Logik remote code for a l39fe12 required to link into virgin media remote
SOURCE: virgin media tv remote control
what you have to do is ring virgin and ask then to send the code.
this code is done stight to your set top box
Posted on Feb 08, 2008
IrishDruid
  • 2712 Answers
SOURCE: Sky+ remote code for the Logik LCX19LN1 LCD TV?
You can find the remote control codes for different brands of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the following steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through 6).
To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. - You can rate a solution with one of four ratings as explained under (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
Thank you for using FIXYA!
IrishDruid
Posted on May 05, 2008
charlygal
  • 136 Answers
SOURCE: eurovox max v virgin media bristol codes
PRESS THE MENU BUTTON FOLLOWED BY YELLOW BUTTON AND UL SEE BOXES USE UR REMOTE TO PUT CODES IN IT TELLS YOU AT BOTTOM SCREEN WHICH BUTTONS TO USE FOR WHICH LETTER CODES ARE.................
5A 01
98 B0 BA 52 D3 21 08 B4
D2 EA 29 B7 B5 52 E9 AD
HOPE THAT HEL[PS
Posted on Nov 29, 2008
SOURCE: tuning samsung tv into virgin media cable box
Make sure you have a Vigin Media branded remote control, then try your codes.
0079 Worked for mine.
Posted on Feb 28, 2009
SOURCE: commtel control freak 4in1 remote
have a 4 control freak uni remote lost booklet would like to down load one pls also have u code for remote media windows pc
Posted on Jan 21, 2010
How to change volume on vm202 virgin media alcatel
Virgin Media Remote Control Codes
www.virginmedia.com/.../vplus-remote-control-codes.php
Virgin MediaYou can set-up your Virgin Remote Control to operate the Volume and Mute functions on your TV so you only need one remote to watch TV. Firstly, please select ...Missing: vm202 ‎alcatel
Customise your TiVo remote to control your TV - Virgin Media
www.virginmedia.com/tivoremotesetup/
Virgin MediaTo clear your changes and reset your remote to its original settings: Press and hold down and on the remote at the same time until the light on the top of the remote flashes green twice. Press three times, then press. The LED will flash green four times and exit programming mode.Missing: vm202 ‎alcatel
Virgin Media VM202 review by 3G.co.uk
Dec 27, 2015 | Alcatel Cell Phones
Logik l39fe12. Why do various programmes have a voice over explaining what is happening?
What you are hearing is the secondary audio program (SAP). It is an option selected during initial set up. You have to return to that procedure and disable SAP.
Oct 24, 2015 | Televison & Video
I have URC2490 Total remote. The codes for my Logik TV don't work and the search for code has found nothing. Why is this so secret? Anybody have any ideas please?
Your Logik TV may require a code that the remote does not have stored in its code library. You may have to try a different remote but even with that there is no guarantee of success.
Dec 06, 2014 | Televison & Video
Logik TV codes
0281,0288.
Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts. Surf the site with patience.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Aug 11, 2014 | Televison & Video
Virgin code for logik tv to control volume ( and other functions)
Logik LED TV making a constant tapping/clicking sound.
try turning off AND unplug for a couple minutes! USB may have pulled power down to start the switching noise. Try usb again and if it does it again then I wouldn't use that usb anymore.
Jan 17, 2014 | LG Televison & Video
Need sky code for logik tv model no L39FE12
058,055,028,025. Try these codes. For more information http://electrohelponline.blogspot.com/ Setup procedure, and setup code list to many popular remote controls are given. Pull up older posts.
Dec 04, 2013 | Televison & Video
My Virgin Media Tivo Remote is not working with my Easy Touch 42 inch TV, I have not been able to find the Code on the Database, can anyone help ?
Since you haven't mentioned the EXACT model of your remote, I can't exactly tell you the instructions. BUT you may choose your EXACT remote and refer to the instruction / codes from this link:
Virgin Media Remotes
I hope this helped you.
You can rate my answer if you appreciate my help.
Thanks!
-damneddle
Oct 14, 2011 | Tivo Series 2 Remote Control
Virgin media remote control TV Control Codes Samsung LE37A558
just tried 0079 from another forum and it's worked for me!
Mar 11, 2009 | Televison & Video
Televison & Video Logo
176 people viewed this question
Top Televison & Video Experts
Electro Med Services...
