Question about Sony BRAVIA KDL-40S2010 40 in. LCD Television
Sony Bravia turns off by itself
My TV turns off by itself and the standby light starts blinking. You turn the tv back on and within 3 seconds it happens again.13 months after purchase, the power now shuts off by itself. When I unplug and replug, it turns on for only a few seconds, then goes back out. There is a blinking standby light. Four blinks, pause, four blinks...
  • 2 more comments
  • psmart Jan 13, 2009
    I don't think external wiring is an issue. I removed the TV from its cabinet and plugged it into a different outlet. One post mentioned replacing the "BU mount PCB." Is this still the best solution? And idea what this will likely cost, given that it is one month out of warranty?
    I have checked a few things are here are my results:
    Inverter board fuses check out good
    Power supply board Capacitor C6000 has shorted.
    Can someone tell me if I might be able to get away with replacing this cap alone, or is this way to simplistic?
    Thanks!
    Thanks for this advice. In fact, I just discovered that C6000 on the power supply board has shorted. I can probably replace it myself. Would you suggest that I do so, or is this just a symptom of a much larger problem?
    Phil
    problem?
  • 1,512 Answers
    Genius:
  • 1,239 Answers
Welcome to FIXYA! For the KV36FS76B, 4 blinks, pause, 4 blinks, etc. means "Vertical Deflection stopped" and the probable cause locations listed are as follows:
1. +15V is not supplied R8207 open (D1 board)
1. -15V is not supplied R8206 open (D1 board)
3. IC1701 is shorted (A board)
These are starting points for a qualified service technician.
Posted on Jan 13, 2009
    Master:
  • 623 Answers
It is the protection circuit cutting in and shutting off the set. This is because it detected a short or near-short circuit somewhere within the 8 or 10 sections of the set. Most common is high voltage, deflection amplifiers and main power supply.
You must know how to troubleshoot the circuit and systems in order to repair these kinds of set. You can get lucky, sometimes, by just probing around looking for something that does not look right.
If you are an electronics technician with some good skills I can give you better advice, but if not, you are better off seeking professional help.
if the set is over 3 or 4 years of age it is not a good candidate for repairs. Why? because it will just fail again, and again, and soon you will have spent so much time and aggravation you will have wished to have cut the losses and just replace it. Sorry, but that is the nature of tv sets once they start to fail.
  • 10,594 Answers
Though I have correct technical info about Sony Bravia by service manual but I'm sure, user will not see my solution / info as I'm 17th in que here.
  • 15,935 Answers
You can have the inverter board replaced...instead of the entire panel.
KDL 40S2010: inverter part # 178950032, you will also need 2 spacers..part # 289765511
you're looking @ 200-300$ for the inverter and 5-10$ a piece for the spacers.
KDL-46V2500: inverter part # A1251295B
you're looking @ around $500-600USD for the part.
May be wise to invest in another set!?!
  • 108 Answers
You have an issue with the viper ic located on the FB PCB, some models call this pcb the BU Mount depending on your model and serial number but replacing the part is pretty straight forward.
  • 818 Answers
  • Sergio Scalfaro
    Sergio Scalfaro Jan 13, 2009
    If you have already experienced this software issue, the television can
    be temporarily reset by disconnecting the AC Power Cord from the wall
    outlet, wait at least 30 seconds and then reconnect the AC power cord
    to the wall outlet. After this reset procedure, the television should
    work properly until another several months of use has accumulated.”
    upgrade the firware from the sony site for your tv
  • Sony Master
  • 19,396 Answers
First unplug for a while and leave the tv with no power for one hour or so.
Four blinks is backlight failure on Bravias.
All The :
No vertical Deflection
Power supply
New cord.
Main board
ballast
Are all wrong.
Let say that we are experiencing technical problems and experts are posting on wrong questions recently.
The converter have failed, or there is a problem with converter wiring/connector. also test backlight system.
The inverter must be tested, and eventually replaced.
On australian models four blink is PSU fault on 5V.
If you are in US is backlight fault
Here is the part.
Here full codelist:
1 blink abnormal AU Power Voltage
2 blink abnormal d5v/a9v power voltage
3 blink Abnormal panel voltage
4 blink backlight failure
5 blink abnormal main power voltage
6 blink abnormal speaker voltage
7 blink internal temp. rise
8 times ic5000
The list published before was for rear projection Sony, Sony LCD does not have the vertical Deflection descripted on the wrong codelist.
Regards.
  • Ginko
    Ginko Jan 13, 2009
    oops, Errata,
    where I wrote converter I meant Inverter.
    The inverter board is a circuit that receive DC power, and returns variable higher voltage on AC to the lamps.
    On your TV it may had blown, if the TV received a shock or had been moved recently, the connector may have slipped, but that is uncommon.
    Contact sony to check if they offer warranty extension to cover the repair, otherwise call a local technician.
    See: Sony Global - "Contact Us"
    About the converter, well I am starting to think that ignorance is contagious.
    Have a nice day, and good luck.
    Sergeant:
  • 378 Answers
Sony  BRAVIA STANDBY BLINKING CODES
8 times ic5000
  • 405 Answers
I have had this problem on a couple of sets, everytime it ended up being a power supply problem, Capacitors or a bad transistor, zener diode, regulator, etc. Best thing to do unless you know alot about electronics and soldering, you should just by a new power supply board.
  • 505 Answers
4 red blinks = backlight error
this is caused by a bad inverter that lights the backlight
if it is really 13 months old call Sony and they'll hopefully help with the repair, they want happy customers..
CALL sony @ 1-800-222-7669
make sure you have:
model #
serial #
date of purchase/bill of sale
If you make a good case to them they might help with repair.. otherwise, you need a new inverter board, or worse case, a new LCD panel (hope not)
    Brigadier General:
  • 8,619 Answers
Hi!
The main board of your TV needs to be replaced
Thanks
Rylee
  • Rylee Smith
    Rylee Smith Jan 13, 2009
    Purchase the warranty thru a 2nd party for less - i.e... extend4less.com
    Sergeant:
    Novelist:
  • 326 Answers
  • Unit is dead, No blinks - Problem in the standby power section. Might check fuse, R607, Q601, IC601, R612 and VDR601 (should show open).
  • Continuous blink once a second, no pausing - No reply from the jungle IC301 data bus is busy, shorted to ground, or held high), IK video path is defective.
  • One blink - not used for the self-diagnosis
  • Two blinks - B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
  • Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
  • Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505 on the board and replace.
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
  • Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206.
  • Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
  • Eight blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401, and 402. On some projection models of Sony TV sets, this code means that T8005 (flyback transformer), or the associative components in the high voltage circuits are defective on the D board.
  • Nine blinks - Replace D 6116 and D 6301 on the "G" board, do not resolder as this will fix the problem temporary. Or Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing, then change the switching regulator on the "G" board or check connections. Make sure the regulator is -12 or -13 (negitive).
  • Ten blinks - Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" board.
  • 716 Answers
Bad Inverter Do You Have A Warranty?
Posted on Jan 12, 2009
    Scholar:
  • 111 Answers
First up unplug the TV and leave it for 10 seconds then plug it back in to assure it is not a basic voltage error within the TV,
Check all Cabling around the back - In particular the power is secured.
Is it on a poerboard of any description? If so plug it directly into the wall to test if the powerboard has fried or not
Have there been any storm around your area lately?
May I also ask for the model name of your TV?
Take care,
Blazamane
  • Curtis Tuendemann Jan 12, 2009
    Also if you can plug another device into the wall socket your TV plugs into to test it is functioning appropriately
    Sergeant:
  • 221 Answers
It clearly the indicates the problem of main board getting short due to any of its capacitors or ic getting overheated and shutting off the tv .the board has to be checked by a meter to locate the faulty component and that has to be replaced.so it will work.
    Genius:
  • 1,199 Answers
The blinking code lifgt most lilely means a power supply problem! Replace ballest transformer!
  • 75 Answers
It could be a problem with the wiring. I assume there are other appliances plugged in around this, it could be a short circuited wire. It could be anything, with the details you provided, you could either buy a new cord/wire or call out a repair man.
    Genius:
  • 1,847 Answers
Seem issue with the power supply...
  • Legin Varghese
    Legin Varghese Jan 12, 2009
    If the Tv is in warranty, I would suggest to use it instead of opening the back cover, that might void the warranty.
    the second issue see is The back light inverter board might be defective or the voltage from the power supply (+24v) is low or missing
    Top Expert:
  • Sony Master
  • 77,499 Answers
All this advice boils down to one issue, the main circuit board is shorted and will have to be replaced, about $600 with labor and then what next? buy a new LCD, they are really cheap, for a 42" screen as little as $699
Sony Projection Televisions - HOW TO FIX TV Red Blinking light of times between 3-second intervals and turn off
I have a Sony Bravia. Smart Television that would not turn on once in standby mode. The Red light would blink twice. I unplugged the television and reconnected it using a surge protector power supply strip. This solved my issue. From now on I'll be sure to turn the television off instead of allowing it to turn itself off.
May 01, 2014 | Televison & Video
Sony bravia blinks 6 times
i have a Sony Bravia LCD TV KDL-60EX645
and it Blinks about 6 times every 25 seconds and it blinks next to the "Power" symbol? what does that mean? i cannot turn on the tv because it turns of and its not on eco and i just got it for christmas. its a 55" and i have a 3 year warrinty. but do i need to pay for it, or will it turn back on later ive been waiting about a week? i am a major gamer i usually spend 14-16 hours using the tv i am a youtuber, but does it burn out? i know alot about tv's but im not used to this error... i need some help so please contact me at Alexcromwell1@live.com
Please help me. i might seem like a slacker but actually i make money of using the tv. thankyou for taking the time to read this and try to help me please. thankyou -Charles
Apr 24, 2012 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
My Sony Bravia, model KDL-46XBR4's standby light is flashing 6 times. We have reset it 3 times but after several days it shuts down and continues to flash the standby...always 6 times. Can anyone tell...
I am experiencing exactly the same problem. TV turns on but within 60 seconds the screen goes black and the red standby light blinks six times. Were you able to resolve this problem on your TV?
Oct 17, 2010 | Sony KDL-46XBR4 46 in. LCD Television
Tv turns on then turns off and the standby led starts blinking
Standby light blinking is sign or internal problem in tv and how many times it blinks is error code that will show what section of tv got problem. Count light blinks and let me know, there would be 3 seconds long pause in blinks so count pause to pause.
Jul 13, 2010 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
My Sony Bravia will play for less than a minute and then reverts to standy. Any suggestions?
Please unplug tv from wall socket for minute or so,, replug back in and turn it On.
If tv still goes to standby itself than its standby light would blink to show an error in somewhere inside tv circuits.
Let me know how many times standby red light blinking? There would be 3 seconds long pause in blinking so count pause to pause to determine problem section.
Thanks.
Jun 13, 2010 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
40'' Sony Bravia goes into standby with the light blinking 9 times
I finally managed to solve this problem by unplugging everything - scarts - HDD cables - power etc and left it for an hour. When I turned it back on again the problem had sorted itself out.
Sep 30, 2009 | Sony Televison & Video
KDL-40XBR3 turns itself off; STANDBY light flashes 9 times
sony 52 inch tv in stand by mode comes on and off on its own
Jun 01, 2009 | Sony BRAVIA KDL-40XBR3 40 in. LCD HDTV
Replace the BU Mount pcb. Sometimes they are called the FB pcb.
Jan 08, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Sony BRAVIA KDL-40S2010 40 in. LCD Television Logo
2,365 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
