Question about Roper Dryers
Drum turns no heat roper gas dryer model rgd4400vq1
the dr
  • 447 Answers
SOURCE: No Heat on Whirlpool Gas Dryer
The timer should advance in the time dry cycles if it does, it is fine Its common for them to not in automatic cycles when there is no heat I would call for service unless you have basic gas appliance knowledge , as it is dangerous If you decide attempt i can tell you what to look for Please rate my help .....Thanks
Posted on Oct 03, 2007
onthejob5130
  • 640 Answers
SOURCE: dryer tumbles, no heat
its a gas dryer it doesnt have ,,heating element...replace thermal fuse
Posted on Dec 28, 2008
  • 11 Answers
SOURCE: GAS DRYER WON'T HEAT
you need to check to see if the egnitor is comeing on do you see a orange glow in there if not you will need to replace the ignitor
Posted on Mar 24, 2009
TheMobilian
  • 8220 Answers
SOURCE: roper dryer model res7648kq0. wont turn on or heat ?
On the back side of the dryer sits the heater and various safety clixons. Any of them that would be OPEN ( no continuity) would be the problem. Here are some repair pictures
Posted on Jul 25, 2009
hunter19_46m
  • 7482 Answers
SOURCE: I have a Roper Dryer Model REX3514PQO. The dryer
Sounds like you have a broken drum belt.
If you have to replace your drive belt and if you have a front loading machine.
First you will need to unplug your dryer from the electric.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley.
While you have the drum out, I would also recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
If the belt is not broken, then I would check to see if the timer switch is working properly, if not then you may need to replace it.
Good luck,
I hope this helps
Posted on Oct 06, 2009
Roper gas dryer model rgd4440vq2 drum turns no heat have front off checked for power seems to be good i can only think the igniter is bad do you have a pic of part so i can compare it please!!!!!
YES!
If you will type in "Sears Parts" you will be given a place to enter your model number.
I tried it and it came up as"not a good number".
You try it.
That web site has complete diagrams for all machines.
Be blessed.
Feb 23, 2013 | Roper 29 Gas Dryer
The drum turns. It heats up. But only small loads of cotton get dry! We have changed the vent tube. Vacuumed the vent the lint catcher area and around the drum to remove lint and hair. Still not...
A very typical problem with GAS dryers is the soloniod coils that open the gas valve . When the coils are cool they operate just fine,but once the dryer gets warm from running the coils dont open the gas valve wwhen they are warm. If that is what your experiencing,the dryer heats when its cool but doesn't heat when it's been running for a while,the coils on the gas valve will need to be replaced.
GENE
Aug 16, 2011 | Roper RGX4634KQ Gas Dryer
I have a Roper gas dryer (RGS7646KQ2) which is not heating up to dry clothes. The drum turns and the timer works as well. It appears to be acting normally, except it is blowing cold air instead of warm...
You have a bad thermostat, flame sensor, thermal fuse, gas valve solenoids, or the high limit thermostat. Below is a video to walk you thru the diagnostic testing and repair.
Jan 03, 2011 | Roper RGS7646KQ Gas Dryer
Roper dryer model REL4434AWO has stopped spinning. Heating element works. Belt seems secure around drum.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Dec 18, 2010 | Roper Dryers
No Heat. Roper gas dryer model # RGX3514PQ0.
Hay Bud, you have an excellent excuse to buy a multimeter congratulations.. when you do, access the burner assembly and controller circuit board, on your disassembley you will likely find a wiring diagram, this will be very helpful in diagnosing your fault, let me know when you have the meter and the diagram and i will step you through the diagnostic proses.
Apr 28, 2010 | Dryers
Roper gas dryer does not ignite.
The problem is the ignitor...
Check out this tip that I wrote about that problem...
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
heatman101
Apr 07, 2010 | Dryers
I have a Roper Gas Dryer model RGX5634KQ2. The
My bet is that your ignitor is bad....change the ignitor and you will be working again...
Here is a tip that I wrote about your problem that will explain it further...
heatman101
Mar 30, 2010 | Roper Dryers
Dryer will heat up but drum will not turn. Unable
Good day,
Sounds like a broken belt, Excellent tutorial on changing the belt on the link below.
Caution: Some models used a very poorly designed belt tensioner. If the tensioner is that style, replace it while purchasing the belt.
Appliance parts house counter men are well aware of the problem. The Roper line is made by whirlpool.
http://www.wikihow.com/Replace-a-Dryer-Belt-on-Whirlpool-Models
Dec 04, 2009 | Roper REX4634KQ Electric Dryer
Good luck,
I hope this helps
Oct 06, 2009 | Roper REX3614KW Electric Dryer
Dryer tumbles, no heat
Dec 28, 2008 | Roper RGX4634KQ Gas Dryer
Dryers Logo
32 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Roper Dryer Expert? Answer questions, earn points and help others
