Question about Philips 50P8341 50" Rear Projection Television
WHEN I TURN TV ON IN FRONT OF TV IT TURNS ON AND OFF AGAIN
I NEED TO COVERGE THE TV AND I CAN'T GET THE REMOTE OR THE BUTTONS ON THE FRONT OF THE TV TO WORK. WHEN I PUSH THE BUTTONS ON THE FRONT OF THE TV THE TV TURNS OFF OR ON AND THEN OFF AGAIN AND THEN BLINKS TWICE. I HAVE A PERFECT PICTURE EXCEPT FOR THE COVERGENCE. HELP PLEASE PHILIPS 50P8341 REAR PROJECTION TV
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,632 Answers
This is the best solution for your problem as a 40 year experience with wires etc. Go to the source of your cable signal connector . Open it and clean the terminals with emery paper , sand the end of the cable shiny clean from corrosion , get a new barrel connectors with gold terminals if possible lengthen the ends of the cable , insert and tighten good, use thick rg-16 or rg 40 cable with good insulation ends crimped professionally with a crimpier or buy ready made , not from dollar store. Get a gold plated professional splitter if you need one or two , it will cost about 15 or more each . Make the cable runs as short as possible, using the thick good cables. If needed get a signal magnifier. From radio shack or the source etc. Connect them good and tight . Ground the splitters . Problem solved , you will get crystal clear channel 2 to 7 including 3 and 4 . Isolate the TV cable from other cables and power wires. Vitally
Posted on Apr 15, 2010
Hi.......
Posted on Jun 15, 2009
  • howard_07
    howard_07 Jun 15, 2009
    I
    Sergeant:
    Champion:
  • 318 Answers
The remote and buttons use one IC to control,
tuning, remote,
open your tv and check the common IC and change it okey
Posted on Apr 16, 2009
My RCA Truflat T.V won't turn on and the FPA lock is turned on, I have the original remote. what should i do?
TV won't turn on • Press the TV button. Make sure the TV is plugged in.• Check the wall receptacle (or extension cord) to make sure it is "live" by plugging in something else.• Something might be wrong with your remote control. Press the POWER button on the front of the TV. If the TV turns on, check the remote control solutions on page 26.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).Buttons don't work
• If you're using the remote control, press the TV button first to make sure the remote is in TV mode.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).• Unplug the TV for two minutes and then plug it back in. Turn the TV on and try again.TV turns off unexpectedly • Sleep timer might have been activated. Go to page 24 for instructions.• KidPass might have been activated. Go to page 21 for instructions.• Wake-Up timer turned on the TV and no remote or front panel buttons were pressed for two hours.• Electronic protection circuit may have been activated because of a power surge. Wait 30 seconds and then
turn on again. If this happens frequently, the voltage in your house may be abnormally high or low.
• Unplug TV. Wait five minutes. Plug it in again.
Sep 16, 2011 | RCA 20F420T 20" TV
Hi, how do i sync my venom dvd remote to my xbox 360? thank you
To enter a TV code:
1 Turn on your TV and point the remote toward it.
2 Press and hold the TV and OK buttons simultaneously for two seconds. All of the buttons on the media remote will then light up for two seconds, after which only the numeric TV buttons (1-12) will remain lit.
3 Enter the code for your TV.
4 Press the TV button again to save the code and exit. All of the buttons on the media remote will blink three times to confirm your selection.
To scan for a TV code:
on the media remote will then light for two seconds, after which only the numeric TV buttons (1-12) will remain lit.
3 Press the CH+ or CH- button to send a series of off commands to your TV. Repeat until the TV turns off.
Jul 02, 2011 | Venom DVD Remote Control for Xbox 360
I have a Mitsubishi 73"
i would suspect your control buttons on your front panel on the set have become shorted. specifically the volume buttom down. This is freezing you control functions. like someone is holding the volume down button all the time. or intermitantly. this cuircit board is on front of the set. I have seen this problem a few times at the shop. The common repair is to replace that button assembly cuircit board. I believe the last time it cost the customer around 85 dollars, but like all things depends on the part and the technician that puts it in.
Apr 21, 2011 | Mitsubishi WD-73827 73" HDTV DLP TV
Philips 50P8341 50" Rear Projection Television Logo
66 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
