The best solution is to replace the entire front to rear harness with the new connectors at each end. The harness is relatively inexpensive and labor should be about 1 hour. Hope this helps.
Jan 30, 2011 | Electric Mobility 3 Wheel Motorized...
Lost the key to my partners lynx mobility scooter... 4 wheeler. Where can I buy a new cylinder / locks? Thanks!
Soutside how secure does the scooter have to be? Is it parked inside at night and does your partner leave it unattended for long? The reason I'm asking is because you can replace the keyed switch with a plain old on/off toggle switch for about 5 bucks. Just remoce the console unscrew the old keyed switch unplug the old switch from the wire harness and using the original connector splice the toggle swith to the connector tape with electrical tape and install in console. Check correct operation of the switch before you put it in the console. If it works ok install it and put the console back together and there you go a fix plus cheap too You can always call Invacare @ 1-800-333-6900 and order a new switch Hope this helps.
Oct 27, 2010 | Lynx L-3X Compact Scooter
We are not getting any aprk to the spark plug the the scooter will not turn over (any suggestions)
few things come to mind on this
First Make Shure your battery is fully charge
Secend the wire harnes atched to the key switch may be loose
Check All Wire connrctions on your scoot as thay have a habbit of comming loose. forum has a check list to help find the fix for your scoot.
Best Reguards
Jan 14, 2010 | RTO Gas Motor Scooter
Problems with Pride Celebrity X 4-Wheel Electric ScooterFree tech support for Pride Celebrity X 4-Wheel Electric Scooter and help with Pride ... the scooter suddenly stops. it is an intermittent problem....
It is often a damaged accelerator (Potentiometer). Sometimes the shaft on the wigwag breaks the contacts in the accelerator from being moved too vigorously when going over a bump too fast. A technician would need to repair this for you. Happy scooting. Regards Chris…
Jun 20, 2009 | Pride Celebrity X 4-Wheel Electric Scooter...
Razor E100 Electric Scooter Logo
47 people viewed this question
Top Razor Toys Experts
Clif Roberts
Bryan Mcphee
Bryan Mcphee
Level 1 Expert
David Payne
David Payne
Are you a Razor Toy Expert? Answer questions, earn points and help others
