Question about Dometic 3309518.003 Brisk Air Conditioner Replacement Shroud Polar White
Trying to install dometic shroud 3309518.003
Replacing shroud, ours cracked. Replacement seems too snug for our RV, although it is the right replacement number for the unit. what can we try to do?
    Genius:
  • Dometic Master
  • 1,363 Answers
Install low end of shroud down over band then pivot high end down over band. if still a problem take a strap and tighten around band to hold in.
Posted on Aug 20, 2015
motor1258
  • 6674 Answers
SOURCE: dometic duo therm a/c for rv
If it's a dometic try ( http://www.dometic.com/enus/Americas/USA/RV-Products/climate/ac-display-page/?productdataid=66932 ) and if it's a coleman/RVP try ( http://www.rvcomfort.com/rvp/products/rooftop/LP_polarMach.php )
Posted on Aug 29, 2008
SOURCE: RV Dometic AC Comfort Control Double EE Problem
I have a dometic duo-therm. The unit works great and fan blows strong and both high and low work., but air is coming out of the ceiling unit rather than the duct work. The bedroom unit works OK, but the air is strong out of one duct, and not much comes out of the others. The front unit only has air coming out on the A/C unit and none out of the ducts.
Posted on Mar 18, 2009
SOURCE: Older Penguin roof shroud, new style fit?
I just replaced my two 620315.321 shrouds with the newer style without any problems. I went to the Camping World site (and called them) with model no. and they knew what to send me. I also found that they had the best price at $79.00 (member price) with free shipping.
I didnt check your shroud part no.s, but think you will be ok if you do as I did.
If you have any question about installing, you can email me at remeola@comcast.net
Posted on May 05, 2009
motor1258
  • 6674 Answers
SOURCE: Rooftop RV Air Conditioner: replaced capacitor on dometic 59516-531 steal trip...
You need to borrow a clamp on style amp gauge, and check amp draw on black wire in box where hydro wires connect. (PLEASE, be careful, and if not experienced in this type of test, don't try it, due to likelihood of getting a shock. ) If it's the compressor kicking in that's causing the breaker to trip, and capacitor is good, then it's usually a problem with either low incoming (supply) 110-120 AC voltage, which will cause high amperage draw, or compressor on it's way out causing high amp draw. If it's only drawing 15-18 amps, and your tripping a 20 amp breaker, then breaker is getting weak.
Posted on Jun 05, 2010
motor1258
  • 6674 Answers
SOURCE: water dripping out of rv ac into rv.
Is it a ducted system? If yes, check that there isn't gaps between the divider that separates return air at the front, with forced(cold) air. You can usually use a flashlight and look for gaps, or even (very carefully) feel it blowing cold into the warm air return. If you find some gaps, buy some foil tape, and tape them off good and retry and see if it still happens. Some older units experienced cracks in drip trays that allowed condensation to drip inside as well. Get back to me with year of your RV, and whether it's ducted or non-ducted system, and perhaps I can guide you better on what to look for.
Posted on Jun 22, 2010
Where do i find the model # on rooftop dometic ac? i lost the cover and need to order a new one?
Regarding location of the model number, look under the ceiling bezel on the inside of the RV. Also, many aftermarket replacement shrouds will fit several different models of Domentic air conditioners. You might want to check out pplmotorhomes.com
Jan 23, 2015 | Dometic Rooftop RV Air Conditioner
Where can I find a shroud for my 2003 model 59516.331 duo-therm high efficiency Dometic roof mounted dometic RV air conditioner?
Try googeling Camping world ,Adventurerv ,or best rv and truck supplies ,these are all in the USA who deliver to Australia.I usually find that it is much cheaper to buy parts like this from the US even with the delivery charge.
Good Luck John
Oct 11, 2012 | Dometic Rooftop RV Air Conditioner
Need a replacement r v air conditioner shroud polaris by dometic 28inches wide 41 7/8 inches long & 9 1/2 inches high
Can you get model number of bottom of upper unit, from inside the trailer? The roof unit model number will make it easier to find replacement shroud.
Sep 27, 2012 | Dometic Rooftop RV Air Conditioner
Where can I find a replacement shroud for my dometic roof top A/C?
Try any local RV dealer, camping world, etc , or call 1-800-544-4881 to order directly from Dometic.
This link will take you to a dealer locator for your info on dealers in your area.( http://www.dometic.com/enus/Americas/USA/Customer-Support/Dealer-Locator/ ). Have your model number ready. Most dealers may even have a used one to sell you if you ask.
Sep 29, 2011 | Dometic Rooftop RV Air Conditioner
We have a Dometic Duo Therm airconditioner on our RV. The model number is 620515.331. When I climbed up on the step ladder to have a look at the roof of the coach, I noticed that encircling the unit,...
Yes once you remove the screws the shroud should come right off. The cover is just that, the cover for the unit. You might think about putting some screening around the opening to keep this material out.
May 29, 2011 | Dometic Rooftop RV Air Conditioner
Where do I find the model number of my Dometic air conditioner that is on my RV?
Remove the shroud. You'll find the model and product number on the side after removing the plastic shroud.
Oct 04, 2010 | Dometic Rooftop RV Air Conditioner
Water dripping out of rv ac into rv.
Jun 20, 2010 | Dometic Rooftop RV Air Conditioner
Dometic 3309518.003 Brisk Air Conditioner Replacement Shroud Polar White Logo
73 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
