Question about GE Washing Machines
MODEL NO. WWSR3130W1WW
WON'T SPIN OR AGITATE, BUT IT FILLS UP OKAY.
pgh_pa_guy
  • 2992 Answers
SOURCE: washer fills with water then stops, won't agitate or spin
There are two possible causes. The most likely cause is the lid switch, which is supposed to keep you from sticking your hand into the moving basket. On many washers this only keeps the machine from spinning, but on other models it prevents agitating as well. The other possibility is the water level switch, but that usually causes no filling or overfilling if it's bad.
Both parts are available from Sears (www.searspartsdirect.com) and many other online sources. (I normally use the Sears site to find a part number if I don't already know it, then search for that number on Google. It's a great way to find good prices on more costly parts.) There are also a number of sites with detailed information about how to remove the cabinet to get at the parts if you want to try doing it yourself. Replacing these parts is pretty simple if you're comfortable with a screwdriver and have some mechanical ability.
If you'd rather have someone else repair the machine, this would normally be about a 1 hour plus parts charge for an appliance technician. It isn't time for a new washer yet.
Posted on Apr 25, 2009
grandadfixer
  • 99 Answers
SOURCE: Washer fills but will not spin or agitate? 1 year
Check waste hose not pushed to far down tube.This would cause same problem
Posted on Jun 11, 2009
SOURCE: doesnt agitate or spin.
Mine is 1 1/2 years old and this worked for me
unplug from power for at least 30 seconds
turn the dial to spin but don't pull out
plug back in to power and open and shut completely so switch is engaged solidly 11 times in 15 seconds.
pull out knob to turn on
This should clear a error code.
hope it helps!
Posted on Jul 30, 2009
SOURCE: WASHER FILLS WITH WATER, THEN WON'T AGITATE.
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
Posted on Jul 23, 2011
tbirdfan1
  • 3051 Answers
SOURCE: washer won't agitate or spin
Hello there and welcome to fixya
there are several things that you will need to check first ok please verrify the following
It doesn't pump or spin
If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
It pumps, but doesn't spin
If your washer pumps out the water but doesn't spin, check these:
The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Posted on Sep 29, 2011
Washer won't agitate with clothes in. Will agitate when empty with water
It's a whirlpool top load and 17 years old.
I checked the lid switch, water level switch and they are okay. I replaced the motor coupling. The old one was chewed up and crumbling.
When I put everything back together and turned it on to check if it would spin, I heard a buzzing sound and after a few minutes there was a burning smell.
What should I check to diagnose this problem? would help to have make or model numbers to show age of machine
Nov 26, 2012 | Whirlpool Washing Machines
Maytag 9700 fills then stops, won't agitate or spin
What is the model number list on the machine? Look on the top of the console.
Oct 13, 2012 | Maytag Washing Machines
My roper top load washer model rtw4440vq fills with water but wont wash, spin or drain
see this causes and fix it. God bless you
Motor Coupling If the washer won't spin or agitate the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and
Drive Belt If the washer won't spin or agitate, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin or agitate properly.
Drive Motor If the washer won't spin or agitate the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged, replace it.
Stator Assembly If the washer won't spin or agitate the stator assembly might be burned out. The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Door or Lid Latch Assembly If the washer won't spin or agitate the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't spin or agitate the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Motor Control Board If the washer won't spin or agitate the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
Sep 30, 2012 | Roper Washing Machines
Washing machine won't fill. i filled it by hand with water, it won't agitate either, only spins.
The inlet solenoid is probably bad. And it won't agitate unless it fills and stops filling automatically.
May 17, 2012 | Whirlpool Washing Machines
Ge top load washer won't agitate or spin after
what is your model number is then we can started then okay
Sep 15, 2011 | GE Washing Machines
Jun 14, 2011 | Whirlpool LSR7333 Top Load Washer
Washing Machines Logo
19 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
