Question about Sharp AR-M350U Copier
Sharp ar-m165 error code 72-04
How do i clear this error?
  • 2072 Answers
SOURCE: Sharp AR-287 Copier error code H5-01
You might need to run a service mode to reset the machine:
P * C * 14 (start) then 1 for Yes and follow on screen directions, code should clear out.
Posted on Mar 17, 2008
  • 62 Answers
SOURCE: Error code H4-01
This mean you have low temp. on heat lamp 2 program interput clear interrupt 14 print may clear this code. if not you can look at the fusing unit and reset thrmo breaker that may be pop off.
Posted on Jul 30, 2008
  • 190 Answers
SOURCE: error code Sharp AR-M 257
The F2-04 error code you are getting is that you are using the wrong toner.It may be form sharp,but it toner chips is different.Only the chips swapping at the toner back can help you.
Posted on Jan 27, 2009
  • 990 Answers
SOURCE: We have a Sharp AR-335 and it is giving an error
Hello sir; There is the way to reset;
1, press "program", "interupt", "clear", "interupt'.
2, enter 14 press print.
3,turn power off and back on again.
Posted on May 18, 2009
SOURCE: sharp ar-m205 error code E7 11
U HAVE TO UPGRADE THE FIRM WARE BY ENTERING SIMULATION 49-1 THE VALUE IS d THEN UPDATE THE FIRM WARE IF U HAVE IT
Posted on Jun 06, 2009
Sharp AR-M165 simulation code H4-00
try this...
Steps
We'll need to enter the simulation mode by pressing the # * C * 14 (HARSH - STAR - C - STAR - 14) and then hit the copy button twice. The machine will restart and the error code will stop showing.
You have successfully rebooted your Machine...
Note: You will need to have a fast finger for it to enter the simulation mode.
Oct 31, 2017 | Sharp Office Equipment & Supplies
Sharp m165 error h4-00 give solution
Heat roller abnormally low temperature
Check blinking of the heater lamp
with SIM 5-2.
When the lamp blinks normally:
Check the thermistor and the
harness.
Check the MCU PWB thermistor
input circuit.
When the lamp does not light:
Check for heater lamp
disconnection or thermostat
disconnection.
Check the interlock switch.
Check the power supply PWB
and MCU PWB lamp control
circuit.
Clear the trouble with SIM 14.
May 12, 2014 | Sharp AR-BC260 Color Copier
Sharp m165 showing error H4-00
H4-00 relates to the fusing unit not reaching the desired temperature. This could be due to a heat lamp or thermistor failure. I would recommend calling your local service engineer. hope this helps.
Apr 22, 2013 | Sharp AR-BC260 Color Copier
It display
Check the white area of document glass and clean it or the copy lamp is not lighting.
Nov 12, 2009 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-M160 H4 error code
Clearing a trouble code on a AR-M160 is a little different than the AR160.
Try "#" "interrupt" "clear" "interupt" "1" "4" "start key"
This should clear the error. Even if you replace the fusion unit you will need this code to clear the error
Oct 26, 2008 | Sharp AR-M160 Laser Printer
Error code 4H on sharp ar 5316
WHEN THE SHARP AR-5316 PHOTOCOPIER IS SWITCHED ON THE ERROR CODE 4H APPEARSAND THE MACHINE CANNOT BE OPERATED. IHAVE TRIED THE SOLUTION SUGGESTED JUNE THIS YEAR BUT IT DID NOT WORK. WHAT CAN I DO TO GET THE MACHINE TO WORK? IT IS VERY URGENT.
Feb 18, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-M350U Copier Logo
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
