Question about Iomega 1TB Desktop USB 2.0 Hard Drive
Need to buy iomega gdhdu2 power supply
Require 12V 1.5A output power supply
5 Suggested Answers
  • 72 Answers
SOURCE: MDHD320-U Power supply
No. You need to supply the same or higher amps than the device uses. Otherwise, the powersupply can burn and cause fire.
Posted on Jun 17, 2009
Chinthakaj
  • 416 Answers
SOURCE: iomega 500gb power supply failure
if it's 6 months old, you should be still having warranty, suggest you take it back to where you bought it from.
Posted on Jul 18, 2009
SOURCE: i want to seperate the
Hello, nappindylan.
With a screwdriver, you will be able to remove the shell, revealing your internal hard drive.
You will then see two cables, pull these two cables from the internal hard drive. There may also be further screws holding down the hard drive inside, remove those, as well.
You will then be able to pull the hard drive out from its case.
Please let me know if you have any further questions.
Posted on Mar 14, 2011
bronk50
  • 27725 Answers
SOURCE: I plug this devise into
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems also make sure the computers Ram and Cmos battery are securely seated
if this fails to fix the problem
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
hope this helps
Posted on Sep 15, 2011
Need a power supply for a linksys WRT546 What are the voltage requirements for this model?
The Linksys WRT54G requires a DC power supply of 12V.
You can purchase this power supply from any electronics store or online vendor.
Mar 07, 2011 | Linksys Wireless-G WRT54G Router
My IOMEGA 1TB Hard drive (Model GDHDU2) is not recognized by my computer. It does not shou-up in "My Computer".
have you tried a different usb port like maybe one of the ones in the back. sometimes usb ports go bad due to prolonged use and sometimes they short out so try a different usb port it should work then. if it doesnt make sure that you have the right software for the usb ports. also you might want to make sure that the barcode scanner driver is the right one and its installed correctly.
Dec 09, 2010 | Iomega Computers & Internet
I NEE TO BUY NETGEAR POWER SUPPLY (OUTPUT 12V 1A)
Hi
You can take this adapter any elictrical shop,and asked them to give 12v adapter,if you show them adapter that will help you get the correct one
Hope it will resolved your query
Thanks for using Fixya
May 24, 2010 | NetGear Power Supply
Power coverter to scanner failure.which unit should i buy? present one 240v 50/60hz.0.4A. output 12v.dc.i.25A
I just found my Canon 5000F scanner to have a power supply outputting 3V DC instead of 12V DC. I replaced it with a 12V DC Power Supply from Tandy rated at 1.5 amps. I had the scans getting darker by the day and sometimes completely black. Now I have great scans again. Just test the voltage at the plug that supplies the scanner for a healthy 12V DC with a multimeter.
Jan 20, 2010 | Canon CanoScan 5000F Flatbed Scanner
Iomega 500gb power supply failure
Jul 18, 2009 | Iomega MiniMax Desktop - Hard drive - 500...
Jun 17, 2009 | Iomega 33089 250 GB Hard Drive
I have a Iomega 250GBExternal hard drive. The pins that connect to the hard drive via the adapter pack have broken. The serial number is 579233448 the model no is DA-30C03 and the p/N is 31426900. I wanted...
i have the same probleme . I have a Iomega 250GBExternal hard drive. The pins that connect to the hard drive via the adapter pack have broken. The serial number is 579233448 the model no is DA-30C03 and the p/N is 31426900. I wanted to know which is the correct product to buy please
Sep 08, 2008 | Iomega (33090) 250 GB Hard Drive
Iomega 1TB Desktop USB 2.0 Hard Drive Logo
Top Iomega Computers & Internet Experts
Arora Singh
Arora Singh
Starnley Johnwells
Starnley Johnwells
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
