Question about Compaq Presario 7478 PC Desktop
No sound when windows 98se was installed, had sound. when windows xp was installed, had sound. Now only ubuntu 7.10 is installed, no sound.
  • Bruce Volkers
    Bruce Volkers May 11, 2010
    Which desktop are you running? KDE or Gnome? Have you enabled sounds? (the system is rather silent by default)
  • 741 Answers
When you go from Windows to Linux (Ubuntu) you will have problems as the hardware and drivers were made for Windows and not Linux. Ubuntu does not always automatically pick up your hardware. Here's what you can do to make it easier. The latest Ubuntu is 8.10 so you need to download the latest version. Then once that is downloaded you need to look at the top bar, there will be a red arrow asking you to download the latest patches. Take those steps as it will bring you current version and current software and may allow your sound card to work.
Don't forget to vote on this solution.
Posted on Jan 12, 2009
I have OS as windows xp.I have 1 GB RAM.Then I want to install the ubuntu and use it.I dono to install.My friends told that 1 GB Ram can"t access the installation well. Then what is the solution to install...
Hello Sir,
I am sure your system meets the normal requirement for installing and using the Ubuntu OS. So you dont have to worry about the system speed and perfomance. I have also sent you the link to download the latest version of Ubuntu OS 10.4 from the original website. All you need to do is download it and burn that image file using nero or any image burning software to the dvd and boot the dvd in your system and install it.
Link
http://www.ubuntu.com/
Aug 11, 2010 | Computers & Internet
I had Windows 98 OS on my desktop and I wiped it out and installed Windows XP. My system performed better before I did this, how do I get rid of XP and reinstall Windows 98? I don't have the Windows 98 CD...
If you don't have the Windows 98 CDROM, or an image backup of your Windows 98 installation (if you don't know what an image is then you don't have one) then you're in a tough spot.<br><br>
You can't just "go back" to your Windows98 machine, you will have to reinstall Windows 98 from a CDROM. So you will have to find a disc from someone/somewhere and hope it's the same version of 98 that your product key was for (if you have the product key). Or you can purchase a new copy of Windows 98SE. They cost around $55 from several websites (viosoftware.com for one).<br><br>
On another note, if you computer is running slower with XP it's most likely due to the amount of RAM being low. Try to get at least 1GB of RAM in your current PC and you'll probably see XP run better. You could also try installing Ubuntu, it's a free operating system.
Jan 31, 2010 | Microsoft Windows XP Home Edition
Cannot access XP after Ubuntu Installation
- reboot with LiveCD
- in CMD run command fixmbr, fixboot
restart, load Windows XP.
OR in Unbuntu Grub write XP portition
Aug 20, 2009 | Computers & Internet
Installing ubuntu 8.1
You must have not deleted the partitions first. You need to do this in order for a fresh install of ubuntu.
Apr 06, 2009 | Compaq Computers & Internet
About driver
I think it would make the most sense to reinstall Vista with a functional Vista disc (should be DVD). Alternatively you can check HP's Website for XP drivers which may not exist if it came with Vista. You could also reinstall Ubuntu. If you want a dual boot with Ubuntu you should install Windows first and Ubuntu will provide that option when setting it up and allow you to resize the Windows partition and create separate partitions for Ubuntu.
Dec 30, 2008 | Compaq Audio card Sound Card
I have a gateway lb3 500 ancient 98se i tried to load xp pro and it crashed i cant seem to even get a 98 startup disk to work to recover it . how can i recover it to load the xp pro onit
Try running linux on it. Linux will run much better on older hardware. Depending an the specs of the system, it may not be able to handle running windows. Try ubuntu (www.ubuntu.com). If it used to run Windows XP or 98 and it wont now, try checking the hard drive. It may be corrupt. You can find hard drive check tools all across the web, google for drive fitness test by hitachi, it works great. Burn to a disk and boot to it on the older machine and do a full advanced test on the drive.
Dec 07, 2008 | Computers & Internet
USB mouse won't work under XP in a dual boot Ubuntu GRUB 1.5
It has the latest mouse driver (logitech setpoint 4.0). Before installing Ubuntu the setup worked w/ SUSE/XP using GRUB dual boot. After installing Ubuntu XP does not see the usb mouse. Even Logitech setpoint does not have the mouse setup/configuration option. It appears that at boot it does not recognize the mouse or disables it. The BIOS has the usb keyboard and mouse enabled. Currently, I have two mices one for xp and either mouse will work under Ubuntu.
Sep 03, 2008 | Canonical Ltd. Ubuntu
Wont intall automatically
hello!
wusb54gc adapter is compatible with windows 98SE and above. you have to install the software first before installing the hardware
Apr 29, 2008 | Linksys WUSB54GC 802.11g/b Wireless...
How do I transfer files from Windows 98se to Vista on my new computer
If you have a CD/DVD writer, you can write the files to a CD-R. If this is not an option, take out the HDD from he Win 98se machine and install it in the vista machine, if you have room. you might need to disconnect your CD/DVD drive in your vista machine to free up the EIDE ribbon cable.
option 3:
Win 98se can do USB, but not very well. And drivers are hard to come by for usb flash drives. Vista/XP/ win 2000 can handle them without needing a driver disk. Therefore you will need a new OS for the win 98se machine. How about linux, it can handle usb flash drives very well. My advice use Ubuntu linux, you don't need to install it, just get a boot CD. it boots the OS from the CD, does not install or format anything. Use that OS to copy the necessary files to the flash drive. This option requires you to have a cd burner or access to one, so not really saving any time.
You did not give ne a lot of information about your setup. Like do you have a cd/dvd burner, any usb ports, any spare HDD, any external media storage. Do you have any burning software like nero. So pick which option that is viable.
You can also take your computer to best buy and have them back up the data on a CD/DVD disc for a price. Best Buy is not the only shop that does this type of service, check in your area.
Feb 12, 2008 | Computers & Internet
Compaq Presario 7478 PC Desktop Logo
135 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
