Samsung model sp43t8he.....how set the convergence
I can not find any switch on remote or at TV to set convergence.please guide me
  • 32 Answers
SOURCE: convergence
mammy: In the MENU when your correcting this problem in order to use your remote you must press the M button or MENU button. Once it is done then you can adjust the color convergence. I also suggest you to check the remaining 2 colors for a nicer setting. SithPitt
Posted on Jul 04, 2007
SOURCE: set up code on remote control
i only needed to set code number to set on remote control i managed so thank u
Posted on Mar 10, 2008
  • 1894 Answers
SOURCE: Samsung 105" RP have to
do you mean that the setitngs are not getting saved eac time you set it?
am i right.?
Posted on Jul 08, 2008
Slinteriors
  • 8617 Answers
SOURCE: need to converge the tv but dont have the original remote
you will need the origional remote. Yoou may be able to get one at the following link, just click the contact button and indicate the model number and what youre needing they ussually have them or can get them quickly.
http://servicemanuals.vstore.ca/
Posted on Jan 26, 2009
SOURCE: service code needed to complete convergence adjustments
I have the service convergence code: mute-1-8-3 (make sure your tv is on and set to antenna. if it doesn't work press S. Mode and make sure is says standard then re-enter code.
So, I have the code but I need the convergence chips. Where did you get the convergence chips?
Posted on Feb 04, 2009
I need Samsung TV remote control code for setting up Sony Blueray Player remote control.
0279,0277,2870,2851. Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Nov 16, 2014 | Samsung Televison & Video
I don't have the remote for a Samsung rear
Go looking for a used remote--I have one I hang onto for just convergence alignments on their sets--no universal will cut this.
The original remotes among other things had a data button to save the adjustments.
May 29, 2012 | Samsung Televison & Video
Which remote control used for 29" TV CS-29L30ML SAMSUNG
If there is any customer sevice center of Samsung nearby, please enquire there about the remote model of your tv set by giving your TVs model number, usually marked on the back side of the tv. They can surely guide you.
Oct 15, 2010 | Samsung CW29M64NS 29" TV
Samsung tv model # HCP4363WX Ghosting
The convergence board that you replaced will not correct the issue that your describing as your model has the convergence amp circuits located on the Deflection board. You would need the deflection board which is available at the following link. It also has a picture of the board which is in your model its the large board on the right with the Flyback and both Convergence ICs on it.
http://servicemanuals.vstore.ca/product_info.php/pName/p59a-pwr-def-board/cName/samsung-parts
Dec 16, 2009 | Televison & Video
Rca d52w27d no convergence in the set up menu cant run the convergence
some rca models have the convergence as a seperate button on the front or side of unit. sometimes if unit has guide plus+, unit wont have that option. try on your tv factory remote, with tv on, push menu, 7, 1, go back, tv. that is the code to reset your computer in tv.
Nov 14, 2009 | RCA Televison & Video
Convergence is off and wont adjust with remote control adjustment
Convergence control will disappear / inactive in TV menu when Convergence out section got failure.
Please replace convergence out board in TV to solve this problem.
Is it Samsung HC-N473W model?
Thanks.
Nov 02, 2009 | Samsung HCN473W 47" Rear Projection...
Double image
it is not majer problum. this is a convergence problum pls read user"s menual and set convergence seting on the remot control.
if not posibal convergence seting then inside the fornt cover 6 pre-set Adjesting 3 pre-set on top is foucas Adjment.
and 3 pre-set bouttom is screen Adjesment for R_G_B. Gun. set perfact Adjestment.
Oct 04, 2009 | Samsung Televison & Video
Samsung sp47w3hf1x - no picture no sound I have no problem tv picture and sound on the remote but can not shut down the remote - when ignition switch on you hear a mali BRUM in the loudspeaker -- before...
You have listed two different model numbers.
Please look on the right side of the set and you will see a sticker listing the Model# Serial# and the Version#. I need the Model# and the Version#. If your set has no side sticker then look on the back of the set and read the Model# from there. Then report this info back to me.
Jul 15, 2009 | Samsung HLN4365W 43" Rear Projection...
Service code needed to complete convergence adjustments
Jan 26, 2009 | Samsung HCM653W 65" Rear Projection...
Convergence
corbey1984,
Look for bad pico fuse feeding B+ to convergence amps,two are
hiding under the heatsink amps are on, more fuses in power supply ...............................What part # did you use and what price / mfr. ?.............................T
Cris1983,
please verify your model number on back of your tv..........T.
Nov 30, 2007 | Samsung PCL5415R TV
Televison & Video Logo
44 people viewed this question
Top Televison & Video Experts
Electro Med Services...
