Question about Epson Stylus 830U InkJet Photo Printer
Smudged printing when i print the first inch of the left handside is blurred. I have done the nozzle clean and alignment. Thank you Peter atpeter@prflicos.wanadoo.co.uk
  • peter626 Jan 18, 2009
    tHANK YOU FOR TRYING HOWEVER i BOUGHT A NEW BLACK AND COLOUR CATRIDGE UNFORTUNATELY IT IS NOW REALLY BAD I THINK I WILL HAVE TO THROW THE PRINTER AWAY
    PETER FLICOS
    Problem Solver:
  • 3 Answers
You have a dirty print cartridge. Replace it with a new one, then reset your printer by unplugging both wires from the rear, wait 60 seconds, then plug them back in. Then it may ask if you want to print a test page. Go ahead and do it. I hope this helps.
Posted on Jan 15, 2009
The printing is blurred
Blurred print may be caused by a dirty print-head - remove and wash with clean warm water. Dry with paper towel and retry.
Blurred print may also be caused by a print-head alignment fault. First check that there are no paper fragments at either end of the print path inside the machine. Then go to the maintenance section either on the printer or in the computer printers folder and perform a nozzle check, print head clean and print alignment. in that order
Jan 08, 2015 | Canon PIXMA Office Equipment & Supplies
Smudged horizontal lines
Try cleaning your rollers, it worked for me. I hope this helps.
Feb 13, 2013 | Canon Pixma MX410 All-In-One Printer
Printing alignment is out, printing in blurs
cartidge have problem, require to be done by maintenance pass software in panel control of printer, cleaning deep or, check nozzle
Feb 26, 2011 | Canon PIXMA MP540 All-In-One InkJet...
The print is readable but blurred, looks smudged and prints pictures blurred too.
Align the print cartridges after installing them to improve print quality. To do this:
1. Load plain paper.
2. Open the Lexmark Solution Center.
3. From the Maintenance tab, click Align to fix blurry edges.
4. Click Print.
Hope that helps.
Sep 10, 2010 | Lexmark X7170 All-In-One InkJet Printer
Epson Stylus CX4800 prints blurred pictures
ok..first you will need to print the nozzle check and see if all the color are printed out fine.. this feature is under the printer properties , under the utility tab.... assuming all your colors nozzle are printed fine..then the next thing for you to do is do the Print Head Alignment.. it's under the same place where you print the nozzle check.. when you press the Print Head Alignment, it will print a page out with many lines.. choose the one with the best alignment.. once u done that..try printing the image again..
oh..if your nozzle check print out is not good.. then you will need to perform head cleaning to clear the clogged head..
May 24, 2010 | Epson STYLUS CX3900 All-In-One InkJet...
I HAVE A CANON MP 760 PRINTER THE MAGENTA COLOUR LINE IS TWO TONED WITH DARK AND LIGHT PINK . SO WHEN PRINTING PICTURES THERE IS DISTINCT LINES CAN SOMEBODY HELP HAVE TRIED THE CLEANSING REPLACED THE...
You need to conduct the following steps:
Printing the Nozzle Check Pattern
The nozzle check pattern shows if each print head nozzle is operating properly.
You can also print the nozzle check pattern from your computer.
  1. Load A4- or letter-size plain paper in the Auto Sheet Feeder (ASF) or cassette.
  2. Press <Feed Switch> button to select the paper source.
  3. In either COPY, PHOTO, or FILM menu screen, press <Menu> button.
  4. Press the left or right arrow to select [Maintenance/Settings], then press <OK>.
  5. Use left or right arrow to select [Maintenance] and press <OK>.
  6. Use up or down arrow to select [Nozzle Check] and press <OK>.
  7. When prompted to print a nozzle check pattern, use the up arrow to select [Yes] and then press <OK>.
    The machine prints a nozzle check pattern
Print Head Cleaning / Head Refreshing
If the printed nozzle check pattern is broken, missing, or a specific color is not printed, clean the print head.
MEMO:
a. Cleaning the print head consumes a small amount of ink. Cleaning too often reduces the amount of ink in the ink tanks.
b. Print head cleaning is performed when you connect the power cord. Your machine may perform print head cleaning periodically to avoid clogging.
  1. In either COPY, PHOTO, or FILM menu screen, press <Menu> button.
  2. Press the left or right arrow to select [Maintenance/Settings], then press <OK>.
  3. Use left or right arrow to select [Maintenance] and press <OK>.
  4. Use up or down arrow to select [Print Head Cleaning] or [Head Deep Cleaning] as necessary and then press <OK>.
When prompted to clean the print head, use the up arrow to select [Yes and then press <OK>.
IMPORTANT:
If normal print head cleaning does not improve print quality, perform deep print head cleaning.
Print Head Alignment in Windows
If colors mix or streaks appear in the nozzle check pattern, perform the print head alignment.
The print head alignment can be performed either automatically or manually.
If the automatic print head alignment does not resolve the problem, perform the print head alignment manually.
Your feedback is very important to us, please do not forget to rate my service for the site to continue helping everyone and improve on it.
I thank you for the opportunity to help and please do not hesitate in contacting me for any further questions…god bless
Aug 09, 2009 | Canon PIXMA MP760 All-In-One InkJet...
Printing blurred
H'mmm - new one on me , and I'm ***** old. If it was all blurred I would blame a faulty capacitor on the main board putting noise on the line - but the first inch? Check the track (where the print head travels along) and make sure there is nothing to cause the paper to be a bit low at the left end. Report back on what you find.
Jan 12, 2009 | Epson Stylus 830U InkJet Photo Printer
Test page always blurred
It would appear as though the ink cartridges were not securely in place. Upon making them secure my test page printed perfectly thereafter.
All four requirements were carried out i.e. clean/deep clean/print head alignment/nozzle check
Tks for your respons
guru1234.
Feb 07, 2008 | Computers & Internet
Print problem with Cyan cartridge
i had to run 10 cleaning to get a printer to print magenta. finally it cleaned it self..it gets expensive..leaving your printer on keeps the in nozzles clean..when its off for long periods it dries in the nozzles.
Oct 14, 2007 | Epson Stylus Photo R320 InkJet Printer
Epson Stylus 830U InkJet Photo Printer Logo
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
