Question about Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Hook up fuel lines on a craftsman chain saw model 358356332
I need a diagram or an explanation of where the fuel lines go. my carb has a choke not a bulb. when i took the covers off it had only one line going to the tank the fuel filter was not hooked up ans all i can see is the one line.
  • 4 Answers
SOURCE: Mcculloch 3216 starts few seconds and dies, choke must be closed.
after jerkin fingers bloody today same problem i took carb apart,,the old hoses deteorated an clogged screen on in take side/// inside of carb plate //of carb,,blew out with choke cleaner,, reassembled now runs well make sure to run same size hoses large an small,,as original other wise floods out,,,
Posted on Mar 21, 2009
dontbother10
  • 2220 Answers
SOURCE: How to connect the fuel lines for Poulan Model # 1950 Chain Saw
The following link should be very helpful:
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
A link to a Poulan model 1950 Type 7 follows (may not be your saw, there are 7 different Types and 2 Woodsharks (LE))
http://www.ordertree.com/modelinfo/PWE/1950-Gas-Saw-Type-7/75.1950-Gas-Saw-Type-7.1.59.1.html
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Posted on Jul 22, 2010
  • 4088 Answers
SOURCE: I need a diagram to see how to replace the fuel
The large hole in the tank brings a line from the filter to the upper carburetor fitting. The lower carburetor fitting goes to the primer inlet (which is found by plug and try). The short line from the tank goes to the outlet of the primer. With fuel mix in the tank, try one of the ports in the primer with the line from the carburetor. If correct, the primer bulb will fill with fuel--otherwise, try the other primer port and see if fuel will come into the bulb. This may take over 6 pumps if the carburetor is empty of fuel. Did you check the fuel filter for plugging? If it was ok, and with new lines, fuel should pump into the primer provided the carburetor is not plugged itself. If the problem seems to center on the carburetor, be sure to check the diaphragm in the lower chamber for flexibility--no holes or cracks. Also, there is a very small filter screen in the mid-body section that may be plugged. Use spray carburetor cleaner to clean the carburetor inside and out. When you get fuel to come into the bulb, the short line from the tank goes to the empty port. Hope some of this helps!
Posted on Jul 23, 2010
SOURCE: I need the routing of the gas lines on a poulan
how to route the gas tank lines in a poulan chain saw
Posted on Nov 18, 2010
  • 2239 Answers
SOURCE: Walbro WT891 carb on a
Who connected these hoses? the normal routing for a machine with a primer is like this, the fuel hose from the tank with the filter on the end goes to the carb fuel inlet nozzel ( not to the primer ) nearest to the pump cover ( cover on carb held with one screw ) the pipe from the metering side of the carb connects to the shorter nozzel on the primer bulb ( suction side ), the longer nozzel on the primer ( pressure side ) connects to the pipe going back to the tank, just remember the primer pulls fuel from the carb,into the bulb, and pushes it back into the tank, it is not actually a primer it is a purge. because it is connected this way it is impossible to flood the engine no matter how many times the bulb is pressed.
Let me know if it starts and runs.
Posted on Jan 31, 2011
How do you replace fuel lines on a craftsman 16" chainsaw model#358.352161?
remove the carb and then pull fuel lines from tank ,there should be a filter in tank attached to the fuel line you will put that on the new line then feed it through from in the tank out
Oct 30, 2014 | Craftsman Garden
My craftsman chain saw 18 will not start
The 3 things needed for an engine to run:
1. Compression (Cylinder, Piston, rings, gaskets)
2. Ignition (Spark plug, ignition module/coil)
3. Fuel (Fuel lines, Carburetor, gaskets, bad fuel)
More than Likely I would start by checking fuel related since that is usually the biggest offender (fuel lines broken/dry rotted, bad carb.)
Jun 19, 2014 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
My husqvarna chain saw will run only if choke is at least half way out
this is a sure sign of a fuel blockage some place !! id start with fuel filter and air filter and then look closely at fuel lines for signs of collapsing when running (CAREFULLY!!!!!) then move on to cleaning and resetting carb jets
remember choke richens fuel/air mix so if it needs choke to run then it's being restricted in fuel supply
Jun 17, 2014 | Husqvarna Chain Saw 20" Bar
Fuel lines on craftsman chain saw
go to the website and see if you can download a manual
most saws have 2 lines fuel in and a return
the fuel in line is the one that goes in the tank and has a filter on it
hold you finger over the fuel line on carb and pull cord, the one that sucks is your fuel in, the one that blows air out is your return
Mar 07, 2014 | Craftsman 42cc 18" Gas Chain Saw
No fuel going to carb
Either you have a air leak fuel inline or at fuel tank or a plugged up carb- sour aged fuel or foreign debris
Jun 12, 2013 | Craftsman Sears Chain Saw Manuals Model...
I have a walbro carb on a craftsman chainsaw..Can you tell me which fittting on the carb (TOP RIGHT) OR (BOTTOM LEFT) gets the fuel line with the filter on it??
All chainsaw primers pull fuel from the carb, so the fuel inlet ( pipe with filter on the end ) goes to the connection nearest to the pump cover of the carb ( the alloy cover with a single central screw )
Feb 01, 2013 | Craftsman sears 18" Chain Saw Chain (...
Craftsman 18" chainsaw runs but dies when I press the throttle, new carb and fuel lines low and high speed set at 1 turn .
remove the muffler and run it after seeing that it runs good open the muffler and clean the screen inside
Sep 27, 2012 | Craftsman sears 18" Chain Saw Chain (...
Diagram of fuel line for Craftsman 16" chainsaw
Your saw is a Poulan. Try converting the cc to a model number. A 2.2cc Craftsman is often a Poulan model 2200. go to this link and find something that appears the same under (POULAN-WEED-EATER).
http://www.ordertree.com/cms/illustrated-parts-list/9788.html
The IPL will help. Pay attention to the year there is a different area for older saws.
For a current saw Craftsman should have something available.
Sep 04, 2009 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
Mar 03, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan Pro 42CC 2 Cycle Chainsaw, 18" Logo
48 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
