Question about Bose Lifestyle V30 Home Theater System - Black
Where is the power switch on the Bose v30 acoustimass module?
SOURCE: bose acoustimass 25 subwoofer has no power
Honestly speaking you should probably not work on this unit yourself: "There are no user serviceable parts inside"
Even if you are an accomplished Electrical Engineer Bose will not provide the required schematics to troubleshoot and repair this unit.
Are you still undaunted . . . then if the case is the original LS-25 series, there is a hidden catch at the end of the cover furthest from the input connectors that needs to be rotated (until a plastic tab is sticking out), which you can do with a flat bladed screw driver, and you also need to remove a few screws from the bay where all of the connectors reside. Remove the two knobs from the side of the cover. Then hit the case with your fist at the far end (plastic tab) and the cover should then pop off. You may have to hit it hard, with an upward motion.
Note there is not going to be much you can do to fix this beyond replacing the fuse. (Note that the fuse may be soldered in.) The bass amplifier is op-amp based with discrete class G output stage and the twiddler amps are monolithics with discrete class G circuitry shared between several channels.
The power transformer has a thermal fuse in it as well which is not replaceable. If you play the unit loudly for long periods of time and it is not adequately ventilated it is possible for the thermal fuse to open - if this is the case you will definitely need to send it in for service.
When plugged in there are hazardous voltages present on the top PC board where the power connector is located, whether or not the unit is turned on.
Power switching is via a triac controlled by whichever front end you have CD-5? 12V should be present on the mini plug (tip I think, but might be ring) when the music center is on.
There is also offset detection circuitry that will latch the unit off should any output have more than a volt or so of offset.
For more information see following web site:
http://www.diyaudio.com/forums/showthread/t-106135.html
Posted on Mar 01, 2009
  • 3 Answers
SOURCE: Need v30 bose code for remote
Bose V 30 works on Radio frequency ............. so you need to have a unversal radio frequency remote conrol..... no IR (infrared) remote can control a bose lifestyle product..
why not use your bose radio frequency remote( the v 30 remote) to control the dvr plyer from motorola.. you can used the remote even to control your tv and other deices ..
all codes for your other systems are available in th e system settings option under remote control category to set up your system to control other devices
Posted on May 14, 2009
Ojelola
  • 22 Answers
SOURCE: no sound from centre speaker
Check your audio settings, via the on-screen menu. The center channel may be turned down. When set at -5 to -8, the center channel speaker may be practically inaudible. If raising the volume of the center channel does not solve the problem, then you do have a dead center channel. The system would then be in need of repair.
Posted on Jan 26, 2010
pabloloco
  • 2335 Answers
SOURCE: Flashing / ghosting with Bose Lifestyle V30
I recommend you switch from using HDMI cables to using component (R/G/B RCA-style) cables. HD picture is superior through component cabling, and solves several HD picture issues. Component cabling from your devices should eliminate your problems.
I hope that helps.
____________________________________________
Download Bose LifeStyle V30 User Manual
Posted on Jul 05, 2010
gopakumarg43
  • 75157 Answers
SOURCE: What is the impedance of
Hello
The impedence of all speakers are [3.5 Ohms]. May connected upto [6Ohms] instead, provided the output will be a little less. Bass module cannot be connected with other sources. If you are intented to hear the music on an other room you can add speakers. For more detail, go to page [29] of its user manual, where all details and switching data are provided. All cannot be send by this window, as it will be out or capcity of this answer window. If you haven't its user manual with you now, send your email address to me by FixYa. I'll send a copy of it to you by return mail.OK.
Posted on Jun 02, 2011
How to turn on bose acoustimass 15 sub unit
there is a switch located next to where the speaker wire is connected to the module. flip it.
Aug 02, 2014 | Bose Acoustimass 15 System
Have this Bose system connected to my Yamaha a/v receiver
If you have it literally conencted the way you say not much good will happen.
The speaker OUTPUTs for the Yamaha feed the INPUTS on the Acoustimass Module then the satellites branch out of the Acoustimass Module's OUTPUTs.
Acoustimass module
Bose® recommends putting your Acoustimass module at the same end of the room as the
television monitor. To prevent interference, keep the module at least 2 feet (.6 m) from the
television.
• You may hide the Acoustimass module behind or under furniture, but do not block the
opening. Be sure there is at least 2 inches (5 cm) between the opening and any surface.
• If the opening faces the wall it increases the bass; if it faces away it decreases the bass.
For the most bass response, place the opening 2 to 3 inches (5 to 8 cm) from a wall or
corner.
• Stand the Acoustimass module vertically or horizontally (Figure 6). To stand it on the
cable connection end, remove the cover by gently pulling it away
Move the sub closer to a wall or corner to increase the bass.
This is a SYSTEM and as such is not designed to be pieced out or separated. I don't recommend that you try it that way. I doubt it will improve the sound.
Apr 30, 2010 | Bose Acoustimass 10 III System
Dead Bose acoustimass bass module
Even i have the same problem.bose does not providing a single sub-woofer
Feb 20, 2010 | Bose Acoustimass 15 System
I have a Lifestyle 35 and want to replace head unit with a 5.1 receiver. The Bose subwoofer model LSPS uses a network type cable connector on the sub side and a male din plug on the head unit side of...
The entire 5.1 amplification system, in the Bose Lifestyle 35, is actually part of the Bose Acoustimass (subwoofer) module. The RJ-45 (network type) connector passes a low-voltage signal from the console to the Acoustimass module. If you were to hack the connection, and plug the speaker outputs of a 5.1 receiver to the RJ-45 socket on the Acoustimass module, you would blow the amplifier.
If you are really itching to replace the Bose Lifestyle 35 console with a regular 5.1 receiver, I strongly suggest you sell your Bose system, and purchase a Bose speaker system, such as the Acoustimass 10 Home Theater Speaker System, which is made for use with a standard 5.1 surround sound receiver.
Dec 26, 2009 | Bose Lifestyle 28 System
Bose Powered Acoustimass 30 Speaker System
The master on/off switch will usually be on the back (or maybe even the bottom) of the largest component, which contains the power and control circuits.
Nov 28, 2008 | Bose Acoustimass 15 System
Do I have to have a powered bass module to make the cubes work?
Your Acoustimass 5 is a powered sub with powered surround speakers. If you are not getting sound output, the internal fuse may be open and you will have to replace it. Bose used a heavy multiple output cable terminated in a miniature DIN plug to connect speakers. You may be able to find one on eBay.
Apr 17, 2017 | Bose Acoustimass 6 III System
Changing the inpout voltage of inside bose Acoustimass module
Probably not, but you can install a step-down transformer if there's room inside the unit. Since these speakers don't use much current, a small transformer will work. It doesn't have to be a 220-to-110 transformer either - any transformer designed to cut the voltage in half is fine. A 24 volt-to-12 volt transformer will also work.
Aug 13, 2008 | Bose Acoustimass 15 System
Bose 321
3 audio inputs (3 analog, 3 coaxial digital, 1 optical digital)
2 video pass-through inputs (composite and S-video)
Video output for TV (composite, S-video, and component)
Media center • 3 1/4"H x 13 3/4"W x 10"D • (8.3 x 34.9 x 25.4 cm) • 6.7 lbs. (3 kg)
Remote control • 1 1/8"H x 2 1/2"W x 9"D • (3 x 6.5 x 22.9 cm)
Gemstone speakers • 2 1/2"H x 5 1/2"W x 4 1/8"D • (6.4 x 14 x 10.5 cm) • 1 lb. (.45 kg) each
Acoustimass module • 14 1/2"H x 8 3/4"W x 19 1/8"D • (36.7 x 22.2 x 48.5 cm) • 23.3 lbs. (10.6 kg)
Total shipping weight • 44 lbs. (20 kg)
gray_hr.gif What's In the Box • Acoustimass® module • Media center • 2 speakers • 3·2·1 universal remote control • Setup DVD • Antenna stand • Stereo cable • Video cable • Speaker cable • Module cable • Rubber feet for Acoustimass® module • Rubber feet for speakers • Batteries • AM antenna • FM antenna • 120V power cord • Quick setup guidepls rate !!!!!!
May 29, 2008 | Bose 321GS Series II System
Attaching a pair of Floor standing speakers as Front R and Front L instead of standard bose cubes
yes of corz,, u can use any of that but dont go pass the power of your power amp,, becoz,, it coss damage 2 your speakers,, and thats expensive... ps. . dont revers the polarity
Feb 20, 2008 | Bose Acoustimass 15 System
Bose Lifestyle V30 Home Theater System - Black Logo
260 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
