Question about AEG Lavamat 16810 Front Load Washer/Dryer
My Lovamat washing machine displays warning E94
I am Unable to set control panel on to any washing sequence on my Lovamat washing machine due to error sign which displays warning E94 and suggesting that I refer to the instruction manual. But the instruction manuals do not list error or signs of possible problems with the washing machine. What does this mean?. My Lovamat front loader washing has suddenly stopped wringing out the water in the clothes also. What is the fault?
2 Suggested Answers
SOURCE: PC board of Lavamat 42260 Top Loader washing
Found that the water heater is giving low insulation resistance. It is being replaced by a new one.
Posted on Apr 15, 2009
I have an error code of E94 on my intex portable spa what does it mean?
If alarm code E94 is displayed on the control panel, it means the water temperature is too low. If alarm code E94 appears, unplug and plug back in the GFCI/RCD and test the GFCI/RCD to restart the system when the spa water temperature is higher than 39?F (4?C).
Jan 25, 2016 | Intex Pool & Spa
Why Is WHIRLPOOL Duet & Duet HT washing machine showing F/11 error code on...
The error F/11 is shown on the display due to Serial Communication Error detected in the washing machine.
In this problem check the Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) .
This will Help.Good Luck.
on Mar 11, 2010 | Washing Machines
Why Is WHIRLPOOL Duet & Duet HT washing machine showing F/07 error code on...
The error F/07 is shown on the display due to Motor Control Unit Error in the washing machine. The motor speed is not getting detected by the control board in the machine or there is a confirm short in the motor control unit.
Model EWF1048W. Won't start. What does error e94 indicate?
E94 - Washing cycle configuration error.
Incongruence of configuration values at the switching on of the appliance. Check that all the connectors are inserted correctly.
Possible configuration error. Replace the circuit board.
Dec 12, 2015 | Electrolux Washing Machines
Electrolux time manager 7kg washing machine keeps stopping mid cycle and has an error code E94
E94 means: "Console control problem. Replace control board."
However fault codes are not absolutes. They simply tell a service person where to look for a problem. For example, if i was a service man and i had a control board like yours on the truck i would switch it out first to see if it solved the problem. If it did i would charge you for the part and labor and be on my way, even if it was just a loose wire or connector that was causing the problem. Or if i was a washer warranty rep and the machine was under warranty and you said you were getting an E94 fault code i'd ship you a control board and consider the problem solved.
I am not a service man or a warranty rep so my advice is to wiggle the wires going to the control board. Also, disconnect then reconnect any plastic conectors you see. Let me know.
Jan 30, 2013 | Electrolux Washing Machines
Washer will not let me select correct spin speed or wash temp
Possible that the main control panel is defective and so the programs are not being set or memorized. It can be failure on the memory or the processor or the logic gate within the IC that does not proceed in sequence .Hence the program is not selected or is run.
Try to swap a similar board to confirm before you invest.
Jul 01, 2012 | Hoover Washing Machines
FL code on a Calypso Whirlpool washer
FL= Flood Condition
FL flashes if any overfill condition
occurs. This condition occurs when
excessive water in the tub causes the
overfill switch to trip. The control must
realize that the trio was due to an
overfill condition instead of a suds lock
condition in order for FL to be displayed.
With an overfill condition, the beeper
repeats a warning every 10 seconds with no
time out. The pump is cycled in drain mode
for 30 secondson 30 seconds off untill the
overfill switch resets or power is
discontinued to the unit.
Note: Press STOP/CANCEL to clear display on all error codes
Causes of flood condition. Inlet valves
stuck on, Sediment in water level pressure
Other codes:
PF power failure
Er control lost settings during PF
LF Long fill Clogged inlet screens
CE Com error between motor and control
Ld Long drain Clogged/slow drain/pump
CA/CI Motor amping up
ob off balance load
Sr relay failure no control to motor
LS Lid switch no signal from lid switch, error occurs if the motor and control disagree as to the position of the lid switch. Usually means corosion is buit up in the switch and the motor knows the lid is shut but the control does not. Cose appears when start button is pressed.
open lid= flashing display time If the lid is opened time remaining flashes in display. Close lid and press start to continue.
SL Suds Lock Current draw on motor is sensed by motor control and a suds lock is declared The control trys 3 times to fix this by doing a mini cycle, SL is displayed if the unit was unable to correct the problem. This problem is caused by:
Bad pump
Extra heavy load
Excessive detergent
or Excessive suds/wrong stuff
Feb 04, 2010 | Washing Machines
PC board of Lavamat 42260 Top Loader washing machine. (Automatic) Washing Machine stopped on cycle and displayed E94 on panel.
Apr 14, 2009 | AEG Washing Machines
AEG Lavamat 16810 Front Load Washer/Dryer Logo
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
