Question about Roper RT21SKXLQ Top Freezer Refrigerator
Water leaking Why does the water leak from the freezer to the bottom of the refrigerator, It gets in the trays and you can see it driping from the freezer. It is only 4 1/2 yrs old.
  • Anonymous Jan 15, 2009
    I have a question, Is it possible to use compressed air and blow the hose out?;or will it damage the hose?
  • Anonymous Jan 24, 2009
    my freezer goes thought the defrost cycle but its like there is no where for it to drain down into the try and it fills the bottom glass and the crisper drawers i havent been able to fix it can some one help?
  • 51 Answers
If the freezer is on top then empty out the freezer and remove the bottom and back liner of the freezer compartment usually phillips screws. In the back you will see the freezer coils along with a defrost element. Below these two items u will see a drip tray that collects water from the coils on defrost cycle, in the center of the pan will be a drain hole that connects to a hose that leads to a pan under the refrigerator.Normally the water is collected there and evaporated. The hole in the tray in the freezer is clogged. Thaw it and clean it until you can pour water in it and it goes to the pan down below. please rate me
Posted on Jan 13, 2009
Auto defrost works fine except for water accumlating in the bottom of unit under the bottom trays instead of in the water tray by the compressor.
There is a leak or damage of the pipe leading from the evaporator downwards.The defrosted water is leaking out of the tubing to the bottom,replace this tubing or check the leak on the collecting tray under the evaporator.
Sep 30, 2010 | Whirlpool Refrigerators
I have a txf27f and at the bottom in the freezer ice get thick and frozen and water runs out and wets the floor..
check the door gasket. Probably leaking and allowing moist air to enter and frost up, alos melting and causing the driping
Aug 16, 2010 | GE Refrigerators
Defrost condensate line behind the rear panel is clogged up. The watter is flooding over the condensate collection tray and and through the cabinet. Click below.
There are many reasons for this happening for example water leaking from a water supply line for the dispenser or ice maker, a crack in the defrost pan, water leaking inside and draining through the refrigerator cabinet, but most are caused by a defrost drain line blockage. Below is a link that may be helpful so try to take it all in and use the parts that most refer to your specific problem, Thanks Sea Breeze
Watch the short movie on how to get to the tray behind rear panel in freezer and if you have trouble or questions let e know, Thanks, Sea Breeze
Nov 14, 2009 | Amana ABB1927DE Bottom Freezer...
Water leaks on the floor. i Is there a tray that
the drain in the freezer is clog make sure the drain from the freezer is clean all the way to the pan next to the compressor . you need to open the back wall of your freezer for that ( the inside wall) clean with buster (water pump)the drain is in the bottom middle of the freezer.
Nov 03, 2009 | Frigidaire FRS3R5EMB Side by Side...
Water leaking at bottom of freezer side
that is not a leakage it might be sweating of the chilled line. and to collect this water there will be a tray fixed below the freeser or refrigerator exactly on the condensor so check this tray is in its place.
May 28, 2009 | Roper RS22AQXKQ Side by Side Refrigerator
Ice build up on bottom of freezer. Water leaks out of freezer possibly from melting. Water leaks onto floor of kitchen.
Your problem is possibly one of two things. The ice maker is leaking or the defrost tray behind the rear panel inside freezer back wall is clogged with ice or something else. If you know its not the ice maker unplug the refrigerator and remove the back panel to see if the drain is blocked there, Let me know, Sea Breeze
May 19, 2009 | GE Profile Stainless Bottom-Freezer...
Freezer leaking water
My Whirlpool has been filling the bottom under the crispers with water and leaking out the vents (?) from the freezer down into the fridge compartment. I finally caught it today being rather loud, probably in a defrost cycle, and it was positively POURING in the fridge. After some more research on this site I removed the freezer bottom tray (1/4" ratchet needed) and found a layer of 1/2" thick ice under the tray. My guess is the drain hole iced up. Removed all the ice from under the tray and on the metal drain run in the back (danger, seemed sharp) and put it all back together. I didn't try to pour hot water down the drain yet, thinking positive thoughts that the drain itself isn't iced all the way to the tray near the floor. Will watch it carefully.
Apr 20, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Ice maker is leaking into the tray where the ice is dispensed causing the ice to become embedded into the tray
there is a screw in the ice maker unit that can adjust the water level open the ice maker whit cover and you should see it but turn it gently little by little each time...and see how much you getting :) very EZ good luck
Jun 06, 2008 | GE PDS22SIS Bottom Freezer Refrigerator
Roper RT21SKXLQ Top Freezer Refrigerator Logo
332 people viewed this question
Top Roper Refrigerators Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Roper Refrigerator Expert? Answer questions, earn points and help others
