Question about Refrigerators
Roper refrigerator model # RT21LMXKQ02 leaks water into refrigerator . How can I fix this problem?
2 Suggested Answers
jtbjtb
  • 135 Answers
SOURCE: Roper Refrigerator, top freezer leaking water into refrigerator
This is usually caused by a plugged freezer drain. The back wall (or floor) of the freezer may come out to access the drain. Clear out anything visible and run a stiff wire thru it. Test with a cup of water. Hope this helps!
Posted on Jan 01, 2009
Roper refrigerator leaks
Good job! most people do not know about the evaporator drain.
I would check the tubing to the icemaker, icemaker inflow valve and, water filter.
Jan 23, 2010 | Roper RT21AKXKQ Top Freezer Refrigerator
Water leaking inside freezer and refrigerator.
you have a clogged drain tube in the freezer compartment. it is frozen with ice and as the unit goes in to a defrost cycle the water has no place to go. you can fix it the easy way, just unplug the unit and let it defrost. this will take care of your issue.
Oct 19, 2009 | Roper RT21AKXKQ Top Freezer Refrigerator
Leaking water inside fridge/freezes the food
Most likely your defrost condensate drain in the rear of your freeze is frozen over. I have put together a long page on the link below. Little too much about leaks in refrigerators and how to solve the problem to fit this page. Choose the part that applies most to your situation and let me know how I may help you resolve yours. I'll be here if you need so click on the link below, Thanks, Sea Breeze
HOW TO FIX A DRAIN LEAK INSIDE REFRIGERATOR AND FREEZER PART 2
Aug 13, 2009 | Roper RT21AKXKQ Top Freezer Refrigerator
Ice is forming in the bottom of my freezer, blocking the drain hole, and dripping water into the refrigerator. We defrosted it, and it worked fine for 2 weeks. Now it's doing it again. The drain hole is...
Defrost the drain again and use an aluminum wire , maybe 14-16 guage ,inserted into the drain hole approx 4 inches and wrap about 1 turn of the top end of the wire around the calrod defrost heater , This wire , will transfer heat from the heater to the drain hole , keeping it from freezing up again . Also , once cleared , use a small hose and blow into the drain to remove any debris possibly accumulated . Do this before installing the wire .
Jul 20, 2009 | Refrigerators
Water leaking at bottom of freezer side
that is not a leakage it might be sweating of the chilled line. and to collect this water there will be a tray fixed below the freeser or refrigerator exactly on the condensor so check this tray is in its place.
May 28, 2009 | Roper RS22AQXKQ Side by Side Refrigerator
Leaking water
the water reservoir tank could be your problem, take out the drawers and operate the dispenser and see if water is leaking from it. if so replacement of the tank is very easy
May 21, 2009 | Roper RS22AQXKQ Side by Side Refrigerator
Icemaker leaks water into bucket when it dumps ice
Either the inlet valve is stuck or the icemaker solenoid is shored.
Most likely the second one.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Apr 09, 2009 | Roper RS22AQXKQ Side by Side Refrigerator
Water in refrigerator
clean the drain hose using air presure and liqued susa
Sep 24, 2007 | Roper RT14DKX Top Freezer Refrigerator
Refrigerators Logo
24 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
