Question about Westinghouse Washing Machines
Hi, We have a Westinghouse washing machine LF652D with an error code that comes up"E50" . What does this mean and how do i fix it
SOURCE: Error codes
This code is suggesting a motor related fault. Check the brushes in the first instance.
Posted on Aug 31, 2007
  • 49 Answers
SOURCE: electrolux ewf 1435 washing machine
i can not find e50 in any of my servive manuals, are you sure it is e50 ?
Posted on Feb 19, 2008
kevin000
  • 1847 Answers
SOURCE: hi zanussi fjr 1254 w error code e90 what does
This error code seems to be the control board detecting a wrong configuration (in other words, an illogical set of sensing conditions, from its connected sensors and wiring). It apparently can happen, when wires become badly contacting, or if contaminated with motor brush carbon (the horrible black powder that comes off the motor commutator and brushes), or corroded from other contaminants from the soap dispenser area. You should be able to check this, remove, clean and replace the contacts:
Thanks
Posted on Jul 01, 2009
  • 174 Answers
SOURCE: ERROR CODE E50 SHOWING AFTER POWER SUPPLY INTERUPTION
It was probably your washer that tripped the electric . e50 relates to the motor check the carbon brushes they will be worn out. hopefully with new brushes you will be back in action. the programme wont start with a fault on the motor
Posted on Jul 24, 2010
FitzOriginal
  • 842 Answers
SOURCE: Hi my washing machine Electrolux
Oddly, the main site I use to find error codes skips from E45 to E51, but 2 other sources I have seen say:
eE50 is a motor error code.check the motor brushes are ok and check the insulation on the motor as this will give you an E50 error code (as could a water leak, dripping onto the motor).could also be a faulty wiring loom to the motor or a faulty main control pcb
E50- Insufficient heating during wash phase Either the NTC sensor setting is incorrect, the heating element has failed, there is a wiring or main PCB fault
In other words, this is a fairly generic fault code I'm afraid. I would check the motor appears clean and dry, but beyond this, you will need to do a fair degree of fault finding
Posted on Jun 23, 2011
How to solve e50 and e54 errors
Hi!
On Electrolux washing machines error e54 means the problem in the contact group of one of the two reverse relays. I would like to help you with the e50 error. What is your model of the washing machine?
May 12, 2017 | Washing Machines
Hi could you tell me what error code E50 means?
try adding a MAKE thru Google then error codes
Sep 28, 2016 | Washing Machines
AEG Lavamat 60810 keeps stopping and displaying error E50 and some time E70. What is the problem and how do I fix it?
Family error code E50 means a problem with the washing motor. Family error code E70 means a problem with the NTC sensor. In my experience, E50 is most common fault in worn carbon brushes. But in any case family error code E50 is shown to the customer. In service mode could be: E51,52,53 and 54. The same applies to family E70 error code that will be displayed in service mode as error code E71 or E74.
E50 error code could be: motor winding, power board, tachymetric generator, motor relay on power board, wiring between motor and power board and wiring between tachymetric generator and electronic.
E70 error code could be: faulty NTC sensor, wrong position of NTC sensor or to much limescale on it and finaly wiring between NTC and electronic.
Dado
May 05, 2015 | AEG Washing Machines
Simpson washing machine error message e20
i am having a problem with it draining, it turns and washes though, where is the filter?
Sep 29, 2013 | Simpson Washing Machines
My machine is beeping and flashing E50
Hi.
E50 means that the timer board is incapable to control the motor. This means that either control module,
motor power triac or motor itself may be faulty.
Try disconnecting power for five minutes, by either tripping circuit breaker or disconnecting power cord.
If the error comes back contact Zanussi at the number listed on the owners manual. The problem is often consequence of a factory defect.
Regards.
Ginko.
Aug 22, 2011 | Zanussi Washing Machines
Hi my washing machine Electrolux 6.5kg eco valve keeps showing E50. What does that mean? by the way my washing machine isn't working.
Jun 23, 2011 | Washing Machines
Error code E50, what does this mean? We select programme, all the lights are on, we press start and E50 appears. What does this mean?
e50 is a motor error code.check the motor brushes are ok and check the insulation on the motor as this will give you an e50 error code.could also be a faulty wiring loom to the motor or a faulty main control pcb
E50 says the motor is overheated, they recomen you let it sit for 30min to clear.
It can be the motor power supply triac has got a short circuit or there could be no signal from the motor tachometric generator, which will uaually mean a pcb fault, or wiring to motor or even the motor. hope this helps
Dec 13, 2010 | Electrolux EW1000i Front Load Washer
How much water to add to Westinghouse frontloader?
If you add too much, it will just drain until it reaches the correct amount to start.
Hope this answers your questions.
Nov 17, 2009 | Washing Machines
Electrolux ewf 1435 washing machine
Feb 16, 2008 | Electrolux EW1000i Front Load Washer
Washing Machines Logo
76 people viewed this question
Top Westinghouse Washing Machines Experts
Dan Webster
Dan Webster
Robert Siegel
Level 1 Expert
Steven Clarke
Steven Clarke
Are you a Westinghouse Washing Machine Expert? Answer questions, earn points and help others
