Question about HP Pavilion F1903 19" Flat Panel LCD Monitor
Hp pavillion f1903
Turns on for a second then gos black. what do i do please.
  • 3 more comments
  • Anonymous Jan 28, 2009
    I have the same issue, I am going to try the capacitors and see if it works
  • Anonymous Feb 07, 2009
    I have the same problem but have not been able to check capacitors yet. How do you open the monitor to check them and where is a schematic to find the capacitors spoken of (location)?
    See 4 small screws on each corner but do not appear or look to be able to release the back. Does the monitor open straigt out from backing or do you have to slide it or do something special to open?
  • theviolent Feb 25, 2009
    I have the same issue but i have examined the boards and it don't see any busted or bulging capacitors???
  • pwyrzykowski Mar 02, 2009
    i have same problem, monitor goes blank after seconds when it is connected, i assume thats are burned capacitors, however i have no clue where to find them. If any1 can help me by posting a picture or have a technical diagram where i can find them aswell as what type of capacitors i should use i would be much appriceated.
  • Anonymous Apr 28, 2009
    H p F1903 monitor comes on normal looking for about 3 seconds then goes black repeat turning it on and it does the same thing . Heard that the backlight is bad any one else?
  • 3 Answers
It has a bad capaitors in it open it up look for bulged capacitors replace all bad ones and it will run again i fixed more hps with this problem than any other and it doesn't cost much to fix its under $10.00 thank you have a nice day
Posted on Jan 13, 2009
    Problem Solver:
  • 8 Answers
To open the casing, remove the four screws that secure the stand. if your looking at the screen, flip the top away from you 45 degrees so your looking at the bottom. to the very left and right you will see a small notch where the plastic casings meet. with a small flat-head screwdriver, carefully pry them apart and continue to work your way around the side carefully. I had the same cap problem with a dell. this is definately a cap problem. good luck!
Posted on May 16, 2009
When i turn on the monitor it flashes on once for a few seconds t
faith1114, Try this first! See if any thing seems a little similar to your f1903 type of complaint. Problem been around a long time!!! Go do some reading here: http://www.lesliewong.us/blog/2005/05/02/hp-pavilion-f1703-flat-panel-display-blackout-solution. After doing some reading there, you will be in a better position to make decision to DIY repair, contract out the repair work, trade in for new , DIY repair + buy a new monitor keeping refurbished f1903 as emergency spare. Here is a little clue. If unit can display Win-desktop for 2 seconds and then the "black screen of death happens" you certainly need to do some reading and viewing of DIY videos at YOUTUBE so you can understand the big problem all major CCFL back-lit lcd monitor manufacturers are facing. do some additional reading here at fixya in the profiles of ccfl backlit lcd monitor technicians "budmrtn" "buddymc" , "12fixlouie" (late) "louie12fix" (old) Follow links you find there. Once you understand basic problem you will never walk past the new curlie-Q, screw-in energy-efficient CFL light bulbs at the local hardware or big box homecenter ever again with out having a slight grin on your face!! Bye for now. 12fixlouie
Jun 02, 2010 | HP Pavilion F1903 19" Flat Panel LCD...
My HP vs19e Monitor went black, when I turn it off...
guest, If monitor vs19e acts same when connected to different "known good" pc then try this site for info: http://www.lesliewong.us/blog/2005/05/02/hp-pavilion-f1703-flat-panel-display-blackout-solution/ How old is this model? When was last time it worked correctly? 12fixlouie
May 19, 2010 | HP Pavilion F1903 19" Flat Panel LCD...
Hp f1903 flat pc monitor goes black after 5
I was given a faulty f1703 by someone as it was out of warranty, had no help from HP and bought another brand replacement.
Same problem everyone else seems to be having. Press the on button, came on for a second or so and then went blank. Press button again, turn on again and the same happened.
I managed through trying time and again after pressing on to quickly press menu, then go down to Factory settings, press select, go down to Yes and press select again. This reset to the Factory settings and it seems to be working okay. Been like this now for about a week. I don't know how long it will last - if it goes again will try re-soldering. Guess I won't be buying HP products as this was a part of a very expensive system.
Apr 29, 2010 | HP W2007 LCD Monitor
Monitor flickers about 2 minutes after turn on. the flickering starts from the left and it eventually becomes a black screen. the monitor is 8 months new.
Unless I have the model number wrong (F1903), this monitor was relased in 2004. If it is 8 months old then it should be fixed under warranty. This can be bad problem in the bcaklight inverter circuits or bad lamps due to bad soldering works, bad power supply, please look here to see hwat is involved in repairing the monitors: http://s807.photobucket.com/home/budm/allalbums
Apr 01, 2010 | HP Pavilion F1903 19" Flat Panel LCD...
HP Pavillion f1903 monitor, power light turns blue, no display
sounds like the flourescent backlights are burnt-out--very expensive to replace and dangerous
Mar 14, 2010 | Computers & Internet
HP F1903 monitor
sure the F1903
is a LCD monitor but is old , it has
and CCFL black lamp.
it has board inside that is the power supply /inverter
this board runs the lamps.
the lamps love to fail after 10 long year of service
so when monitor fails, push the menu botton on the front
is the OSD menu dead (monitor brains inside)???
see bottom of this page , see CCFL and PCB there?
if lamps bad replace them
if PCB bad replace it, seen sold on Ebay , vastly, there.
http://pcdied.com/black-screen.html#CCFL-examples
some of these old monitors.
have silly internal sleep mode,
turn that off. (push menu button on front)
see OSD (on screen,display menus)
see settings
see power saver mode, turn it OFF,
Jul 28, 2017 | HP Pavilion F1903 19" Flat Panel LCD...
Monitor going black
HP's are known for bad capacitors in the power supply.
Replacing them is simple if you know how..not so simple if you don't.
Try your local TV repair centre. It should not cost alot to have the capacitors replaced.
Hope it helps =)
Apr 06, 2008 | HP Pavilion F1903 19" Flat Panel LCD...
HP F1903 FLAT PANEL POWER PROBLEMS
internal power supply failure in the monitor generally repair is more costly then replacement,that can be verified if you can find a tv repair shop that provides free estimates.
Dec 26, 2007 | HP Pavilion F1903 19" Flat Panel LCD...
HP F1903 turns itself off when connecting DVI
Sounds like your problem is hardware and lies with the port on your PC, this may be due to a bad driver, or bad port! Sounds like you have tried everything else!
Oct 03, 2007 | HP Pavilion F1903 19" Flat Panel LCD...
HP Pavilion F1903 19" Flat Panel LCD Monitor Logo
291 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
