Question about HP LaserJet 4100dtn Printer
Hp 4100dtn powersave issue
I have an HP 4100DTN (directly connected to PC) that will not wake up after going into powersave mode. At first it happened every time it went into powersave. I did a cold reset (powering it up while holding the green 'go' button) and now the problem occurs less often, but still happens at least once a day. Any suggestions?
  • Anonymous Feb 10, 2009
    HP Laserjet 4100 not waking up from powersave mode. Even if I turned off the powersave mode, it stills goes to powersave mode. Local printer, connected directly to the desktop. I replaced the printer driver. I replaced formatter board. Please help.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 121 Answers
I see that your machines are not on a network but do they have network cards installed?
The jet direct card can cause various problems. Look to see if they are in your machines and remove them if they are.
If that doesn't work you can print an event log and see if any errors corespond with the condition.
Hope this helps
Posted on Mar 09, 2009
HP 4100dtn Tray 2 picks the paper NON-STOP?
Step 1:Check with another cartridge
Step 2:Switch off the printer take out tray 2 casette, swich on the machine check while intializing the printer tray 2 pick up roller rotating?.. If its rotating check solnoid which is located right side under the main moto assembly, clean the solnoid as shown in the anap shot..fix it back.
Step 3:Open right ,left & top covers.., close cartridge access door check is it driving the laser scanner shutter?, if not check the sccess door knotch broken/bend.
Nov 20, 2011 | HP LaserJet 4100dtn Printer
How do I connect my HP Laserjet 4100 to my router?
HP LaserJet 4100 printer C8049A HP LaserJet 4100n network-ready printer C8050A HP LaserJet 4100tn network-ready additional tray printer C8051A HP LaserJet 4100dtn network-ready duplex printer C8052A
Which model do you have? There is an optional card to install before you can have it connected to an Ethernet network if you just have the 4100 model.
Oct 29, 2010 | Computers & Internet
I would like to install the printer on my network computer. how should i go about it?
This model HP printer has a JetDirect print server. To set it up as a network printer, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559242-setting_up_hp_jetdirect_print_server_p
Sep 23, 2010 | HP LaserJet 4100dtn Printer
Why does my printer say low toner and have garbled print when i downloaded drivers and changed toner?
In the configuration menu you should have an option to select when changing the toner to say "New Toner" yes or no.
Jun 14, 2010 | HP LaserJet 4100dtn Printer
HP4100 dtn (jetdirect 610n) will not wake up from power saving mo
I think the IP is not matching..Down load the firmware once again..will get resolved..
Jul 10, 2009 | HP LaserJet 4100dtn Printer
Recurring false paperjam alert
Remove the jammed paper. Unplug the printer from the mains and PC. Inspect the rollers, etc for tiny paper piece(s) that may be stuck, or other debris. Try to clean rollers and make sure they are dry.
Keep printer unplugged for about 2 minutes and replug and try a test print.
Also make sure that you have waited long enough for the printer to heat up before giving a print job.
Finally, it could be an issue with the paper sensor. If this is the case, you will probably have to take the printer in for servicing..
Apr 27, 2009 | HP LaserJet 4100dtn Printer
HP Laserjet 4100dtn not able to set resolution to 1200
How sure are you it doesn't need its memory expanding, please?
Nov 05, 2017 | HP LaserJet 4100dtn Printer
HP 4100DTN
Run a half test. Start printing a few pages, as it prints open the cover, remove the toner and look down at the paper. Does it have lines on the right side? If yes - replace the toner cartridge.
May 06, 2008 | HP LaserJet 4100dtn Printer
HP LaserJet 4100dtn Printer Logo
330 people viewed this question
Seeker5211
Seeker5211
