Question about Kenmore Washing Machines
My kenmore front loading washer mod 769 40272900 wont come on. recectacle that its pluged into is working fine but still no power? any sugestions?
Masher was working fine and when i went to change the load of clothe and it wont turn on . the rececptacle it is pluged into is working fine. I cleanrd out the filter at the bottom and still not working.
SOURCE: Kenmore Front Load Washer Problem
Pump may be plugged.Take off back Locate pump remove hoses. Check pump spins freely, remove debis. Mine had a hole in the basket gasket sealt hat let debis get in the pump. Good luck
Posted on Nov 02, 2007
  • 1294 Answers
SOURCE: kenmore elite washer top loading 6 years old clothes still wet after spin cylce
Click on 'washing machines', then brand name (below FIXYA) on this website, type in your model number & search. You will get a shortlist; click on your model,below the page u will get Manual/Guides. Click on the blue, you have your manual on line. Possible your filter is clogged after these years.
And dont forget to rate me on this great site.
Posted on Jan 21, 2008
  • 277 Answers
SOURCE: Kenmore front load washer will not spin. Clothes come out wet.
The clothes are wet after spinning When the clothes are wet at the end of a cycle, check these:
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
  • If it's spinning when you lift the lid, the coupler is fine.
  • If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Posted on Mar 02, 2009
SOURCE: kenmore front load he3 washer: door wont unlock
happened to me once - I just unplugged the machine - waited a minute and plugged it back - it - then used cancel button
jsrock516
  • 5911 Answers
SOURCE: removing front panel from kenmore elite HE-3 front load washer?
If you've removed the screws and the panel sticks, tapping on each side will knock it loose. The panel should drop down, then off. You can also try propping the two front feet of the washer up slightly for better access. A 2x4 works real well. This will allow more room for the panel to drop and gives better access to the screws. The washer is very heavy, so you may need some assistance to lift the front. Either lift from the bottom, or place your hands on the front facing of the cabinet to push the washer back. DO NOT push on the door or control panel.
If you still need assistance, please let me know. I hope this helps you.
Posted on Jul 05, 2009
What is F2t means on Kenmore front loading washer Mod. 11047571602
Check the trouble shooting section in back of the instruction book, It could be anything
Oct 31, 2014 | Kenmore Washing Machines
Kenmore washer MOD 110.24422300 SER CP4427442 the washer wont spin, it makes a harsh and loud noise when it comes onto the spin cycle.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Oct 20, 2010 | Kenmore 12502 Top Load Washer
Kenmore mod. #417.44092500 high speed spin doesn't
replace speed control board located right rear base of unit
Sep 12, 2009 | Kenmore Washing Machines
KENMORE MODEL 110 WASHER WONT DO ANYTHING, JUST DEAD
you need to make sure you have power comeing out of your wall socket first. then let me know. also is any of your lights on your display lite up?????? control lock?????
Jul 24, 2009 | Kenmore Elite 45986 Front Load Washer
My washer wont drain
Either your pipe to sink is clogged or nearly clogged or the pump on the washer is about to give out. Does the water spray out vigorously when using the container, or does it just flow out?
Jul 02, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore Elite Catalyst Mod. 22052
Oil is no problem. The door switch/interlock is faulty. Replace door interlock. Try closing the door firmly with an extra little shove on the door handle. Sometimes this works.
Oct 30, 2007 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
48 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
