Question about Sli Lighting 48" Fluorescent Tube Bulb 32 Watts 25CartonSLT01713
Just installed two 40 watt 48" fluorescent tubes in our mobil home kitchen - they worked for a few minutes and then went to flickering dim only and no this isn't a dimmer switch unit.
Need to know if it's the lighting unit or the brand new bulbs ... should I use a smaller wattage?
    President:
  • 1,851 Answers
Peggy - there are 'starters' on the unit called ballast - Those must be either replaced or you have a deeper problem. I am sure it is the starters. Please just take a pic on your camera - leave it there go to LOWES -- and show them - tell them you need to make it light and about them flickering etc. They will guide you to exactly what you need. Most are very easy to replace. Ask the man or woman at LOWES - they are very knowledgeable. Without seeing what type or brand you have I can't tell you more.
If they can't help you - come back and tell me more on the COMMENT section. I will be notified and read your comments there.
Thanks
Gary @ Fix Ya
Posted on Dec 09, 2012
My fluorescent shop light fixtures sometimes does not go on and sometimes the bulbs just flicker without giving much light. What's wrong?
If your shop is in your garage, and it is cold outside, the two-pin fluorescent tubes don't work very well. Garage lighting (fluorescent) should be the HO (high output) type. It operates on the same voltage. The tubes are not interchangeable. You need a HO fixture. If your shop is inside your house, then flickering tubes (assuming that you tried changing them out with new ones) indicate a bad ballast inside the fixture. You can either change out the ballast, or for almost the same price, replace the fixture.
Sep 19, 2014 | Home
Tip
LED Tube replacement for 48
These are better, but cost more. Get them at Amazon where some reviewers complain about quality. I love them in our garage where I replaced 4 tubes in 2 fixtures. Took an hour with the first, 30 mins for the second and probably 15 mins if I did another. Here's a link to an Australian teardown video. Eliminates mercury concerns.
on Dec 07, 2013 | Sli Lighting 48" Fluorescent Tube Bulb 32...
Fixture not working after bulb change
"CFLs" Compact Fluorescent Bulbs (with built in ballast) must be labeled as dimmable to be used on a dimmer circuit.
Traditional fluorescent fixtures must have a dimmable ballast installed inside and can be used with standard fluorescent lamps.
Fluorescent lamps must be sized to match the ballast. CFL's are matched at the factory, but others are not. Older fluorescent lamp fixtures have a ballast inside. A type rating is to operate (2) 48 inch / 40 watt lamps. Newer fluorescent lamps are rated for 32 watts, and these will not work - or will have a greatly reduced life.
If you installed CFL's, the first thing I would do is install regular incandescent lamps and see if it works as expected. If not, something else is wrong - otherwise - make sure you've got the right lamps in the fixture.
Mar 17, 2014 | Electrical Supplies
Fluro tube
fluro tubes are rated in watts and they are connected to the length of the tube. ie 20 watt 20 inches---30watt 36 inches and 40 watt 48 inches. Some makers have a triclor fluro that have a higher lumens value but the wattage will be the same.. You will have to compare tubes in the lighting shop.
May 29, 2013 | Home
How is tubelight wiringdiagrem
Following the simple circuit diagram below you can actually place the ballast and the starter hidden somewhere away from the tube as long as you follow where the terminal goes.
You will need to buy:
a pair of tube holders.
a starter holder and a starter
a ballast (20 watts for a 2 feet tube or 40 watts for a 4 feet tube)
a fluorescent tube of your preferred wattage.
All these item are readily available in most electrical shops. Here is the diagram:robertaji_1.jpgPlease rate if this solution helped you, thanks!
Jul 05, 2011 | Computers & Internet
A 40 W fluorescent lamp gives out more light than a 4o W filament bulb.explain whether the fluorescent lamp is actually using electrical energy at the same rate as the filament bulb??
The lamps are both using 40 watts of energy, but the fluorescent lamp gives more lumens (visible light measurement) than the incandescent.
Fluorescent gives at least 5000 lumens for 100 watts.
Incandescent gives 1750 lumens for 100 watts.
You can see that if you had a 100 watt incandescent, it would be 1750 and you would only need 35 watts of flourescent.
Gary
Feb 19, 2011 | Vacuums
I installed a digital timer GE 15086. Does it work with fluorescent lights?
15086 manual says 15A Tungsten.
Tungsten is incandescent.
manuals usually say CFL or fluorescent if they are made for those loads.
http://waterheatertimer.org/GE-timers-and-manuals.html#15086
http://waterheatertimer.org/pdf/GE-15086-Manual.pdf
Honeywell (500 watt/40 watt minimum) Aube T-1032 handles fluorescent and halogen
http://waterheatertimer.org/Aube-timers.html
Woods 59028 works with CFL
http://waterheatertimer.org/Woods-timers-and-manuals.html#59028
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 16, 2011 | General Electric Hardware & Accessories
Have 3- 13 watt mini spiral bulbs on fixture. When switch in auto mode, lights hum, flicker and not maximum brightness. When switched to on position, lights stop flickering and humming. Full brightness as...
-Replace the compact florescent bulbs with regular incandescent bulbs and see if problem continues.
-Lighting controls are made for different kinds of bulbs.
-Your package should say what the watt rating and type of bulb.
According to the PR180 manual:
-I am looking at the Leviton PR180 occupancy sensor manual, and the PR180 sell-sheet, and these documents say for incandescent and fluorescent (rapid-start magnetic ballast only).
-Compact fluorescent are supposed to have a magnetic ballast.
-The manual does not specifically say it works with 'compact fluorescent'
-The manual does not say there is a minimum amount of wattage either. Some controls will not work correctly if the overall wattage is low. Your overall wattage is 39watts.
Read the product package (if this is a new installation and you have the package)
Try the incandescent bulbs.
If the PR180 is not your product, add a comment with product number and I'll look for information
Nov 06, 2010 | Leviton R01-PR180-1LI Decora 180 Degree...
40 watt just not bright enough?
60 watts could be fine and you may never have a problem, but it says 40 watts for a reason. So you don't burn your house down. See "To reduce the risk of fire....". The better option here would be to buy 23watt compact fluorescent light bulbs. They give off less heat than a 40 watt incandescent and the same light output of a 100watt incandescent. I'm guessing that you don't currently have the light on a dimmer, but if you wanted to, make sure you get cfl's that are made to be used on a dimmer.
Jan 08, 2009 | Hampton Bay 24002 Ceiling Fan
Sli Lighting 48" Fluorescent Tube Bulb 32 Watts 25CartonSLT01713 Logo
93 people viewed this question
Top Sli Lighting Home Experts
Donni Steen
Tom Chichester
Are you a Sli Lighting Home Expert? Answer questions, earn points and help others
