Question about Horizon AFG 5.0 AT Treadmill
How to lube belt for AFG 5.0 AT treadmill - Horizon AFG 5.0 AT Treadmill
4 Suggested Answers
SOURCE: horizon treadmill won't start running
The manual said that after lubricating the deck, press Stop and Speed buttons together for 5 minutes and this will reset the lubrication message and the treadmill should work.
Posted on Aug 22, 2010
  • 14 Answers
SOURCE: treadmill says to lube belt,
Horizon treadmills need a silicon lubricant, placed between the underside of the walking belt and the deck board that it slides across. This should be done about once a year ;o)
Posted on Oct 25, 2010
ercupa190
  • 12223 Answers
SOURCE: how to fold my afg 5.0 treadmill for storagae
Dear Sir: Hello , i hope everythign is o.k
Please do the following:
FOLDING Firmly grasp the back end of the treadmill. Carefully lift the end of the treadmill deck to the upright position until the foot lock latch engages and securely locks the deck into position. Make sure the deck is securely latched before letting go. To unfold, firmly grasp the back end of the treadmill. Gently press down on the foot lock latch with your foot until the lock latch disengages. Carefully lower the deck to the ground. NOTE: on some models the foot lock latch might be on the right hand side. NOTE: when folding the Horizon Fitness Treadmill the console assembly will tilt away from you, but will return when fully folded in the upright position. Please allow two additional feet from wall when folding.
Thank you in advance, sincerely. Blessing.
If you need additional help, please contact me.
e.cuadra Managua, Nicaragua C.A.
Posted on Sep 26, 2011
Where does one lube the belt on this treadmill?
Belt is the surface you walk/run on.lift it up in the Centre and spray lube on the board belt runs on
Jan 08, 2015 | Exercise & Fitness
My Horizon T80 treadmill is emitting a smell after operating a while not an electric smell but a rubber chemical smell
How old is the walking belt? When was it last replaced? How many miles are on the belt. Seem like your belt and deck is worn.
Jan 01, 2014 | Horizon T92 - Treadmill
Treadmill
Sorry, but the description does not indicate what type of machine you are looking to purchase.
Assuming it is a trealmill? Not all machines use belts which need to be lubed any more. AFG (Advanced Fitness Group) uses a belt deck combo which is pre-impregnated with lube for the estimated life of the belt. Landice does not suggest any lube for their standard home use treamills but does make Slip Coat if an additional application were needed.
Traditionally, you loosen the tension on the rear roller so you can access the laminated deck, on which the belt slides on top of. Specific to each brand or model of belt, you will apply either a wax or silicone lubricant. They are usually supplied in a single "dose" or application volume. Apply the lubricant to the deck, retension the belt and start the machine at a slow pace to evenly distribute the lube.
If you were referencing an ellitical, most manufacturers just want the track or beam to remain clean. Cleaning with a light solvent with usually remove any built up. I have found White Lightning (make) Clean Ride (model) wax based lubricant can resolve any noise a good cleaning cannot fix.
Jan 08, 2013 | Exercise & Fitness
My Reebok v6.80 treadmill turns and lights up but won't go.
1) LUBE the deck belt,you have a WORN deck belt, this happen because you didnot lube according with the schedule maintenance
29 LUBE the rollers bearing too
3) Test the drive belt motor, for worn or crack, or adjust if is possible
4) Test the input voltage motor, if there are the motor need repair
5) Test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
God bless you
Nov 28, 2012 | New Balance 1400 Treadmill
Treadmill doesnt want to start
1) LUBE the deck belt, maybe you have WORN deck belt by lack of lube and maintenance.
2) LUBE the rollers bearint you must do it after 5 hours of use.
3) Test the drive belt for loose or faulty.
4) Test the input voltage motor, if there are voltage the motor need repair, see my personal TIPS.
5) TEST the output voltage board, for input voltage motor, if there are NOT voltage, the board is faulty. see the block diagram.
Nov 23, 2012 | True Technogym Excite Run 700 Treadmill
Belt sticking
LUBE inmediatel the deck belt, maybe you have a WORN deck belt. You must lube the treadmills after 5 hours of use, is the maintenance normal.otherwise you will the problem now you have.
2) LUBE the roller bearing too.
3) test the input voltage motor, if there are the motor need repair.
4) test the output voltage board, for input voltage motor, if there are NOT the board is faulty. See my personal TIPS for troubleshotting motor.
God bless you
Nov 22, 2012 | Nordic Track Nordictrack C2100 Treadmill...
Treadmill 91ti lifefitness is making high pitch noise as belt starts. Is anything wrong.? Should I use the the treadmill with this nose.
No do not use, until YOU LUBE. This happen because you must do it every 5 hours aprox of use, The machine protect itself the electronic system and shut down.Maybe the deck belt is worn.
2) LUBE the rollers bearing very i
3) test the drive belt, and test too the bearint of main motor and fix it.
God bless you
Nov 19, 2012 | Life Fitness 95Ti Treadmill 95 Ti
I have a roger black treadmill the belt stops working after 5 - 6 minutes, the display still continues counting as normal, I have to wait for acouple of hours to start it again to last for 5 mins. please...
1) this a problem by lack of LUBE maintenance, you must LUBE about 5 hours continuosly of use. Otherwise you may have a worn DECK BELT, and time to replace. By that reason the treadmill shut down, to due the software has protection itself for electronic system
2) LUBE the rollers bearing.
3) test the bearing from the main motor, and replace too.
God bless you
Nov 14, 2012 | Exercise & Fitness
Making a loud whirring noise when running.
hi i think that the running belt is too loose and touching the underbody of the treadmill, if you can have a look underneath.
Nov 15, 2010 | Horizon AFG 3.0 AT Treadmill
My roger black treadmill keeps tripping the eletric
This could be a lubrication issue if this treadmill has never been serviced or worn belt/ deck. The last thing I am thinking about is if the unit is turned on with nobody on the unit and trips the the breaker then you have a shorted lower board.
1. Inspect belt and deck. The deck should be smooth. The belt should have a consistent feel from side to side (a belt can be worn out without any sensory signs of a problem). If you feel deep grooves in the deck or uneven wear on the underside of the belt, part replacement is necessary. Continued use of your treadmill may damage expensive electrical components. 2. To inspect the belt and deck visually or to clean underneath the belt before applying lubricant, the belt must have the tension reduced. Loosen the tension roller by following the instructions in your owner’s manual. Do not loosen the bolts in the tension roller too far or the bolts will come out of the roller shaft. This step may not be necessary for your treadmill model or belt and deck condition. 3. Contaminants are the worst enemy of your belt and deck. Some treadmills may have an excessive accumulation of dirt and contaminants. If these are trapped during the belt lube process, significant damage will occur. If contaminant removal is necessary, loosen the belt by following step 2, lay the treadmill on its’ side, and use a nylon brush to loosen contaminants that have accumulated on the inside of the belt. Clean the deck with mineral spirits in a well-ventilated area. Allow the deck to dry before lubing or tightening the belt.
4. Lift the belt and use approximately ½ of the tube by squeezing the lube in the walking area lengthwise. Move to the opposite side of the treadmill and repeat using the remainder of the lube. Use all of the contents of a single container during application. Do not put any lubricant on any surface with which your feet make contact. The lube will spread evenly in the next step. Do not perform this step by hand. The lube is usually not harmful to the skin but has the potential to permanently stain fabric. 5. Adjust belt tension and centering following your owner’s manual instructions if you have loosened the belt to clean. LOOSENING THE WALKING BELT IS NOT NECESSARY JUST TO APPLY THE LUBE. Start the treadmill at 2-3 mph and allow to run for 5 minutes without walking on the treadmill. Check centering carefully and adjust as needed following your owner’s manual instructions. Using your treadmill’s handrails and safety switch for safety and support, walk on the treadmill at 2-3 mph. CAUTION!!! BELT MAY HESISTATE. THIS CAN CREATE AN INJURY IF BELT IS NOT PROPERLY TENSIONED! Within 5 minutes the lube will be preliminarily walked in to the backing of the belt. Damage and/or injury may occur if the belt is not properly centered and tensioned by using your owner’s manual. 5. CAUTION: Do not run on the treadmill until your are certain the belt tension and centering is correct according to your owner’s manual specifications. Make certain that there are no friction.
Go on E-Bay you may purchase a kit or a single application all of them are a silicone base lubricant so don't worry about which is the best. The application will also determine if the visual inspection and cleaning did the job and if the breaker trips then you have a belt and deck issue.
Jul 18, 2010 | Exercise & Fitness
Horizon AFG  5.0 AT Treadmill Logo
Top Horizon Exercise & Fitness Experts
Electro Med Services...
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Are you a Horizon Exercise and Fitnes Expert? Answer questions, earn points and help others
