Sound Issue There is a high pitched noise coming from my television. It only occurs when the TV is on and goes away when it is on mute. It is less noticeable if headphones are plugged in, but it is still there. The noise volume is consistent, in other words it does not change regardless of the TV volume level.
    Top Expert:
  • Televison & ... Master
  • 74,482 Answers
This might be of the core vibration of the backlight inverter transformers.
Posted on Dec 09, 2012
freetek
  • 5568 Answers
SOURCE: High pitched hum from LNT5265FX when powered off
What may be doing this a a type of transformer used in switching power supplies with a ferrite core. It is rare but, if the transformer and its windings are not well secured with lacquer or epoxy, the core or windings can vibrate at a frequency related to its operating frequency which is normally beyond the range of human hearing; typically, 50,000 cycles or higher. This lower frequency is called a subharmonic. When the set is running, the electrical loading of this transformer may be causing the singing to cease because of the changes in the strength of the magnetic field (higher current) until turned off again.
Posted on Dec 18, 2009
budmrtn
  • 11361 Answers
SOURCE: loud buzzing noise on vizio tv
It sound like you may have sound processor problem which is part of the main board, I would also look at the 12vdc from power supply to make sure it is clean DC.
Parts: http://www.shopjimmy.com/catalogsearch/result/?q=l37hdtv10a
http://en.wikipedia.org/wiki/Capacitor_plague
Posted on Dec 22, 2009
moorah1
  • 181 Answers
SOURCE: High Pitch Sound when TV is turned on.
problem with capacitors in a power supply. if you 're a pro, poke she set open, by taking away 3 screws at the bottomof plastic grill, right above in/out plugs. slide grill down, make sure take screws completely out. another big screw in a miggle of grill must go out. after you manage to get plastic out, you'll get metal shieild off, by taking another 3 scews at the bottom. pry it open and lift it up, then slide it out of the assembly(looks like a rectangular box. then, expose the electronics: power supply is at the top of the module, trace power cord to that. disconnect power from the unit and look for bloated elecrolytic capacitors.found the ones, replace with exact value.
good luck.
Posted on Apr 05, 2010
  • 208 Answers
SOURCE: when turning on TV sound volume is too high
HI check the menu setings under the sound menu. there may be a power on volume setting in there
Posted on Aug 13, 2010
joeymille916
  • 143 Answers
SOURCE: Philips widescreen flat TV model #50PF9966-37 50"
From what I'm seeing online, the bulbs in the Ambilight may be the culprit. I also read that a firmware upgrade could fix the issue too. There was also a recall of some TV's with that issue, so I would check with Philips about your model and serial number and see if your TV was included in the recall. If you raise enough cain and threaten to never buy from them again, they may get your set fixed for you... even if the warranty is up!
Good luck and please post feedback!
Posted on Oct 10, 2010
Testimonial: "Thanks for the help. I will be calling customer service Monday morning. I will update after the call. Thanks again...."
Funai tv. When plugged in, makes ear piercing high pitched buzz that goes away when unplugged. Will not respond to buttons. No picture or power. Already replaced power board. What now??
TV not turning on; making high-pitched sounds - Tom's ...
www.tomshardware.com > Forum > Graphics Cards
Tom's Hardware Guide
Nov 30, 2013 - 7 posts - ‎2 authors
Both of them are refusing to turn on, and make high-pitched sounds when plugged in and unplugged. More about : turning making high pitched ...Missing: ear ‎piercing
Top 136 Complaints and Reviews about Funai TV ' Page 2
www.consumeraffairs.com > Electronics > Televisions
Rating: 1.1 - ‎65 votes
We unplugged the unit and waited 15 - 20 seconds and plugged the unit back in, and it wouldn't ... He heard a loud high-pitched whining which led him to TV in my daughter's room. ... It only makes a humming sound now, no pictures at all.Missing: ear ‎piercing
HELP! what is that high pitched noise when tv is on? - TV - Audio ...
www.tomsguide.com/forum/60895-6-help-high-pitched-noise
Jan 25, 2013 - 3 posts - ‎2 authors
Hello, I hear this constant high pitched noise, almost like ringing, but even ... pitch
Jan 21, 2016 | Funai Televison & Video
What may cause a high pitch hum.even when muted or volume turned down?
Samsung DLP making a buzzing noise, but works fine - High Def ...
www.highdefforum.com > ... > Rear-Projection TVs
Dec 11, 2009 - 7 posts - ‎5 authors
My Samsung HLP-5063 DLP starting making a loud buzzing noise recently. ... I've only used it to watch TV for a half hour or so at a time, as I have a new LED LCD in my room. ... Other than that, I can't figure out what might be causing it. .... a humming high pitch sound, it will be an issue with the color wheel. RCA D52W25 making high pitch noise - High Def ...
Apr 15, 2009
humming sound in my dlp - High Def Forum - Your High ...
Nov 6, 2006
More results from www.highdefforum.com
High pitched sound coming from my Samsung DLP TV - Open Forum ...
www.dslreports.com > Forums > Social > Open Forum
DSLReports
Oct 3, 2009 - 30 posts - ‎7 authors
Its so high pitched that some people can barely hear it, but I guess I have sensitive hearing. ... Anyway, this seems to be a fairly common issue and it is caused by either the ... You're probably hearing a transformer humming.
Jan 08, 2016 | Televison & Video
TV comes on n goes off,does 3 times
This is the Famous 3 strikes and out for RCA's--it tries to come on 3 times and if fails shutdown occurs.
The high pitched sound may be a short or could be something arcing--if the sound comes from near the very front of set--could be the HV splitter this set has arcing.
Apr 06, 2012 | RCA Televison & Video
Philips widescreen flat TV model #50PF9966-37 50" plasma, as the tv warms up a loud hissing sounds comes from the back. The hissing sound does not go away when you mute the broadcast sound. when you change...
Oct 10, 2010 | Philips Televison & Video
Loud buzzing noise on vizio tv
Dec 22, 2009 | Vizio L37 Television
Sound trouble
If you have a cell phone or wireless internet this may cause interference. If you have any of these close them out and see if it still does the sound.
Feb 15, 2009 | Sony KV-27XBR45 27" TV
27 inch tube tv won't stay on
You have a problem is in your horizontal section which also is part of your power supply. The high pitched whine is from the Intergrated High voltage transformer (also called the flyback transformer). This sound occurs when the freuency of the transformer changes and or the voltage gets too high. The click occurs as a result of the drawing of excessive current by the HOT Horizontal output transistor. This is repairable, but requires the correct equipment and a schematic.
Sep 19, 2007 | Philips Magnavox 27MS343S 27" TV
High Pitch Sound From Samsung TXN3071WHF 30" TV
I think its the flyback and its starting to leak. this is a component responsible for the high voltage of your tv set. always observe safety in dealing with this. Have it check by a qualified technician. Good luck!
Feb 25, 2007 | Samsung TXN3071WHF 30" TV
Occasional 'whistling/whining' from back of TV
I wonder if there is enough air circulating around your equipment?? My DVD recorder makes a sound unless I open the doors on the cabinet that contains all of my equipment. The cable company says it is a fan to cool down the units.
Jan 30, 2007 | Bush WS6671 28" TV
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
Electro Med Services...
