Question about Mitsubishi 938P019010 Color Wheel
Where can I find a mitsubishi WD73927 color wheel
2 Suggested Answers
  • 98 Answers
SOURCE: Where can we buy a light engine for our Mitsubishi
From Mitsubishi parts, 18005537278.
Posted on Jan 18, 2011
How do I open the housing to the color wheel of a Mitsubishi dlp wd65735? The tv has been doing constant flickering and we've checked everything out but the color wheel and can't access it.
Usually the color wheel makes a loud whine noise when it starts to fail or they shatter because they are thin glass. The problem is not likely to be the color wheel. On a previous post I alluded to a problem with the lamp socket. If it is not the lamp then you need to check the power supply for failing components.
Feb 10, 2017 | Mitsubishi Televison & Video
My Mitsubishi 73 in SDLP works fine for about an hr then turns green and starts jumping. I can turn it off and back on and it's good for about 15 mins. If its off for a while it starts within a hr
Hello. When the picture changes color after warming up, chances are that the color wheel is defective. If you get close enough, you might be able to hear a whining sound. If you do hear a whining sound, you definitely have a bad color wheel. Some color wheels are still available from Mitsubishi. Good luck!
Jul 31, 2016 | Mitsubishi Televison & Video
I have a Mitsubishi 65" dlp TV and the picture is green and yellow with no reds or magenta's so would that mean i need a new bulb or does it have something to do with the color wheel
It means that the color wheel or it's encoder is not properly syncing with the controller. It is therefore blanking the DLP chip on the red and blue sections of the color wheel. Clean the color wheel motor and encoder disk, lubricate the motor. This should correct the problem. There may be dirt in the opto-coupler that is reading the color wheel. Be sure to clean it with a vacuum and small brush. Regards.
Nov 28, 2015 | Mitsubishi WD Televison & Video
WD73927 sound cuts off but picture stays
try the soft reset this model should have with set on Menu,1,2,3 enter.
Nov 29, 2012 | Televison & Video
WD-60638 COLOR WHEEL PROBLEMS
Usually the wheel is not available except with a Light engine.
Aug 31, 2012 | Mitsubishi WD-60638 DLP TV
I need a new color wheel WD52527 where do I get one It has been replaced once already while under warranty and is now doing the same thing
Try website like Tvrepairworld.com have it for $229 Mitsubishi colors wheel.Make sure the same exact colors wheel model as ur tv model ok and u have the skills and know how to do it ur self.These colors wheel are deligate part and can be damage easily.If not sure about it and can or can't do it.Hire a tech. to do it.These colors wheel are spinning at 1200 RMP if u put in wrong the colors wheel 50/50 can be damage the place u buy it from will not take it back.
Aug 30, 2011 | Mitsubishi WD52527 52" Projection HDTV
Mitsubishi WS-65611 has a blurred image with the colors creating almost a double image. was told it might be a color wheel. Should i order a new one? Best Buy said it would be a $150 house call to...
The model number you have posted does not have a color wheel at all.
If it is WS-65611 go into the customer menu and select convergence--if it is 3d and will not adjust there--you have a convergence problem.
I HAVE AVAILABLE START TO FINISH, STEP BY STEP INSTRUCTIONS for replacing this part in this set--available here for free.
If someone told you it is a color wheel and you have the correct model number here posted--they are not very smart--this model does not have a color wheel and the later Mitsubishi sets that did have one--they do not sell the color wheel for them.
If you want the instructions let me know and I will post them here for you. I have repaired hundreds of these sets and the instructions are based on actual experience doing this repair.
If this has helped you rate this solution as I do this here for free.
SD TECH
Dec 14, 2009 | Mitsubishi WS-65611 65" Rear Projection...
DLP TV - After warm up - colors smear
Did you ever figure the problem out? My TV is doing the same thing.
May 11, 2009 | Mitsubishi WD-73927 73" HDTV
Mitsubishi 938P019010 Color Wheel Logo
21 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
