Question about Sony Handycam® DCRSR45 HDD Camcorder
DCR-SX45 Sony Handycam
Diagram of ribbon cable on hinge?
SOURCE: Sony Handycam DCR-PC109E User manual
I moved every moveable object on the handycam to no avail and then I wiped the screen to clean it and got the menu. It is a touch screen cam. Thanks antway.Ian
Posted on Feb 16, 2008
  • 489 Answers
SOURCE: Driver software of Sony Handycam DCR HC30E for windows vista
http://esupport.sony.com/US/perl/select-system.pl?DIRECTOR=DRIVER&PRODTYPE=37
you only need to find which one is your model.
hope it works
pls rate this.
Posted on May 29, 2009
Fixe_You
  • 1800 Answers
SOURCE: SONY HANDYCAM DCR-DVD105 ERROR MSG C:13:02
Try to use a cotton swap to 1st clean the recording lens or blow gently on it. Place an empty disc in, format the disc, record a little scene. Turn off camcorder. Place the error disc in the camcorder, turn on the camcorder all the way to play/edit. If this doesn't work turn it to record and try to record. Worked for some of my error disc
Posted on Jun 28, 2009
megarza
  • 88 Answers
SOURCE: Driver of Sony Handycam DCR-TRV285e
you can download the drivers here http://support.sony-europe.com/dime/camcorders/d8/d8.aspx?site=odw_en_GB&m=DCR-TRV285E
Posted on Aug 20, 2009
  • 497 Answers
SOURCE: UNABLE TO TRANSFER VIDEO FROM SONY HANDYCAM DCR TRV TO MY LAPTOP
If you want to use the USB cable to connect the Camera to the Computer to transfer the video to the Computer then:
This Camcorder does not support USB streaming with the VISTA Operating System. Use an i.LINK cable to transfer the video to the Computer. The i.LINK port is also called IEEE 1394 or Firewire port. (An i.LINK is a black D shaped connector with 4 or 6 pins. The type of cable to be used will depend on the i.LINK port of your Computer. The Sony Camcorder will have the 4 pin i.LINK cable and if the computer has the 6 pin i.LINK port, then you may have to use the 4 pin to 6 pin i.LINK Cable).
You can use any video capturing software like Windows Movie Maker to transfer the video from the Computer.
Refer this link for the instruction to transfer the video to the Computer using i.LINK cable.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C111893
NOTE: As the Camcorder does not support USB streaming with Vista, it is not required to use any Sony Device Driver to transfer the video to the Computer. You do not require any Drivers or Software from Sony to transfer the video from the Camcorder to the Computer using the i.LINK/Firewire interface.
Good Luck!!!!!!!!!!!!!!!!!!!
Posted on Sep 12, 2009
Sony handycam DCR-DVD608 Error E:61:00
I have sony handycam dcr dvd 608,when I open my handy cam,the message is showing, movie record disable
May 23, 2010 | Sony DCR-DVD608E DVD Camcorder
We are experiencing some problems with our sony handycam dcr-sr200. The screen is scrolling upwards. It just started and we don't know how to fix it? Can you help?
Hi!
It's most likely a broken LCD flex cable which goes through the hinge. It's a common problem with these cameras. I repair them every day as I work in a Sony service center. If you're out of warranty, talk to Sony, maybe they are ready to pay half of the repair or something like that as I believe it's a factory fault.
Hope this helps!
Tom
Oct 09, 2009 | Sony Handycam DCR-SR200 Camcorder
Lcd is blank
Looks like the ribbon cable that connects from the LCD to the inside of the camcorder ,its either loose or defective and need to be replaced, hope this helps AJ
Aug 03, 2009 | Sony Handycam DCR-HC42 Mini DV Digital...
Sony DCR-HC20 displays E 61:10 in upper right corner, no zoom
I can simulate this fault E61:10 by pulling out the CCD ribbon cables. This is an error that is pointed to no signal from Camera CCD assembly. Very gently remove the screws for the LCD cover assembly and remove. If you look in the upper left corner you will notice a ribbon cable connection. There is one more connection that should be checked, and it is located in the top portion below the CCD assembly. Make sure that all ribbon cables are currently attached firmly. Take specail care in opening your camera.
Jan 05, 2009 | Sony Handycam DCR-HC20 Mini DV Digital...
Dcr dvd 306e camcorder where can i buy flat flexi cables
hi, from here you will get replacement of flat flexi ribbon cable for your camcorder http://judy-hydigital.diytrade.com/
May 29, 2008 | Sony Handycam DCR-DVD100 DVD Camcorder
Dcr-trv320 problem
Hi, The the door cannot be fixed. You need to replace it. It's called a switch block control ***'y.
Ask if you need a part number.
mr cicmo
Jan 03, 2008 | Sony Handycam DCR-TRV320 Digital Camcorder
Sony Handycam® DCRSR45  HDD Camcorder Logo
27 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
