Question about Panasonic Toughbook CF-51 Notebook
Panasonic CF-51 backlight intermittent
Voltage to backlight falls when backlight fails. All voltages measured at motherboard connector to backlight power supply read the same (referenced to ground) whether light is on or off. Simulating a lid closure (with magnet by reed switch) and then simulating reopening (remove magnet from reed switch) causes backlight to come back on (each time) for about 10-30 seconds before failure. Reed switch has been isolated and known good.
Question: Is there other circuitry on the motherboard that may cause this problem (even with the voltages measuring the same at the motherboard connector) or is the problem in the backlight power supply located in the monitor frame?
  • R Shendo May 09, 2009
    screen barely visible when powered on. closed and opening laptop provides normal lcd brightness for a very limited time. overheating?
The screen flickers when opening laptop.
It's one of two things, either it's the backlight inverter or it's the switch which tells the laptop the lid is closed.
The backlight inverter is what powers the lamps in the back of the screen.They aren't expensive, but a computer shop will probably charge you an arm and a leg to replace.
The switch tells it to turn the backlight off when the lids is down to save power.
If it's the switch, you can disconnect it by following this guide… and… according to that if it thinks the lid it will turn the blue touchpad LED orange to indicate the touchpad is locked.
Jun 02, 2010 | Panasonic Toughbook CF-51 Notebook
Panasonic CF-51 computer getting stuck, and making clicking noise. Have to turn off manually and restart.
Listen carefully to the HDD bay of the CF-51, If the "Clicking" sound is coming from that area then it is possible that the hard drive is failing causing the whole laptop to freeze up.
If that is the case then you're looking at a new or replacement hard drive.
May 27, 2010 | Panasonic Toughbook CF-51 Notebook
Panasonic CF-51 LCD screen is very dim and fades to black. I replace the LCD screen and have the same behavior. Is this an issue with the Motherboard
Yes that sounds about right now.. but did you replace the Inverter board as well... I mean did you replace everything including all electronics attached too? Or just the LCD, see it may be the driver?
Feb 06, 2010 | Panasonic Toughbook CF-51 Notebook
Panasonic CF-51,s are becoming common on Ebay but most do not have hard drives or caddies installed.The caddies cost more than the computers & are almost impossible to find for sale.Is it possible to...
I found this via
So try that out. I just got a toughbook cf-51 and will try it soon myself. Mine came with an XP reg code so maybe that can run from a virtual machine inside of linux.
My advice is to resist the urge to drop yours onto cement from a couple of feet. Not quite that tough.
The hard drive caddy is "the catch", for certain.
Too lazy to look into what the hdd connector is for that, maybe there's a cable or converter somewhere.
Oct 22, 2009 | Panasonic Toughbook CF-51 Notebook
Need a motherboard for a cf 51. mine is a dl3up1481aaa. That number cannot be found. will anyother work in it's place.
There's one on ebay right now ! check it out fast.
Jul 14, 2009 | Panasonic Toughbook CF-51 Notebook
Wont power up
yes no reset. your battery got low voltage. recharge by your charger.
May 26, 2009 | Panasonic Toughbook CF-51 Notebook
Panasonic Toughbook CF-51 shutting down
Sue, it's not the inverter board. People who don't really know much about laptops will often diagnose them incorrectly, especially computer repair shops. The problem you're experiencing is most likely related to your motherboard. Unfortunately the most expensive part to replace on most laptops.
Your best bet is to probably just have any important files from the laptop extracted by a repair shop and then selling the computer "As-IS" on ebay. Or you could try another local repair shop to take a look at it. I wouldn't pay any money for a diagnostics since it would take most techs about 5-10 minutes to confirm what I just typed.
Feb 20, 2009 | Panasonic Toughbook CF-51 Notebook
Computer suddenly turns itself off.
Your best hope is that the CPU heatsink is dusty and the CPU is overheating and therefore shutting of for thermal protection.
Try to clean it deeply with canned air caring not to short the fan speed sensing with the condense caused by the expanding air(do not hold the nozzle too close to the fan).
If it keeps doing it, then it's probably because of the motherboard's voltage regulator and you need to replace the motherboard or at least the voltage regulator if it is not on-board(usually it is onboard.)
Feb 14, 2009 | Panasonic Toughbook CF-51 Notebook
Locate battery
Actually thr bios battery is on the motherboard ..u have to open the laptop and look for it..
Jan 10, 2009 | Panasonic Toughbook CF-51 Notebook
Panasonic Toughbook CF-51 Notebook Logo
522 people viewed this question
Top Panasonic Computers & Internet Experts
Oloyede Monsuru
micky dee
Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
