Question about Maytag Centennial 3.2 cu. ft. SuperSize Plus Top Load Washer
Maytag centennial washer control board - Maytag Centennial 3.2 cu. ft. SuperSize Plus Top Load Washer
richroth
  • 9472 Answers
SOURCE: maytag centennial commercial technology washer
What is your model number?
Posted on Oct 25, 2011
  • 112 Answers
SOURCE: NO power or dead control board with maytag washer mah9700aww
Are you getting power at the wall plug? Test it with a lamp or nitelite. GFI are made to protect people and need to be tested annualy by the button on the plug. You also have to reset it by the plug or circuit breaker. If the washer is on the same circuit as something else that uses high current it may too much current for the circuit. It use to be that we could not wash clothes and use the microwave so I moved the microwave.
Posted on Aug 12, 2009
beltronic205
  • 1474 Answers
SOURCE: Overfilling maytag centennial - brand new?
Sounds like a hose off pressure switch or faulty switch/ however make sure drain connected ok 1st....
Posted on Oct 02, 2009
appliancguy
  • 86 Answers
SOURCE: Maytag centennial washer - power went out while
Set the timer to any off position. Unplug the unit for 10 minutes. Plug it back in and try that. The worst thing
you can do to a Maytag washer is advance the timer yourself...hope this helps.
Posted on Apr 02, 2011
  • 3289 Answers
SOURCE: I just purchased a Maytag centennial washer. I
According to page 6 of the manual for the "3 cu. ft. Capacity Maytag® Centennial® Top Load Washer" and page 8 of the manual for the "Centennial® High-Efficiency Top Load Washer", not more than 1 cup (250 ml) should be used in either machine.
Also, it should be added to the dispenser cup on the front left of the machine - not directly to the wash as it will interfere with the detergents ability to clean the clothes.
I hope this helps & good luck. Please rate my reply. Thanks.
Posted on Apr 20, 2011
Testimonial: "Thank you so much. I looked on pge 8 you are right. Wonderful site. More people should know about this. Thank you more than I can say. "
How do you clean out the drain pump maytag centennial washer
Maytag & Whirlpool & Kenmore Washer Pump Repair ...
? 3:44
https://www.youtube.com/watch?v=97rBObh_3mQ
Sep 12, 2013 - Uploaded by ApplianceVideo.com
Repair your own Maytag Top Load Washer which has the following ... Took me awhile to unclog as an entire ...
Washer Won't Drain - Pump Clogged with Sock - Repair ...
? 1:53
https://www.youtube.com/watch?v=tHT7PmmFc9w
Dec 2, 2011 - Uploaded by Tomahawk DIY
Washing machine pump clogged with a sock. ... I searched hi and low trying to figure out why my washing ...
HE Maytag Centennial Washer Fix - YouTube
? 31:43
https://www.youtube.com/watch?v=CoTlOr3Gxuk
Nov 15, 2013 - Uploaded by mike3000ace1
So how do you open the washer to pull out the Manual? .... +mike3000ace1 Hi, I have a 2011 Maytag ...
Maytag Centennial Washer Drain, Transmission ...
Jan 05, 2016 | Maytag Washing Machines
Coninuosly repeats spin cycle, any suggestions how to remedy this? I have to manually cancel the cycle in order for the machine to stop recycling through spin
I had a Centennial washer on a service call doing this just the other day... After putting it trough diagnostics I found no errors and all the washer's mechanics tested okay. After resetting the control by putting it trough the diagnostics mode it continued to repeat cycles without restarting the washer.
  • Try running it through diagnostics and see what error codes are in the memory. (Guide is linked below)
  • What are the codes? do they give any more clues?
  • clear the codes and run a test cycle.
  • does it work?
  • if it checks out properly with the diagnostics it's probably a bad control board...
Maytag Centennial Washer Diagnostic Guide
If it does turn out to be the control try contacting Maytag (Whirlpool) for a parts concession... Whirlpool customer service guide is linked below.
Hope that helps! Good luck!
Jun 16, 2015 | Maytag Centennial Top Load Washer
Wash cycle will agitate 3 spins then nothing for a few minutes then 3 more and nothing again and repeat over and over
you may want to put it through a diagnostics cycle and check for error codes... Maytag Centennial Washer Repair Guide
The tub sensor can cause the washer to act strangely like that. Also there are two mechanical styles of washer branded Maytag Centennial. The model number would help to know we are talking about the one I think we are talking about.
Hope that helps!
May 27, 2015 | Maytag Centennial 3.2 cu. ft. SuperSize...
Specs for model#MVWC400XW0 Maytag Centennial Washer
It definitely could be a clogged or bad pump. However, it's always a good idea to check for error codes before replacing a part...Especially expensive ones...
http://applianceassistant.com/Washer-Repair/Maytag-Centennial/Maytag-Centennial-Washer-Error-Fault-Codes.php
Hope it helps! Good luck!
Mar 02, 2015 | Maytag Centennial 3.2 cu. ft. SuperSize...
Repair manual Where I can download the repair manual for the maytag centennial washer
This is a manual. Since there are so many versions, you might need to search for the appropriate one. I searched for "Maytag centennial top load washer repair manual". There was a Maytag site, but download was very slow. http://applianceassistant.com/ServiceManuals/8178628_ml-3_maytag_centennial_top-load_washer.pdf#zoom=100#scrollbar=1#toolbar=1 http://applianceassistant.com/ServiceManuals/8178628_ml-3_maytag_centennial_top-load_washer.pdf
Jul 30, 2014 | Maytag Centennial Top Load Washer
My mayage centennial washer is agitating before the water begins to come in , how do I fix it?/
We had the same problem with our Maytag Centenial Washer. I simply removed the Auto Fill Sensor, cleaned the contacts with Deoxit contact cleaner and problem solved. All was done in less than 20 minutes.
Oct 14, 2011 | Maytag Centennial 3.2 cu. ft. SuperSize...
I just purchased a Maytag centennial washer. I just love it the Maytag products arethe best. Question I am using the HE detergents as the book suggests, however how much bleach do I use?
Apr 20, 2011 | Maytag Centennial MTW5800TW Top Load...
Maytag Centennial 3.2 cu. ft. SuperSize Plus Top Load Washer Logo
159 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
