Question about Maxtor Ultra ATA/133 PCI Adapter Card (999812) IDE Controller
Hello, I have a PCI Ultra Ata/133 Dual IDE card. I have two Ide devices hooked to it. Everytime I hook it up in the system My regular Motherboard IDE says can't be read, reboot. I am trying to get not Raid but Two IDE devices to be available in my Vista system. I had same problem in Win XP, Now I have installed Vista hoping the driver problem would be solved. In order for my PC to even boot normal, I have to uplug both dual IDE cables from my Ultra ATA/ 133 card. Thanks, Professor Yonce.. Whats your suggestion?
  • 2 more comments
  • Professor Yonce Jan 13, 2009
    It acts like no Disk can be found. It can not find even my Motherboard IDE when I have the 133 dual IDE board plugged in.
  • Professor Yonce Jan 23, 2009
    I see the Controller card wanting to boot each time instead of my Motherboard IDE.
    I have to disconnect the IDE ribbon cable each time if I want the Motherboard IDE to boot.
    It says in my Bios that I have a Raid controller.
    I do not want a Raid controller, I want a dual IDE controller.
    I even switched the two hard drives. I put the One that was connected to my Motherboard onto y add on PCI controller card and it boots okay.
    I have a special key to press to boot up on the one I deside, All the Hard drives are listed including the CD-Rom as a boot. but it ignores the choice I make and tries to boot from the ATA controller 133 Ultra card instead.
    Thanks for your help. I need to know how to flash or erase my E-Prom Bios and unplug the Add on 133 ATA card and reboot and let the PC install a new driver, I do not want the Raid driver, I want the Dual IDE controller driver. I tried that and even deletted my Device driver in my Hard drive manager and rebooted with the card out of the machine, Then I powered down the PC and plugged back in the 133 ATA controller card and my Boot still shows the Raid driver.
  • Jordan May 11, 2010
    Are you using the PCI2IDE to connect your boot drive (Primary Master)?
    What kind of errors do you get if you leave the IDE cables plugged in and boot up your machine?
    Sergeant:
  • 238 Answers
Sounds like the system is trying to boot from the drives attached to the controller. Go into your setup and make sure the system is set to boot from the proper drive.
Posted on Jan 23, 2009
  • Robert Graf Jan 23, 2009
    This is because of your motherboard's BIOS settings. It needs to be set to the proper drive.
    No, you don't. Set the system BIOS. When you installed the controller, your BIOS detected it and assumed you want to boot from it.
    This is probably just a generic term. If you have not formatted the drives for RAID operation, then I would assume that to be the case. I don't think your BIOS can detect this. This setting in the BIOS sometimes listed SCSI as the option because that was the most common add in controller. Most people doing what you are doing are using it for RAID, so that's the name they use.
    You're probably fine. This probably has to be set in the controller card's BIOS.
    >I
    This confirms my diagnosis. Just watch your system at startup and it will tell you the key to press to enter setup, usually or an F key. Then, enter the settings screen and select the drive you want to boot from. This menu item should say RAID presently, from what you are saying. Again, this does not indicate RAID operation, but rather a RAID capable controller.
    >I
    card instead.
    Hopefully, changing the settings in the system BIOS will fix the boot problem.
    It's not a driver issue or else you wouldn't have been able to boot from the drive that was connected to your motherboard when you hooked it up to the add in card. You do not need to flash anything as far as I can tell.
Maxtor ultra 133 raid drivers windows 7
Driver is for Vista but should hopefully for Windows 7. This is a legacy card no further driverswill be added past Vista.
http://firstweb.promise.com/upload/Support/Driver/Ultra133%20TX2%20windows%202.1.0.3%20logo%20driver.rar
Nov 16, 2011 | Maxtor Ultra ATA/133 PCI Adapter Card...
Have an SYBA PCI IDE RAIDx2 and very urgent need the driver for Windos 7 Ultimate x64. The VIA site is out of service..!!
hi I found this link below for all syba driver updates and downloads, hope this helps.
http://it.us.syba.com/support_download/download/index.html
Feb 13, 2011 | SYBA SD-SIL680-RAID Ultra ATA 100/133 IDE...
Ultra ata 133 ide controller........i installed this on a brand new gigabyte MB with windows 7..........Device manager knows its there but with a problem. I cannot locate drivers for this device...
if u cant locate the drivers name, try using unix base(linux) live cd's, like knoppix for example, they usally detect all the drivers u have in minutes and even gives u all the names and serial numbers, then u can download them.
Apr 30, 2010 | Maxtor Ultra ATA/133 PCI Adapter Card...
Can i use 2.8ghz cpu for my p4s533-e?
this is what asus says:
arrow-org.gif Latest P4 CPU Support
The latest P4S533-E motherboard supports Socket 478 Intel® P4 processors, which utilize the most advanced 0.13um process technology to provide frequencies up to 2.53GHz
Mar 23, 2010 | ASUS P4S533-E Motherboard
Silicon Image Ultra-133 Medley ATA (Maxtor Ultra ATA/133 PCI Card
No I do not think there is unfortunaely. Contact Maxtor and ask if they are going to support it under Windows 7?
Jan 21, 2010 | Maxtor Ultra ATA/133 PCI Adapter Card...
I cannot find a driver anywhere for my belkin f5u098 ide raid controller.
The drivers for this ATA Controller Card are resident in Windows, just like the Motherboard's onboard ATA/IDE Controller. If they don't autodetect and load make sure you are running at least Service Pack 2 for Windows XP and SP4 for Win 2000. Vista and later will have resident drivers.
Sep 23, 2009 | Belkin Ultra ATA/133 PCI (f5u098) ATA...
Vista drivers needed for Ultra ATA/133 IDE RIAD controller card
You can plug it in and see if Vista can use any of its drivers for it. In many cases it has drivers for the chipset on the card which will work perfectly well with the device.
Apr 09, 2009 | Maxtor Ultra ATA/133 PCI Adapter Card...
Mortherboard
CPU:
Supports Intel Pentium 4 Socket 478 processors with 800/533/400 MHz FSB
Supports Intel Hyper-Threading Technology Chipset: Intel 865PE / ICH5-R
Supports Dual Channel DDR 400 Memory
Supports Advanced Configuration and Power Management Interface (ACPI) Memory: Six 184-pin DIMM sockets
Supports Single/Dual Channel DDR 400 memory (Max. 4GB). Audio: High quality 6-channel AC'97 audio with S/P-DIF function with JAck Sensing IDE/SCSI: Dual Ultra DMA 66/100 IDE controllers integrated in ICH5R- up to four Ultra ATA drives
Serial ATA/150 controller integrated in ICH5R- Up to 150MB/sec transfer speeds
2 channels Serial ATA 150MB/s data transfer rate via Silicon Image PCI controller
GigaRAID IDE RAID Controller I/O Connectors: PS/2 Keyboard and mouse, 1 x Parallel, 2 x Serial, 4+4 x USB2.0, 1 x RJ45, 1 x Audio Expansion Slots: 1 x AGP (3.0) , 5 x PCI (2.3), 1 x DPS Additional Features: GIGABYTE Patented Technology Dual Power System 2 (DPS 2)
GIGABYTE Xpress3 Series Software
from the above configuration for the board you can see that it supports up to 4GB ddr max
hope this helps pls appreciate by rating as fixyaa
Oct 05, 2008 | Intel Motherboard
Installing a 2 port ATA-133 IDE adapter card to a desktop w/a hard drive & DVD
I don't think you can boot off of the ATA-133 so you will have to boot off of the IDE on the mobo and have the DVD drive jumpered cable select on the 2nd IDE. Boot that way to make sure the system boots. Shut down. Then instll the ATA-133 adapter with NO DRIVES on it and boot. The system should ask you for drivers for the new hardware. Intall the drivers. Shut down. Attach the new drives to the ATA-133. Reboot. You still might have to go into admin in windows and assign drive letters to the new drives. Anyway, if you are trying to boot off of a drive on the ATA-133 adapter, I don't think you can do it. I have mostly used Asus boards with Award Bios and there was no way to point the boot process to an add-on ATA Controller.
Jan 12, 2008 | Promise Ultra133 TX2 ATA Controller
Maxtor Ultra ATA/133 PCI Adapter Card (999812) IDE Controller Logo
427 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
