Question about Oster TSSTTVMNDG Six Slice Toaster Oven w/ Toast, Bake, Convection Bake, Broil, Warm, Defrost and Pizza Functions, 450 Degree Max Heat, 90-Minute Timer & Extra Large Capacity
E1 oster toaster oven
E1 error
SOURCE: OSTER TOASTER OVEN --- TIMER TWIST KNOB BROKE
Need to replace all the knobs on the Euro-Pro Toaster oven model T0160. Please let me know where I can purchase these knobs.
Posted on Jan 20, 2009
SOURCE: Oster Toaster Oven 6232 replacement parts?
Write to Oster and they might give you a new one depending on how old it is
Posted on Apr 01, 2009
SOURCE: Oster Toaster Oven Model # 6192-33
I had the same problem where the time knob broke. I filled in a claim form on the Oster Website and they answered within 3 days saying the timer knob was discontinued and no longer available. They proposed to replace the whole toaster-oven with another model 6073-33 which I received last week. I've to say that their customer service was amazing.
Posted on May 12, 2009
SOURCE: broken timer knob
Posted on May 13, 2009
SOURCE: Oster 6232 toaster oven.
trying to find a solution for a broken knob, i discovered that there aren't many decent options. so i took it upon myself to find one. my father actually recommended that i post the solution, seeing that there were so many with broken knobs. now this works on the timer knob on an oster 6232 toaster oven. it may work on the other knobs and possibly other models, but i cannot confirm that. the plastic stem of the knob that slips over the medal stem of the timer had broken. i crazy glued it back together and knew that there was no way in hell it would hold up with just glue. sorry for the lack of pics on this part. with the broken piece glued back in place, i went to home depot to find something/ anything that would securely slip over the stem of the knob. i tried all sorts of tubing. copper, pvc, steel and found nothing. in the plumbing isle with all the brass fittings and compression fittings, i found an "ander-lign compression nut" 5/8" OD w/ insert. part # A-304 961-P. 634052c.jpg
all you need is the brass flanged insert. if you can find it without the nut and compression ring, then more power to you. after buying this, slip the piece over the knob stem flanged end first. i used 5 minute opoxy to ensure it would stay in place. 7c9f2a3.jpg
i then used a cone shaped diamond bit in my dremel tool to notch out the two sides of the knob. 6be2e7e.jpg
just cut the brass down enough to match the notches in the stem of the knob. 0cdfdf7.jpg
and there you have it. sorry for the 2 blurry pics. hope this can help some of you.
Posted on Oct 15, 2009
Oster 6058 Toaster Oven heating elements are not working properly. Can parts be replaced?
You will be able to locate authorized parts and service centers by visiting http://www.oster.com
Regards.
Jun 17, 2011 | Oster 6058 Toaster Oven with Convection...
When I plug in my Oster 6248 toaster oven, it flashes error
This is caused by a bad contact on the heat sensor located on the top inside the oven...now if i could juste find the replacement part...
Mar 14, 2010 | Oster Toaster Ovens
User Manual Oster-Toaster-Oven-Broiler-6233
If manufacturer site is of no help, check here, they have the Oster 6233 manual for download.
Aug 15, 2009 | Oster 6232 / 6233 1500 Watts Toaster Oven...
I have an oster toaster that worked for about 8 months, then just recently it shows this error (err) aftr toasting for a min. do you know what i can do?
It sounds like you have the same problem as the Oster 6248 typically develops. The fix is to avoid ever buying anything made by Oster again, because it's all the same ****, made in China, just more overpriced.
Jul 14, 2009 | Oster 6239 Toaster Oven with Convection...
Oster Digital Convection Toaster Oven
Not A solution but I had the issue with a new oven and the factory just replaced it with a different model, My web searches found LOTS of problems like yours and it seems my model oven was discontinued even before I bought it from walmart.
Jun 12, 2009 | Oster Toaster Ovens
Jan 30, 2008 | Oster 6232 / 6233 1500 Watts Toaster Oven...
My toaster keeps beeping and comes up with an error message can you help
I just called Oster Service and the said to plug in the unit, hold the start button for 10 seconds and unplug the unit. My oven reset before I was able to try this, so let me know if this works for you.
Dec 08, 2007 | Oster 6235 Toaster Oven with Convection...
Oster TSSTTVMNDG Six Slice Toaster Oven w/ Toast, Bake, Convection Bake, Broil, Warm, Defrost and Pizza Functions, 450 Degree Max Heat, 90-Minute Timer & Extra Large Capacity Logo
259 people viewed this question
Top Oster Toaster Ovens Experts
Angel Joseph Jr.
Angel Joseph Jr.
Craig Butler
Craig Butler
john h
Are you an Oster Toaster Oven Expert? Answer questions, earn points and help others
