Question about LG Washing Machines
Repair manual for LG Front loader washer WD-1238C
Repair and parts manual
SOURCE: Front Loader LG Inverter 7.5kg WD-1238C
CL is about the Child Lock which is done by pressing both the buttons together. To release the same do press both the buttons under the display simultaniously.
Posted on Jan 19, 2008
  • 351 Answers
SOURCE: LG Front Loader WD-8074FHB
sometimes you just have to force the door but first try hitting the machine near the door lock sometimes this helps the door interlock may be stuck in the closed position
Posted on Mar 02, 2008
SOURCE: Washer LG Model WD-8013F Noisy & vibrates badfly when spinning
I had same problem, the bowl is supported by (2) large springs from the top & two telescoping shock absorbers underneath.
I inverted the machine, found a large hollow retaining plastic bolt had falled out of the shock absorber,causing the bowl to be out of balance & the drive belt to be missaligned.
I reinstated the plastic retaining pin/bolt then tried the machine again.
Now the damn thing refuses to wash or spin.
I'm not happy.
Posted on Nov 06, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: LG WD-3243RHD Front Load Makes grinding, crackling noise
Check the motor at the bottom of the machine. Also check the timer on the unit to make sure the timer is work
Posted on Feb 10, 2009
blueextc3221
  • 15935 Answers
SOURCE: the front loader for lg washer won't drain
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 11, 2010
Where can I get a service manual for a lg 7.5kg front loader washer model WD12020D
http://servicemanuals.pro/servicemanuals/lg/service_manual/home_appliance/washing_machine/wd/wd12020d/finish.html?m=0
Mar 25, 2015 | LG Washing Machines
Wiring diagram for kg80490np washing machine front loader
More details required. i.e kg? np? Brand name enter minimum details in Search box should show up and suggest.
Good Luck
Feb 03, 2015 | LG Washing Machines
I have a LG WD 1238C Front Loader Washing Machine and the display has a CL on it.
Remove power for some time , allow the power to drain off the memory and see if the display is clear. If not hold the start button and switch on power. Check the inlet and drain filter , free water flow, if not remove and clean.
Nov 01, 2013 | LG WD-1280FHD Front Load Washer
I didnt get a users manual with my lg WD-1238c front load washing machine and only no how to use the quick wash cycle, where can i get the information i need to use it?
go to LG's website and start there. If it's not available ther, Google LG (model) user manual. There you will find plenty of links to websites that offer manuals.
May 08, 2011 | LG Washing Machines
We bought our LG WD-1238C Front Washer a couple of years ago. I was sure that it use to beep with every turn of the dial but now it doesn't. We have just had the door replaced and the guy said he also...
Don't know whether it should beep or not -- is this causing the machine not to function normally. Are the clothes dirty and wet when the cycle is over? If not, I would say it's not important.
Apr 29, 2009 | Washing Machines
Error display "CL" - what to do?
THe child lock is on. Mine came on for some random reason. On my LG front loader there is a button on the right hand side with a cartoony picture of a child and a padlock. Press this.
Jul 04, 2008 | LG WD-1280FHD Front Load Washer
Dec 02, 2007 | LG WM-2277HW Front Load Washer
Washing Machines Logo
29 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
